溫度傳感器SHT1x和SHT2x的STM32源代碼
zbr1995
2018-8-27 11:18
溫度傳感器SHT1x和SHT2x的iic通信代碼,這都是從網上找的代碼,sht1x親測可用,sht2x時序也是準確的。后續將呈現sht7x代碼
(36.97 KB, 下載次數: 26)
2018-8-27 18:28 上傳
#include "led.h"
#include "delay.h"
#include "sys.h"
#include "usart.h"
#include "lcd.h"
#include "SHT10.h"
SHT1x sht1x; //定義傳感器結構體
int main(void)
u8 t=0,error=0,checksum,value=0;
volatile u8 T_Display=0,H_Display=0;
u16 T_Value=0,H_Value=0;
delay_init(); //延時函數初始化
uart_init(9600); //USART1初始化
LED_Init(); //LED初始化
LCD_Init();
SHT1x_Init();
POINT_COLOR=RED;//設置字體為紅色
LCD_ShowString(60,120,200,16,16,"SHT1X Test");
POINT_COLOR=BLUE;//設置字體為藍色
LCD_ShowString(60,150,200,16,16,"Temp: . C");
LCD_ShowString(60,170,200,16,16,"Humi: . %RH");
if(!SHT1X_read_statusreg(&value))
if(value&0x07)
for(value=5;value!=0;value--)
if(!SHT1X_write_statusreg(0))break;
else SHT1X_softreset();
//------------------------讀取SHT1X傳感器數據--------------------------------------
error+=SHT1x_Measure( &T_Value,&checksum,0); //measure temperature
error+=SHT1x_Measure( &H_Value,&checksum,1); //measure humidity
if(error!=0)SHT1x_Reset(); //通訊故障,復位傳感器
sht1x.T_Result = T_Value;
sht1x.H_Result = H_Value;
SHT1X_Caculation1((float*)&sht1x.T_Result, (float*)&sht1x.H_Result );
sht1x.Temperature=sht1x.T_Result;
sht1x.Humidity=(u16)sht1x.H_Result;
sht1x.DEW=SHT1X_dewpoint1(sht1x.T_Result, sht1x.H_Result);
//顯示函數處理
//-------------------溫度顯示-------------------------------------------------
if(sht1x.Temperature<0)
LCD_ShowChar(60+40,150,'-',16,0); //顯示負號
sht1x.Temperature=-sht1x.Temperature; //轉為正數
else LCD_ShowChar(60+40,150,' ',16,0); //去掉負號
LCD_ShowNum(60+40+8,150,sht1x.Temperature/100,2,16); //顯示正數部分
if((sht1x.Temperature%100)>=0 && (sht1x.Temperature%100)<=9 )
LCD_ShowNum(60+40+32,150,sht1x.Temperature%100,1,16); //顯示小數部分
LCD_ShowNum(60+40+32,150,sht1x.Temperature%100,2,16); //顯示小數部分
//-------------------------濕度顯示-----------------------------------------------
LCD_ShowNum(60+40+8,170,sht1x.Humidity/100,2,16); //顯示正數部分
if((sht1x.Humidity%100)>=0 && (sht1x.Humidity%100)<=9 )
LCD_ShowNum(60+40+32,170,sht1x.Humidity%100,1,16); //顯示小數部分
LCD_ShowNum(60+40+32,170,sht1x.Humidity%100,2,16); //顯示小數部分
t++;
if(t==20)
t=0;
LED0=!LED0;
溫度傳感器程序.rar
(1.12 MB, 下載次數: 54)
2018-8-27 11:17 上傳
petertang
2020-3-21 09:06
剛看到,希望可以使用。謝謝樓主。
petertang
2020-3-21 09:48
怎么下載一次,再下載,還扣分呢?呵呵!
