標(biāo)題: 音樂豬八戒背媳婦 [打印本頁]
作者: bulia    時(shí)間: 2018-8-17 16:03
標(biāo)題: 音樂豬八戒背媳婦
#include <reg51.h>
sbit fm=P2^7;
uchar timeh,timel;//用于存放定時(shí)器的高8
uchar code zbjbxf[]=
   { //定義豬八戒背媳婦的簡譜數(shù)組
   0x64,0xA3,0xC1,0xA2,0x62,0x84,0x61,0x81,0x61,0xA4,
   0xA1,0x91,0xA1,0x81,0x64,0xA3,0xC1,0xD2,0xD2,0xD2,
   0xA2,0xC4,0xA1,0xC1,0xA1,0xC1,0xD2,0xD2,0xD2,0xA2,
   0xC4,0xC2,0x62,0xC2,0x62,0xA2,0xA2,0x84,0x94,0x94,
   0x92,0x81,0x91, 0xA2,0xC2,0xD4,0xE4,0xA4,0xE4,0xA2,
   0xE2,0xA2,0xE2,0xA2, 0xA2,0x84,0x94,0x94,0x92,0x81,
   0x91,0xA2,0xC2,0xD8
   }; //適合12M 的晶振定時(shí)器初值表,高低 位分開
uchar code chuzhi[]=
   0xff,0xff,0xFC,0x8E,0xFC, 0xED,0xFD,0x43,0xFD,0x6A,
   0xFD,0xB3,0xFD,0xF3,0xFE,0x2D,0xFE, 0x47,0xFE,0x76,
   0xFE,0xA1,0xFE,0xC7,0xFE,0xD9,0xFE,0xF9,0xFF,0x16
void timer0() interrupt 1 //定時(shí)器0中斷服務(wù)程序
TH0=timeh;//將timeh 賦給計(jì)時(shí)器的高8
TL0=timel;//將timel 賦給計(jì)時(shí)器的低8
fm=~fm;
}//定時(shí)器每次到時(shí)將蜂鳴器反相
void delay(uint z)
{        uint y;
    for(z;z>0;z--)
        for(y=19000;y>0;y--);
void delay1(uint z)
{        uint y;
    for(z;z>0;z--)
        for(y=112;y>0;y--);
music.rar
960 Bytes, 下載次數(shù): 7, 下載積分: 黑幣 -5
