標(biāo)題: 我又來(lái)問(wèn)這段程序是什么意思了 [打印本頁(yè)]
作者: 路人君    時(shí)間: 2018-8-21 19:13
#include <reg52.h>
#include <intrins.h>
#include "delay.h"
sbit RS = P2^4;
sbit RW = P2^5;
sbit E  = P2^6;
sbit RES = P2^3;
sbit PSB = P2^1;
sbit PAUSE = P3^0;
#define DataPort P0        //MCU P0<------> LCM
                    檢測(cè)忙位
void Check_Busy()
    RS=0;
    RW=1;
    E=1;
    DataPort=0xff;
    while((DataPort&0x80)==0x80);//忙則等待
    E=0;
                   寫命令
void Write_Cmd(unsigned char Cmd)
        Check_Busy();
        RS=0;
        RW=0;
        E=1;
        DataPort=Cmd;
        DelayUs2x(5);
        E=0;
        DelayUs2x(5);
                    寫數(shù)據(jù)
void Write_Data(unsigned char Data)
        Check_Busy();
        RS=1;
        RW=0;
        E=1;
        DataPort=Data;
        DelayUs2x(5);
        E=0;
        DelayUs2x(5);
                   液晶屏初始化
void Init_ST7920()
   DelayMs(40);           //大于40MS的延時(shí)程序
   PSB=1;                 //設(shè)置為8BIT并口工作模式
   DelayMs(1);            //延時(shí)
   RES=0;                 //復(fù)位
   RES=1;                 //復(fù)位置高
   DelayMs(10);
   Write_Cmd(0x30);       //選擇基本指令集
   DelayUs2x(50);         //延時(shí)大于100us
   Write_Cmd(0x30);       //選擇8bit數(shù)據(jù)流
   DelayUs2x(20);         //延時(shí)大于37us
   Write_Cmd(0x0c);       //開顯示(無(wú)游標(biāo)、不反白)
   Write_Cmd(0x01);       //清除顯示,并且設(shè)定地址指針為00H
   DelayMs(15);           //延時(shí)大于10ms
   Write_Cmd(0x06);       //指定在資料的讀取及寫入時(shí),設(shè)定游標(biāo)的移動(dòng)方向及指定顯示的移位,光標(biāo)從右向左加1位移動(dòng)
                   用戶自定義字符
void CGRAM()
     int i;
     Write_Cmd(0x30);
     Write_Cmd(0x40);
                   顯示字符串
x:橫坐標(biāo)值,范圍0~8
y:縱坐標(biāo)值,范圍1~4
void LCD_PutString(unsigned char x,unsigned char y,unsigned char code *s)
switch(y)
          case 1: Write_Cmd(0x80+x);break;
          case 2: Write_Cmd(0x90+x);break;
          case 3: Write_Cmd(0x88+x);break;
          case 4: Write_Cmd(0x98+x);break;
      default:break;
while(*s>0)
      Write_Data(*s);
      s++;
      DelayUs2x(50);
                      清屏
void ClrScreen()
   Write_Cmd(0x01);
   DelayMs(15);
                 主程序
main()
  unsigned char i;
   CGRAM();     //寫入自定義字符
      Init_ST7920();   //初始化
      LCD_PutString(0,1,"重量:");
          LCD_PutString(0,2,"單價(jià):");
          LCD_PutString(0,3,"總價(jià):");
      LCD_PutString(0,4,"");
          for(i=0;i<30;i++)
          DelayMs(200);
所以void CGRAM()
     int i;
     Write_Cmd(0x30);
     Write_Cmd(0x40);
}   這一串有什么用?對(duì)程序的影響是啥?
作者: devcang    時(shí)間: 2018-8-21 20:32
main()
  unsigned char i;
   CGRAM();     //寫入自定義字符------------------------看這行說(shuō)明
整個(gè)程序,應(yīng)該是模擬穩(wěn)重、計(jì)算總價(jià),顯示在LCD屏
作者: Hank丶Huang    時(shí)間: 2018-8-21 20:33
這個(gè)需要查看屏幕的datasheet的,估計(jì)是屏幕的相關(guān)指令。
類似1602的write_com(0x38);//設(shè)置16X2顯示,顯示5X7點(diǎn)陣,8位數(shù)據(jù)接口
還有相關(guān)寄存器的設(shè)置 比如光標(biāo)這樣的
作者: 路人君    時(shí)間: 2018-8-21 21:56
devcang 發(fā)表于 2018-8-21 20:32
main()
  unsigned char i;
我確實(shí)想寫這么個(gè)程序,但是我是直接改的,所以這一句我不太懂,但是那個(gè)寫入自定義我還是不懂,他這是定義了什么?
作者: 路人君    時(shí)間: 2018-8-21 21:57
Hank丶Huang 發(fā)表于 2018-8-21 20:33
類似1602的write_com(0x38);//設(shè)置16X2顯示,顯 ...
偶  謝謝 ,所以這玩意真的是設(shè)置大小的。。。。。。
作者: 人中狼    時(shí)間: 2018-8-21 22:56
這個(gè)是對(duì)帶字庫(kù)的12864液晶的設(shè)置參數(shù),帶字庫(kù)的12864液晶有多種工作模式,需要選擇,也可以切換
