標題: stm32f1的adc掃描模式并通過DMA輸入 [打印本頁]
作者: hi-Slowly    時間: 2018-8-22 20:49
  1. #include "adc.h"
  2. #include "delay.h"
  3.
  4. //初始化ADC
  5. //這里我們僅以規則通道為例
  6. //我們默認將開啟通道0~3
  7. extern const int  M; //為10個通道
  8. void  Adc_Init(void)
  9. {
  10.         ADC_InitTypeDef ADC_InitStructure;
  11.         GPIO_InitTypeDef GPIO_InitStructure;
  12.         RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA |RCC_APB2Periph_GPIOB| RCC_APB2Periph_GPIOC|RCC_APB2Periph_ADC1        , ENABLE );          //使能ADC1通道時鐘
  13.         RCC_ADCCLKConfig(RCC_PCLK2_Div6);   //設置ADC分頻因子6 72M/6=12,ADC最大時間不能超過14M
  14.
  15.         //PA0/1/2 作為模擬通道輸入引腳
  16.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0| GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4;
  17.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN; //模擬輸入引腳
  18.         GPIO_Init(GPIOA, &GPIO_InitStructure);
  19.         //PB0/1 作為模擬通道輸入引腳
  20.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1;
  21.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN; //模擬輸入引腳
  22.         GPIO_Init(GPIOB, &GPIO_InitStructure);
  23.         //PC0/1/2/3/4/5 作為模擬通道輸入引腳
  24.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5;
  25.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN; //模擬輸入引腳
  26.         GPIO_Init(GPIOC, &GPIO_InitStructure);
  27.         ADC_DeInit(ADC1);  //復位ADC1,將外設 ADC1 的全部寄存器重設為缺省值
  28.         ADC_InitStructure.ADC_Mode = ADC_Mode_Independent; //ADC工作模式:ADC1和ADC2工作在獨立模式
  29.         ADC_InitStructure.ADC_ScanConvMode =ENABLE; //模數轉換工作在掃描模式
  30.         ADC_InitStructure.ADC_ContinuousConvMode = ENABLE; //模數轉換工作在連續轉換模式
  31.         ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None; //外部觸發轉換關閉
  32.         ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right; //ADC數據右對齊
  33.         ADC_InitStructure.ADC_NbrOfChannel = M; //順序進行規則轉換的ADC通道的數目
  34.         ADC_Init(ADC1, &ADC_InitStructure); //根據ADC_InitStruct中指定的參數初始化外設ADCx的寄存器
  35.         ADC_RegularChannelConfig(ADC1, ADC_Channel_10, 1, ADC_SampleTime_239Cycles5 );
  36.         ADC_RegularChannelConfig(ADC1, ADC_Channel_11, 2, ADC_SampleTime_239Cycles5 );
  37.         ADC_RegularChannelConfig(ADC1, ADC_Channel_12, 3, ADC_SampleTime_239Cycles5 );
  38.         ADC_RegularChannelConfig(ADC1, ADC_Channel_13, 4, ADC_SampleTime_239Cycles5 );
  39.         ADC_RegularChannelConfig(ADC1, ADC_Channel_0, 5, ADC_SampleTime_239Cycles5 );
  40.         ADC_RegularChannelConfig(ADC1, ADC_Channel_1, 6, ADC_SampleTime_239Cycles5 );
  41.         ADC_RegularChannelConfig(ADC1, ADC_Channel_2, 7, ADC_SampleTime_239Cycles5 );
  42.         ADC_RegularChannelConfig(ADC1, ADC_Channel_3, 8, ADC_SampleTime_239Cycles5 );
  43.         ADC_RegularChannelConfig(ADC1, ADC_Channel_4, 9, ADC_SampleTime_239Cycles5 );
  44. //        ADC_RegularChannelConfig(ADC1, ADC_Channel_5, 10, ADC_SampleTime_239Cycles5 );
  45. //        ADC_RegularChannelConfig(ADC1, ADC_Channel_14, 11, ADC_SampleTime_239Cycles5 );
  46. //        ADC_RegularChannelConfig(ADC1, ADC_Channel_15, 12, ADC_SampleTime_239Cycles5 );
  47.   // 開啟ADC的DMA支持(要實現DMA功能,還需獨立配置DMA通道等參數)
  48.    ADC_DMACmd(ADC1, ENABLE);
  49.         ADC_Cmd(ADC1, ENABLE);        //使能指定的ADC1
  50.
  51.         ADC_ResetCalibration(ADC1);        //使能復位校準
  52.
  53.         while(ADC_GetResetCalibrationStatus(ADC1));        //等待復位校準結束
  54.
  55.         ADC_StartCalibration(ADC1);         //開啟AD校準
  56.         while(ADC_GetCalibrationStatus(ADC1));         //等待校準結束
  57.         ADC_SoftwareStartConvCmd(ADC1, ENABLE);                //使能指定的ADC1的軟件轉換啟動功能
  58. }
  59. //獲得ADC值
  60. //ch:通道值 0~3
  61. u16 Get_Adc(u8 ch)
  62. {
  63.           //設置指定ADC的規則組通道,一個序列,采樣時間
  64.         ADC_RegularChannelConfig(ADC1, ch, 1, ADC_SampleTime_239Cycles5 );        //ADC1,ADC通道,采樣時間為239.5周期
  65.         ADC_SoftwareStartConvCmd(ADC1, ENABLE);                //使能指定的ADC1的軟件轉換啟動功能
  66.
  67.         while(!ADC_GetFlagStatus(ADC1, ADC_FLAG_EOC ));//等待轉換結束
  68.         return ADC_GetConversionValue(ADC1);        //返回最近一次ADC1規則組的轉換結果
  69. }
  70. u16 Get_Adc_Average(u8 ch,u8 times)
  71. {
  72.         u32 temp_val=0;
  73.         u8 t;
  74.         for(t=0;t<times;t++)
  75.         {
  76.                 temp_val+=Get_Adc(ch);
  77.                 delay_ms(5);
  78.         }
  79.         return temp_val/times;
  80. }
頭文件和dma配置請從附件中下載
adc掃描模式并通過dma輸入.rar
4.45 KB, 下載次數: 75, 下載積分: 黑幣 -5
