基于ADXL345的c8051f330單片機簡易計步器源程序
T-BOY
2018-8-16 10:34
可以實現簡單計步并且可以計算卡路里消耗
#include <c8051f330.h>
#include <string.h>
#include <intrins.h>
#include "sys.h"
#include "5110.h"
#include "adxl345.h"
#include "ds1302.h"
sbit K1=P1^3;
sbit K2=P1^2;
sbit speak=P0^5;
unsigned char ADXL345_FLAG=0;
unsigned char START_FLAG=0;
unsigned char number=0;
unsigned char idata bad_flag[3];
unsigned int idata array0[3]={1,1,1};
unsigned int idata array1[3]={1,1,1};
unsigned int idata array2[3]={0,0,0};
unsigned int idata adresult[3];
unsigned int idata max[3]={0,0,0};
unsigned int idata min[3]={1000,1000,1000};
unsigned int idata dc[3]={500,500,500};
unsigned int idata vpp[3]={30,30,30};
unsigned int idata precision[3]={5,5,5};
unsigned int idata old_fixed[3];
unsigned int idata new_fixed[3];
unsigned int idata STEPS=0;
unsigned int idata time=0;
float xdata speed=0;
float xdata dist=0;
float xdata kalul=0;
SYSTEMTIME CurrentTime;
//獲取時鐘函數
void get_clock(void)
DS1302_GetTime(&CurrentTime);
DateToStr(&CurrentTime);
TimeToStr(&CurrentTime);
//時鐘顯示函數
void show_time(void)
Set_R_C_5110(0,12);
Write_String_5110(CurrentTime.DateString);
Set_R_C_5110(0,60);
Write_String_5110("---");
Write_Char_5110(CurrentTime.DateString[9]);
Set_R_C_5110(1,0);
Write_String_5110(CurrentTime.TimeString);
//BCD碼轉化成十進制碼
uchar zh(uchar temp)
temp=((temp&0x70)>>4)*10 + (temp&0x0F);
return temp;
void first_picture(void)
DS1302_SetTime(DS1302_YEAR,12);
DS1302_SetTime(DS1302_MONTH,1);
DS1302_SetTime(DS1302_DAY,11);
DS1302_SetTime(DS1302_WEEK,5);
DS1302_SetTime(DS1302_HOUR,12);
DS1302_SetTime(DS1302_MINUTE,12);
DS1302_SetTime(DS1302_SECOND,12);
Set_R_C_5110(0,0);
Write_String_5110("20");
Set_R_C_5110(1,54);
Write_String_5110("SET- ");
Set_R_C_5110(2,0);
Write_String_5110("B=00000 b");
Set_R_C_5110(3,0);
Write_String_5110("L=00000 m");
Set_R_C_5110(4,0);
Write_String_5110("S=00.00 m/s");
Set_R_C_5110(5,0);
Write_String_5110("C=00.00 c/kg/h");
void delay_ms(uint n)
uint i,j;
for(i=0;i<n;i++)
for(j=0;j<1000;j++);
*Name: step_counter()
*Function: 實現Pedometer的基本算法.
*Input: void
*Output: void
void step_counter(void)
static uchar sampling_counter=0;
uchar jtemp;
ADXL345_FLAG=0;
Multiple_read_ADXL345(); //連續讀出數據,存儲在BUF中
//------------------------------------------采樣濾波----------------------//
for(jtemp=0;jtemp<=2;jtemp++) //jtemp 0,1,2分別代表x,y,z
array2[jtemp]=array1[jtemp];
array1[jtemp]=array0[jtemp];
array0[jtemp]=BUF[2*jtemp]+(BUF[2*jtemp+1]<<8);
adresult[jtemp]=array0[jtemp]+array1[jtemp]+array2[jtemp];
adresult[jtemp]=adresult[jtemp]/3;
if(adresult[jtemp]>max[jtemp]) {max[jtemp]=adresult[jtemp];}
if(adresult[jtemp]<min[jtemp]) {min[jtemp]=adresult[jtemp];}
sampling_counter=sampling_counter+1;
//----------------------------------計算動態門限和動態精度-----------------------//
if(sampling_counter>=50)
sampling_counter=0;
vpp[jtemp]=max[jtemp]-min[jtemp];
dc[jtemp] =min[jtemp]+(vpp[jtemp]>>1); //dc為閾值
max[jtemp]=0;
min[jtemp]=1023;
bad_flag[jtemp]=0;
if(vpp[jtemp]>=160)
precision[jtemp]=vpp[jtemp]/32; //8
else if((vpp[jtemp]>=50)&& (vpp[jtemp]<160))
precision[jtemp]=4;
else if((vpp[jtemp]>=15) && (vpp[jtemp]<50))
precision[jtemp]=3;
precision[jtemp]=2;
bad_flag[jtemp]=1;
//--------------------------線性移位寄存器--------------------------------------
old_fixed[jtemp]=new_fixed[jtemp];
if(adresult[jtemp]>=new_fixed[jtemp])
if((adresult[jtemp]-new_fixed[jtemp])>=precision[jtemp]) {new_fixed[jtemp]=adresult[jtemp];}
else if(adresult[jtemp]<new_fixed[jtemp])
if((new_fixed[jtemp]-adresult[jtemp])>=precision[jtemp]) {new_fixed[jtemp]=adresult[jtemp];}
//------------------------- 動態門限判決 ----------------------------------
if((vpp[0]>=vpp[1])&&(vpp[0]>=vpp[2])) //x軸最活躍
if((old_fixed[0]>=dc[0])&&(new_fixed[0]<dc[0])&&(bad_flag[0]==0))
STEPS=STEPS+1;
else if((vpp[1]>=vpp[0])&&(vpp[1]>=vpp[2])) //y軸最活躍
if((old_fixed[1]>=dc[1])&&(new_fixed[1]<dc[1])&&(bad_flag[1]==0))
STEPS=STEPS+1;
else if((vpp[2]>=vpp[1])&&(vpp[2]>=vpp[0])) //z軸最活躍
if((old_fixed[2]>=dc[2])&&(new_fixed[2]<dc[2])&&(bad_flag[2]==0))
STEPS=STEPS+1;
//鍵盤掃描
void key_scan(void)
uchar temp=0;
if(K1==0) //功能選擇功能
delay_ms(50);
speak=0;
delay_ms(10);
speak=1;
number++;
if(number>8) number=0;
if(number!=1)
START_FLAG=0;
Write_Char_5110_rc(2,78,'N');
if(number==0) Write_Char_5110_rc(1,78,' ');
else if(number==1) Write_Char_5110_rc(1,78,'J');
else if(number==2) Write_Char_5110_rc(1,78,'S');
else if(number==3) Write_Char_5110_rc(1,78,'M');
else if(number==4) Write_Char_5110_rc(1,78,'H');
else if(number==5) Write_Char_5110_rc(1,78,'W');
else if(number==6) Write_Char_5110_rc(1,78,'D');
else if(number==7) Write_Char_5110_rc(1,78,'Y');
else if(number==8) Write_Char_5110_rc(1,78,'N');
while(K1==0);
if(K2==0) //確定、調節按鍵
delay_ms(50);
switch(number)
case 1: //計步器
if(START_FLAG==1)
START_FLAG=0;
speak=0;
delay_ms(10);
speak=1;
dist=STEPS*0.5; //路程
speed=dist/time; //速度
kalul=1.25*speed*3.6; //卡路里
Write_variable_5110(3,12,dist);
Write_variable_5110_dian(4,12,speed*100);
Write_variable_5110_dian(5,12,kalul*100);
STEPS=0;
time=0;
START_FLAG=1;
speak=0;
delay_ms(10);
speak=1;
Write_Char_5110_rc(2,78,'Y');
Write_variable_5110(3,12,0);
Write_variable_5110_dian(4,12,0);
Write_variable_5110_dian(5,12,0);
break;
case 2:
temp=Read1302(DS1302_SECOND); //讀取秒數
temp=zh(temp);
temp=temp+1; //秒數加1
if(temp>59) //超過59秒,清零
temp=0;
DS1302_SetTime(DS1302_SECOND,temp);
break;
case 3:
temp=Read1302(DS1302_MINUTE); //讀取分數
temp=zh(temp);
temp=temp+1; //分數加1
if(temp>59) //超過59分,清零
temp=0;
DS1302_SetTime(DS1302_MINUTE,temp);
break;
case 4:
temp=Read1302(DS1302_HOUR); //讀取小時數
temp=zh(temp);
temp=temp+1; //小時數加1
if(temp>23) //超過23小時,清零
temp=0;
DS1302_SetTime(DS1302_HOUR,temp);
break;
case 5:
temp=Read1302(DS1302_WEEK); //讀取星期數
temp=zh(temp);
temp=temp+1; //星期數加1
if(temp>7)
temp=1;
DS1302_SetTime(DS1302_WEEK,temp);
break;
case 6:
temp=Read1302(DS1302_DAY); //讀取日數
temp=zh(temp);
temp=temp+1; //日數加1
if(temp>31)
temp=1;
DS1302_SetTime(DS1302_DAY,temp);
break;
case 7:
temp=Read1302(DS1302_MONTH); //讀取月數
temp=zh(temp);
temp=temp+1; //月數加1
if(temp>12)
temp=1;
DS1302_SetTime(DS1302_MONTH,temp);
break;
case 8:
temp=Read1302(DS1302_YEAR); //讀取年數
temp=zh(temp);
temp=temp+1; //年數加1
if(temp>15)
temp=0;
DS1302_SetTime(DS1302_YEAR,temp);
break;
default:break;
while(K2==0);
void main(void)
Init_Device(); //單片機初始化
Init_5110(); //液晶初始化
Clear_5110(); //液晶清屏
Init_ADXL345(); //加速度模塊初始化
Initial_DS1302(); //時鐘芯片初始化
first_picture(); //液晶界面初顯示
//日期顯示開始
get_clock();
show_time();
//日期顯示結束
//鍵盤掃描
key_scan();
//計步器工作
if(ADXL345_FLAG==1 && START_FLAG==1)
ADXL345_FLAG=0;
step_counter();
Write_variable_5110(2,12,STEPS);
void timer0(void) interrupt 1 //約0.02s 進一次中斷
static uchar cnt=0,cnt1=0;
TL0=0X96;
TH0=0Xc3;
cnt++;
cnt1++;
if(cnt>=10)
ADXL345_FLAG=1;
cnt=0;
if(START_FLAG==1)
if(cnt1>=50)
cnt1=0;
time++;
簡單計步器.zip
(106.26 KB, 下載次數: 43)
2018-8-16 10:32 上傳
oohu
2021-4-22 12:00
如何解釋實現Pedometer的基本算法的程序
