KEA128電磁智能車程序
記樹與影
2018-8-21 20:12
KEA128電磁智能車程序
#include "headfile.h"
#include "KEA128_uart.h"
#include "KEA128_qiu.h"
#include "filter.h"
#include "All_Init.h"
#define Speed_set 0
#define zhong 2250
struct PID_Typedef //PID結構體
float P;
float I;
float D;
int Error;
int PreError;
int PreDError;//
int d_error;
int dd_error;
int Output;
int target;
int measure;
}PID_Typedef;
float Kp,Kd,Ks;
extern uint16 val_get_L;//左側電感電壓值 PTA8
extern uint16 val_get_R;//右側電感電壓值 PTA7
extern uint16 aveL,aveR;
extern float val_dev_to_one,val_sum_to_one,aveL_to_one,aveR_to_one;
//extern uint16 val_get_M;
extern uint8 time_flag,dir_time;
extern uint8 read_bianmaqi;
uint8 * itoa(int32 num);
uint16 SpeedSumL,SpeedSumR;
uint16 SpeedL,SpeedR;
uint16 uart_cnt=0;
uint16 sum_cnt;
double Speed_L;
double Speed_R;
float ActualErr=0.0;
float Err_L;
float Err_N;
float Error=0.0;
void speedout();
//void differential();
void ReadBianMaQi();
void Ad_deal();
void MOTOR_PID(struct PID_Typedef *PID,int target,int measure);
void PID_init();//pid參數賦值
struct PID_Typedef Left;
struct PID_Typedef Right;
int main(void)
get_clk(); //獲取時鐘頻率 必須執行
ALL_Init();
PID_init();
pit_init_ms(pit0,1); //初始化pit0 周期設置為10ms
set_irq_priority(PIT_CH0_IRQn,1); //設置pit0優先級
enable_irq(PIT_CH0_IRQn); //開啟pit0中斷
EnableInterrupts;
for(;;)
ReadBianMaQi();//讀取脈沖10讀取一次,
speedout(); //40ms進行一次控速
if(time_flag==50)
time_flag=0;
//uart_cnt++;
//if(uart_cnt>=10)
//uart_cnt=0;
void ReadBianMaQi()
if(read_bianmaqi>=10)
{//10ms讀取一次編碼器
read_bianmaqi=0;
adc_get();
filter1();
adc_to_one();
Ad_deal();
SpeedL = ftm_count_get(ftm1);//讀取脈沖
ftm_count_clean(ftm1);//清除寄存器
SpeedR = ftm_count_get(ftm0);//讀取脈沖1
ftm_count_clean(ftm0);//清楚寄存器
SpeedSumL +=SpeedL;
SpeedSumR +=SpeedR;
SpeedL=0;
SpeedR=0;
void speedout()
if(sum_cnt>=40)
{//40ms進行一次速度控制
sum_cnt=0;
Left.measure=SpeedSumL;
Right.measure=SpeedSumR;
SpeedSumL =0;
SpeedSumR =0;
// Left.target=200;
// Right.target=200;
if( ActualErr>0)//在一定的范圍內才加差速
Right.target=Speed_set-ActualErr*Ks;
Left.target=Speed_set+ActualErr;
Left.target=Speed_set+ActualErr*Ks;
Right.target=Speed_set-ActualErr;
if(Left.target > 700) //限幅防止輸出過大
Left.target= 700;
if(Left.target <-700) //限幅防止輸出過大
Left.target=-700;
if(Right.target > 700)
Right.target= 700;
if(Right.target <-700)
Right.target=-700;
// MOTOR_PID(&Left,Left.target,Left.measure);
// MOTOR_PID(&Right,Right.target,Right.measure);
// Left.target=200;
Left.Output=Left.target;
Right.Output=Right.target;
if(Left.Output>=900)//限上值 但是在這里不管下限 在計算里面管
Left.Output = 900;
else if(Left.Output<=-900)
Left.Output =-900;
if(Right.Output>=900)//限上值 但是在這里不管下限 在計算里面管
Right.Output = 900;
else if(Right.Output<=-900)
Right.Output =-900;
if(Left.Output>=0)
Left.Output=(uint16)Left.Output+0;
ftm_pwm_duty(ftm2,ftm_ch2,0);
ftm_pwm_duty(ftm2,ftm_ch3,Left.Output);
Left.Output=(uint16)(-Left.Output)+0;
ftm_pwm_duty(ftm2,ftm_ch3,0);
ftm_pwm_duty(ftm2,ftm_ch2,Left.Output);
if(Right.Output>=0)
Right.Output=(uint16)Right.Output+0;
ftm_pwm_duty(ftm2,ftm_ch0,0);
ftm_pwm_duty(ftm2,ftm_ch1,Right.Output);
Right.Output=(uint16)(-Right.Output)+0;
ftm_pwm_duty(ftm2,ftm_ch1,0);
ftm_pwm_duty(ftm2,ftm_ch0,Right.Output);
/*ftm_pwm_duty(ftm2,ftm_ch0,Left.Output); //,設置占空比,,右電機正轉,,在系統配置中已經將PWMIO口改成C0C1C2C3
ftm_pwm_duty(ftm2,ftm_ch2,0); //左電機正轉
ftm_pwm_duty(ftm2,ftm_ch3,Right.Output); */
uart_cnt++;
if(uart_cnt>=25)
{//4*25=1000 1秒輸出一次上位機,方便觀察
uart_cnt=0;
uart_putstr(uart2,"L編碼器目標");
uart_putstr(uart2,itoa(Left.target));
uart_putstr(uart2,"\t");
uart_putstr(uart2,"R編碼器目標");
uart_putstr(uart2,itoa(Right.target));
uart_putstr(uart2,"\n");
uart_putstr(uart2,"L編碼器速度");
uart_putstr(uart2,itoa(Left.measure));
uart_putstr(uart2,"R編碼器速度");
uart_putstr(uart2,itoa(Right.measure));
uart_putstr(uart2,"左邊感量");
uart_putstr(uart2,itoa(aveL));
uart_putstr(uart2,"右邊感量");
uart_putstr(uart2,itoa(aveR));
uart_putstr(uart2,"LDuty");
uart_putstr(uart2,itoa(Left.Output));
uart_putstr(uart2,"\t\t");
uart_putstr(uart2,"RDuty");
uart_putstr(uart2,itoa(Right.Output));
//整數轉換為字符串(輸入整數,返回字符串地址)
int32 i=0,isNegative=0;
static uint8 s[15]; //必須是全局變量或者是靜態變量
//如果是負數,先轉為正數
if((isNegative=num) < 0) num = -num;
//從個位開始變為字符,直到最高位,最后應該反轉
do
s[i++] = num%10 + '0';
num /= 10;
}while(num > 0);
//如果是負數,補上負號
if(isNegative < 0) s[i++] = '-';
//最后加上字符串結束符
s[i] = '\0';
/******翻轉字符串******/
//p指向s的頭部
uint8 *p = s;
//q指向s的尾部
uint8 *q = s;
while(*q) ++q;
q--;
//交換移動指針,直到p和q交叉
uint8 temp;
while(q > p)
temp = *p;
*p++ = *q;
*q-- = temp;
return s;
/*pid 調電機*/
/*****差速函數******/
/*void differential()
int chasu=0;
errorL=aveL-zhong;
errorR=aveR-zhong;
tempL=errorL*100;
tempL=tempL/zhong;
tempR=errorR*100;
tempR=tempR/zhong;
Right.target=(int)(speed_set-error*speed_set/100);
Left.target=(int)(speed_set-error*speed_set/100);
/* if( ActualErr>0)//在一定的范圍內才加差速
Right.target=(int)speed_set+ ActualErr;
Left.target=(int)speed_set-ActualErr*Ks;
Right.target=(int)speed_set-ActualErr;
Left.target=(int)speed_set+ ActualErr*Ks;
if( Left.target> 700) //限幅防止輸出過大
Left.target= 700;
if( Left.target <-700) //限幅防止輸出過大
Left.target=-700;
if( Right.target > 700)
Right.target= 700;
if( Right.target <-700)
Right.target=-700;
//給各自的target賦值
/******電機PID部分程序**********/
/*增量式 pid ,慢慢調 */
void MOTOR_PID(struct PID_Typedef *PID,int target,int measure) //target目標期望值,measure目標測量值,輸出占空比改變量
PID->Error=target - measure; //計算偏差。
PID->d_error = PID->Error - PID->PreError; //偏差計算(比例)
PID->dd_error = PID->d_error - PID-> PreDError; //偏差計算(微分)
PID->PreError = PID->Error; //存儲當前偏差
PID->PreDError = PID->d_error;
if ((PID->Error > -5) && (PID->Error <5)) // 設置調節死區 編碼器返回的值跟目標值在小誤差范圍內不調節 防止超調過度起反作用
; // 不執行PID調節
PID->Output+= ((PID->P* PID->d_error) + (PID->I * PID->Error) + (PID->D * PID->dd_error));
if(PID->Output>=900)//限上值 但是在這里不管下限 在計算里面管
PID->Output = 900;
else if(PID->Output<=0)
PID->Output =0;
void Ad_deal()
float IncrementErr;
Error=val_dev_to_one*100/pow(val_sum_to_one,1.5); //水平電感偏差
if(Error>=100)
Error=100;
if(Error<=-100)
Error=-100;
// Error=(sqrt(AD3)-sqrt(AD1))/(AD1+AD3)*3800;
/****************增量式PD****************/
IncrementErr=Kp*(Error-Err_N)+Kd*(Error-2*Err_N+Err_L); //增量式PD
ActualErr+=IncrementErr; //
Err_L=Err_N; //
Err_N=Error;
// Lost_Err(); //防丟線程序
/*****************兩輪差速效果*****************/
if(Error<=0) //計算兩輪差速效果
Error=-Error; //
Ks=Error/10; //
if(Ks>1.3) //
Ks=1.3; //0.78 //增大后內輪減速明顯
void PID_init()
Left.P = 0.4; //左輪P
Left.I = 0.28; //左輪I
Left.D = 0; //
Right.P = 0.4; //右輪P
Right.I = 0.28; //右輪I
Right.D = 0; //右輪D
/* 電感差速 */
Error=0.0;
Err_N=0.0;
Err_L=0.0;
Kp=5.0;
Kd=20.0;
/*左右輪差速效果*/
Ks=0.0; //在arithmetic.c中賦值Error/10
