標(biāo)題: protues AT89C51 Model AT89 specified but not found in U1_#P.電源還是設(shè)置有問題? [打印本頁] 作者: 1045234683 時間: 2018-8-15 16:58 標(biāo)題: protues AT89C51 Model AT89 specified but not found in U1_#P.電源還是設(shè)置有問題? Model AT89 specified but not found in U1_#P.
V+/V- pins not specified for power interface - check ITFMOD properties. [U1_#P]
