TM1638驅動數碼管的arduino和51單片機源程序與電路圖
475463351
2018-7-21 14:47
TM1638數碼管電路原理圖如下:
(74.13 KB, 下載次數: 140)
2018-7-21 17:35 上傳
#include <REGX51.H>
#include <tm1638.h>
unsigned char num[8]; //各個數碼管顯示的值
int main(void)
unsigned char i;
init_TM1638(); //初始化TM1638
for(i=0;i<8;i++)
Write_DATA(i<<1,tab[0]); //初始化寄存器
i=Read_key(); //讀按鍵值
if(i<8)
num[i]++;
while(Read_key()==i); //等待按鍵釋放
if(num[i]>15)
num[i]=0;
Write_DATA(i*2,tab[num[i]]);
Write_allLED(1<<i);
arduino源程序:
#define DATA_COMMAND 0X40
#define DISP_COMMAND 0x80
#define ADDR_COMMAND 0XC0
//TM1638模塊引腳定義
int DIO = 2;
int CLK = 1;
int STB = 0; //這里定義了那三個腳
//共陰數碼管顯示代碼
unsigned char tab[]={0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,
0x7F,0x6F,0x77,0x7C,0x39,0x5E,0x79,0x71};
void setup ()
pinMode(STB,OUTPUT);
pinMode(CLK,OUTPUT);
pinMode(DIO,OUTPUT); //讓三個腳都是輸出狀態
void loop()
unsigned char i;
for(i=0;i<8;i++)
if(i<8)
num[i]++;
while(i==Read_key()); //等待按鍵釋放
if(num[i]>15)
num[i]=0;
Write_allLED(1<<i);
void TM1638_Write(unsigned char DATA) //寫數據函數
unsigned char i;
for(i=0;i<8;i++)
digitalWrite(CLK,LOW);
if(DATA&0X01)
digitalWrite(DIO,HIGH);
digitalWrite(DIO,LOW);
DATA>>=1;
digitalWrite(CLK,HIGH);
unsigned char TM1638_Read(void) //讀數據函數
unsigned char i;
unsigned char temp=0;;
pinMode(DIO,INPUT);//設置為輸入
for(i=0;i<8;i++)
temp>>=1;
if(digitalRead(DIO)==HIGH)
temp|=0x80;
return temp;
void Write_COM(unsigned char cmd) //發送命令字
digitalWrite(STB,LOW);
TM1638_Write(cmd);
digitalWrite(STB,HIGH);
unsigned char Read_key(void)
unsigned char c[4],i,key_value=0;
TM1638_Write(0x42); //讀鍵掃數據 命令
for(i=0;i<4;i++)
c[i]=TM1638_Read();
digitalWrite(STB,HIGH); //4個字節數據合成一個字節
for(i=0;i<4;i++)
key_value|=c[i]<<i;
for(i=0;i<8;i++)
if((0x01<<i)==key_value)
break;
return i;
void Write_DATA(unsigned char add,unsigned char DATA) //指定地址寫入數據
Write_COM(0x44);
TM1638_Write(0xc0|add);
TM1638_Write(DATA);
void Write_allLED(unsigned char LED_flag) //控制全部LED函數,LED_flag表示各個LED狀態
unsigned char i;
for(i=0;i<8;i++)
if(LED_flag&(1<<i))
Write_DATA(2*i+1,1);
Write_DATA(2*i+1,0);
//TM1638初始化函數
void init_TM1638(void)
unsigned char i;
Write_COM(0x8b); //亮度 (0x88-0x8f)8級亮度可調
Write_COM(0x40); //采用地址自動加1
digitalWrite(STB,LOW); //
TM1638_Write(0xc0); //設置起始地址
for(i=0;i<16;i++) //傳送16個字節的數據
TM1638_Write(0x00);
TM1638 按鍵數碼管LED顯示模塊(8位數碼管LED按鍵) 顯示模塊.zip
(961.32 KB, 下載次數: 199)
2018-7-21 14:47 上傳
TM1638驅動程序51
zheng113001
2019-7-26 17:16
謝謝分享
zheng113001
2019-7-26 17:17
謝謝分享。。
H818488842839
2019-7-27 09:43
按鍵不行啊
zxy2266
2019-7-30 12:20
我買模塊好久了,正需要這程序
Ω囿圉Ω
2019-7-31 17:24
學習一下,謝謝分享。
lxr12
2019-8-21 19:31
天微的驅動芯片用的人比較多
stlong
2019-9-19 08:43
感謝樓主的貢獻!
chenwbs
2020-1-20 16:05
非常感謝分享~~~~~~~~~~~~~~
xjlfh
2024-4-15 17:07
謝謝分享,實測可用。
zxy2266
2025-6-9 16:31
發表于 2019-7-30 12:20
我買模塊好久了,正需要這程序
哈哈 好多年了 ,還沒搞明白
