stm32定時(shí)器1PWM控制PA8,定時(shí)器3控制PD2
[打印本頁(yè)]
姚小黑
時(shí)間:
2018-8-27 22:14
兩個(gè)定時(shí)器同時(shí)打開(kāi),pwm不工作,單獨(dú)都可以工作,單步運(yùn)行到紅色字體處出現(xiàn)問(wèn)題,沒(méi)有弄明白請(qǐng)大神幫忙看一下,
定時(shí)器3初始化u16 time_ms=0;
u16 USART1_Heartbeat_time=0;
* 函數(shù)
void time3_init(u16 arr,u16 psc)
TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
NVIC_InitTypeDef NVIC_InitStructure;
RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3, ENABLE); //時(shí)鐘使能
TIM_TimeBaseStructure.TIM_Period = arr; //設(shè)置在下一個(gè)更新事件裝入活動(dòng)的自動(dòng)重裝載寄存器周期的值 計(jì)數(shù)到5000為500ms
TIM_TimeBaseStructure.TIM_Prescaler =psc; //設(shè)置用來(lái)作為TIMx時(shí)鐘頻率除數(shù)的預(yù)分頻值 10Khz的計(jì)數(shù)頻率
TIM_TimeBaseStructure.TIM_ClockDivision = 0; //設(shè)置時(shí)鐘分割:TDTS = Tck_tim
TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up; //TIM向上計(jì)數(shù)模式
TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure); //根據(jù)TIM_TimeBaseInitStruct中指定的參數(shù)初始化TIMx的時(shí)間基數(shù)單位
TIM_ITConfig(TIM3,TIM_IT_Update,ENABLE); //使能指定的TIM2中斷,允許更新中斷
NVIC_InitStructure.NVIC_IRQChannel = TIM3_IRQn; //TIM3中斷
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 3; //先占優(yōu)先級(jí)0級(jí)
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 3; //從優(yōu)先級(jí)3級(jí)
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; //IRQ通道被使能
NVIC_Init(&NVIC_InitStructure); //根據(jù)NVIC_InitStruct中指定的參數(shù)初始化外設(shè)NVIC寄存器
TIM_Cmd(TIM3,ENABLE); //使能TIM3定時(shí)器
TIM_ClearITPendingBit(TIM3, TIM_IT_Update); //清除TIMx更新中斷標(biāo)志
//時(shí)間10ms
void TIM3_IRQHandler(void) //TIM3中斷
if (TIM_GetITStatus(TIM3, TIM_IT_Update) != RESET) //檢查指定的TIM中斷發(fā)生與否:TIM 中斷源
TIM_ClearITPendingBit(TIM3, TIM_IT_Update ); //清除TIMx的中斷待處理位:TIM 中斷源
time_ms++;
USART1_Heartbeat_time++; //心跳定時(shí)器
if(LED_Red.LED_Start_Flash_Flag==1) //指示燈定時(shí)器
LED_Red.LED_Start_Flash_time++;
LED_Red.LED_Start_Flash_Flag=0;
LED_Red.LED_Start_Flash_time=0;
if(LED_Green.LED_Start_Flash_Flag==1) //指示燈定時(shí)器
LED_Green.LED_Start_Flash_time++;
LED_Green.LED_Start_Flash_Flag=0;
LED_Green.LED_Start_Flash_time=0;
if(((USART1_Heartbeat_time>=500)&&(USART1_Heartbeat_flag==0)))//串口1心跳
printf("\r\n @@@Heartbeat@@@ \n");;
定時(shí)器1pwm初始化
void TIM1_PWM_Init(u16 arr,u16 psc)
TIM_OCInitTypeDef TIM_OCInitStructure;
RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1, ENABLE);//
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_AFIO, ENABLE); //使能GPIO外設(shè)和AFIO復(fù)用功能模塊時(shí)鐘
//設(shè)置該引腳為復(fù)用輸出功能,輸出TIM1 CH1的PWM脈沖波形
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8; //TIM_CH1
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; //復(fù)用推挽輸出
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_Init(GPIOA, &GPIO_InitStructure);
TIM_TimeBaseStructure.TIM_Period = arr; //設(shè)置在下一個(gè)更新事件裝入活動(dòng)的自動(dòng)重裝載寄存器周期的值 80K
TIM_TimeBaseStructure.TIM_Prescaler =psc; //設(shè)置用來(lái)作為TIMx時(shí)鐘頻率除數(shù)的預(yù)分頻值 不分頻
TIM_TimeBaseInit(TIM1, &TIM_TimeBaseStructure); //根據(jù)TIM_TimeBaseInitStruct中指定的參數(shù)初始化TIMx的時(shí)間基數(shù)單位
TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM2; //選擇定時(shí)器模式:TIM脈沖寬度調(diào)制模式2
TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable; //比較輸出使能
TIM_OCInitStructure.TIM_Pulse = 0; //設(shè)置待裝入捕獲比較寄存器的脈沖值
TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High; //輸出極性:TIM輸出比較極性高
TIM_OC1Init(TIM1, &TIM_OCInitStructure); //根據(jù)TIM_OCInitStruct中指定的參數(shù)初始化外設(shè)TIMx
TIM_CtrlPWMOutputs(TIM1,ENABLE); //MOE 主輸出使能
TIM_OC1PreloadConfig(TIM1, TIM_OCPreload_Enable); //CH1預(yù)裝載使能
TIM_ARRPreloadConfig(TIM1, ENABLE); //使能TIMx在ARR上的預(yù)裝載寄存器
TIM_Cmd(TIM1, ENABLE); //使能TIM1
姚小黑
時(shí)間:
2018-8-27 22:29
初始化必須定時(shí)器1必須在前定時(shí)器3在后
gdfsg
時(shí)間:
2019-7-22 17:57
樓主還有源代碼么,能分享一下
he20095732
時(shí)間:
2020-3-25 11:56
解決了嗎,貌似沒(méi)有執(zhí)行引腳復(fù)用呀 GPIO_PinRemapConfig(GPIO_FullRemap_TIM1, ENABLE);
我是怎樣都不行呀,用PA3來(lái)輸出PWM還好好的
duan123xx
時(shí)間:
2020-4-26 13:35
同樣的問(wèn)題 怎么解決啊
