STM32F103正弦逆變輸出源碼與工具 25v,50HZ,頻率可調
teleboy
2018-7-24 14:04
STM32單相正弦逆變
(5.36 KB, 下載次數: 75)
2018-7-24 15:34 上傳
#include "delay.h"
#include "key.h"
#include "sys.h"
#include "SPWM.h"
#include "keyboard.h"
#include "bsp_usart1.h"
#include "OLED_I2C.h"
#include "bsp_i2c_gpio.h"
/*把這個SPWM調一下 6路,其中3路一樣,另外3路一樣,這兩組之間互補
2018/5/10 16:52:06
2018/5/10 16:52:06
死區300ns 載頻20K左右,可以自己定 正弦頻率50HZ 三相正弦之間相差120°
vu8 key = 0; //按鍵值
vu16 freq =20000, Period=0; //PWM與定時器中斷頻率;自動重裝載值
__IO float Period_percent; //PWM占空比變化因子,用于修改脈寬
int k=0;
int BUFF1[4];
int BUFF2[4];
int result;
float Kp = 0.32 ; //比例常數
float Ti = 0.09 ; //積分時間常數
float Td = 0.0028 ; //微分時間常數
#define T 0.02 //采樣周期
#define Ki Kp*(T/Ti) // Kp Ki Kd 三個主要參數
#define Kd Kp*(Td/T)
int main(void)
unsigned char i,j;
unsigned char u[17]={0,1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16};
SystemInit();
NVIC_Configuration();
delay_init();
//USART1_Config();
KeyBoard_Config();
/*KEY_Init(); */
Period_percent = ((SystemCoreClock / freq) - 1) / 32767.0; //0.11s
TIM1_PWM_Init(freq,0); //輸出PWM的頻率為8KHz(一周期400個點,正弦波的頻率為8000/400=20Hz)
TIM2_Int_Init(freq,0); //定時器中斷的頻率為8KHz
if(i2c_CheckDevice(OLED_ADDRESS)==0)
printf("OLED OK\r\n");
OLED_Init();
OLED_Fill(0xFF);//全屏點亮
delay_us(20000);
OLED_Fill(0x00);//全屏滅
delay_us(20000);
//PID_set(Kp,Ki,Kd);
i=Read_KeyValue();
if (i>0)
j = u[i-1];
switch(j)
case 0:
OLED_ShowStr(0,4,(unsigned char*)"Hello 1 ",2); //測試8*16字符
BUFF1[k]=1;
k++;
break;
case 1:
OLED_ShowStr(0,4,(unsigned char*)"Hello 2 ",2); //測試8*16字符
BUFF1[k]=2;
k++;
break;
case 2:
OLED_ShowStr(0,4,(unsigned char*)"Hello 3 ",2); //測試8*16字符
BUFF1[k]=3;
k++;
break;
case 3:
OLED_ShowStr(0,4,(unsigned char*)"Hello 4 ",2); //測試8*16字符
BUFF1[k]=4;
k++;
break;
case 4:
OLED_ShowStr(0,4,(unsigned char*)"Hello 5 ",2); //測試8*16字符
BUFF1[k]=5;
k++;
break;
case 5:
OLED_ShowStr(0,4,(unsigned char*)"Hello 6 ",2); //測試8*16字符
BUFF1[k]=6;
k++;
break;
case 6:
OLED_ShowStr(0,4,(unsigned char*)"Hello 7 ",2); //測試8*16字符
BUFF1[k]=7;
k++;
break;
case 7:
OLED_ShowStr(0,4,(unsigned char*)"Hello 8 ",2); //測試8*16字符
BUFF1[k]=8;
k++;
break;
case 8:
OLED_ShowStr(0,4,(unsigned char*)"Hello 9 ",2); //測試8*16字符
BUFF1[k]=9;
k++;
break;
case 9:
OLED_ShowStr(0,4,(unsigned char*)"Hello 10 ",2); //測試8*16字符
BUFF1[k]=0;
k++;
break;
case 10:
OLED_ShowStr(0,4,(unsigned char*)"Hello 11 ",2); //測試8*16字符
break;
// case 11:
// OLED_ShowStr(0,4,(unsigned char*)"Hello 12 ",2); //測試8*16字符
// break;
// case 12:
// OLED_ShowStr(0,4,(unsigned char*)"Hello 13 ",2); //測試8*16字符
// break;
// case 13:
// OLED_ShowStr(0,4,(unsigned char*)"Hello 14 ",2); //測試8*16字符
// break;
// case 14:
// OLED_ShowStr(0,4,(unsigned char*)"Hello 15 ",2); //測試8*16字符
// break;
// case 15:
// OLED_ShowStr(0,4,(unsigned char*)"Hello 16 ",2); //測試8*16字符
// break;
/* case 16:
LED1_TOGGLE;
OLED_ShowStr(0,4,(unsigned char*)"Hello g ",2); //測試8*16字符
break; */
default:
OLED_ShowStr(0,4,(unsigned char*)"no key ",2); //測試8*16字符
/* key=KEY_Scan(0);
if(key == 1 )
freq += 400; //sin頻率 = freq/400
Period = (SystemCoreClock / freq) - 1; //算出自動重裝載值,Tout(溢出時間)= ((arr+1)*(psc+1))/Tclk= 1/freq;
TIM1->ARR = Period;
TIM2->ARR = Period;
Period_percent = Period / 32767.0;
else if(key == 2)
freq -= 400;
TIM1->ARR = Period;
TIM2->ARR = Period;
STM32F103正弦逆變輸出25v,50HZ,頻率可調.rar
(380.72 KB, 下載次數: 90)
2018-7-24 15:34 上傳
STM32正弦逆變輸出25V 50hz
oliverlau2k11
2018-8-23 10:53
好東西,贊一個
