W5500官方驅動源碼 ioLibrary_Driver-master V4.0.0
hange_v
2018-8-3 20:59
W5500官方驅動 ioLibrary_Driver-master
V4.0.0,
2018年3月29日
最新板,下載不容易
(44.74 KB, 下載次數: 67)
2018-8-3 23:49 上傳
#include <stdio.h>
#include "loopback.h"
#include "socket.h"
#include "wizchip_conf.h"
#if LOOPBACK_MODE == LOOPBACK_MAIN_NOBLCOK
int32_t loopback_tcps(uint8_t sn, uint8_t* buf, uint16_t port)
int32_t ret;
uint16_t size = 0, sentsize=0;
#ifdef _LOOPBACK_DEBUG_
uint8_t destip[4];
uint16_t destport;
#endif
switch(getSn_SR(sn))
case SOCK_ESTABLISHED :
if(getSn_IR(sn) & Sn_IR_CON)
getSn_DIPR(sn, destip);
destport = getSn_DPORT(sn);
printf("%d:Connected - %d.%d.%d.%d : %d\r\n",sn, destip[0], destip[1], destip[2], destip[3], destport);
#endif
setSn_IR(sn,Sn_IR_CON);
if((size = getSn_RX_RSR(sn)) > 0) // Don't need to check SOCKERR_BUSY because it doesn't not occur.
if(size > DATA_BUF_SIZE) size = DATA_BUF_SIZE;
ret = recv(sn, buf, size);
if(ret <= 0) return ret; // check SOCKERR_BUSY & SOCKERR_XXX. For showing the occurrence of SOCKERR_BUSY.
size = (uint16_t) ret;
sentsize = 0;
while(size != sentsize)
ret = send(sn, buf+sentsize, size-sentsize);
if(ret < 0)
close(sn);
return ret;
sentsize += ret; // Don't care SOCKERR_BUSY, because it is zero.
break;
case SOCK_CLOSE_WAIT :
//printf("%d:CloseWait\r\n",sn);
#endif
if((ret = disconnect(sn)) != SOCK_OK) return ret;
printf("%d:Socket Closed\r\n", sn);
#endif
break;
case SOCK_INIT :
printf("%d:Listen, TCP server loopback, port [%d]\r\n", sn, port);
#endif
if( (ret = listen(sn)) != SOCK_OK) return ret;
break;
case SOCK_CLOSED:
//printf("%d:TCP server loopback start\r\n",sn);
#endif
if((ret = socket(sn, Sn_MR_TCP, port, 0x00)) != sn) return ret;
//printf("%d:Socket opened\r\n",sn);
#endif
break;
default:
break;
return 1;
int32_t loopback_tcpc(uint8_t sn, uint8_t* buf, uint8_t* destip, uint16_t destport)
int32_t ret; // return value for SOCK_ERRORs
// Destination (TCP Server) IP info (will be connected)
// >> loopback_tcpc() function parameter
// >> Ex)
// uint8_t destip[4] = {192, 168, 0, 214};
// uint16_t destport = 5000;
// Port number for TCP client (will be increased)
static uint16_t any_port = 50000;
// Socket Status Transitions
// Check the W5500 Socket n status register (Sn_SR, The 'Sn_SR' controlled by Sn_CR command or Packet send/recv status)
if(getSn_IR(sn) & Sn_IR_CON) // Socket n interrupt register mask; TCP CON interrupt = connection with peer is successful
printf("%d:Connected to - %d.%d.%d.%d : %d\r\n",sn, destip[0], destip[1], destip[2], destip[3], destport);
#endif
setSn_IR(sn, Sn_IR_CON); // this interrupt should be write the bit cleared to '1'
// Data Transaction Parts; Handle the [data receive and send] process
if((size = getSn_RX_RSR(sn)) > 0) // Sn_RX_RSR: Socket n Received Size Register, Receiving data length
if(size > DATA_BUF_SIZE) size = DATA_BUF_SIZE; // DATA_BUF_SIZE means user defined buffer size (array)
ret = recv(sn, buf, size); // Data Receive process (H/W Rx socket buffer -> User's buffer)
if(ret <= 0) return ret; // If the received data length <= 0, receive failed and process end
sentsize = 0;
// Data sentsize control
ret = send(sn, buf+sentsize, size-sentsize); // Data send process (User's buffer -> Destination through H/W Tx socket buffer)
if(ret < 0) // Send Error occurred (sent data length < 0)
close(sn); // socket close
return ret;
break;
#endif
if((ret=disconnect(sn)) != SOCK_OK) return ret;
#endif
break;
case SOCK_INIT :
printf("%d:Try to connect to the %d.%d.%d.%d : %d\r\n", sn, destip[0], destip[1], destip[2], destip[3], destport);
#endif
if( (ret = connect(sn, destip, destport)) != SOCK_OK) return ret; // Try to TCP connect to the TCP server (destination)
break;
case SOCK_CLOSED:
close(sn);
if((ret=socket(sn, Sn_MR_TCP, any_port++, 0x00)) != sn){
if(any_port == 0xffff) any_port = 50000;
return ret; // TCP socket open with 'any_port' port number
//printf("%d:TCP client loopback start\r\n",sn);
#endif
break;
default:
break;
return 1;
int32_t loopback_udps(uint8_t sn, uint8_t* buf, uint16_t port)
int32_t ret;
uint16_t size, sentsize;
uint8_t destip[4];
uint16_t destport;
case SOCK_UDP :
ret = recvfrom(sn, buf, size, destip, (uint16_t*)&destport);
if(ret <= 0)
printf("%d: recvfrom error. %ld\r\n",sn,ret);
#endif
return ret;
sentsize = 0;
while(sentsize != size)
ret = sendto(sn, buf+sentsize, size-sentsize, destip, destport);
if(ret < 0)
printf("%d: sendto error. %ld\r\n",sn,ret);
#endif
return ret;
break;
case SOCK_CLOSED:
//printf("%d:UDP loopback start\r\n",sn);
#endif
if((ret = socket(sn, Sn_MR_UDP, port, 0x00)) != sn)
return ret;
printf("%d:Opened, UDP loopback, port [%d]\r\n", sn, port);
#endif
break;
default :
break;
return 1;
#endif
W5500官方驅動.zip
(6.07 MB, 下載次數: 82)
2018-8-3 20:57 上傳
