標(biāo)題: 編譯總出現(xiàn)計(jì)C(4): error C129: missing ';' before 'sfr'這個(gè)錯(cuò)誤,這是什么情況啊 [打印本頁]
作者: a164188    時(shí)間: 2018-7-19 02:07
#include<reg52.h>
#include"lcd1602.h"
unsigned char        print
sfr T2MOD = 0x0c9;
sbit Q0 = P2^4;
sbit Q1 = P2^5;
sbit Q2 = P2^6;
sbit Q3 = P2^7;
sbit PWM                 = P1^7;
sbit UP                         = P1^0;
sbit DOWM                 = P1^1;
sbit GORB                = P2^3; //換相
sbit ADDSPEED         = P1^2;
sbit SUBSPEED        = P1^3;
uint tuint = 65535;
uint tpwm = 1;        //pwm周期為10000us tpwm變量表示pwm高電平時(shí)間,也相當(dāng)于占空比 (仿真時(shí),頻率高時(shí),電機(jī)反應(yīng)慢。在實(shí)物上要加大頻率)
uchar t1_flag = 0;
uint pulse = 0;
uint t0_flag = 0;
uchar t2_flag = 0;
bit t2_over = 0;
bit Just_Get = 1;
#define         ZZ                 { Q0 = 0;Q1 = 0;Q2 = 1;Q3 = 1;}        //正轉(zhuǎn)
#define         FZ                 { Q0 = 1;Q1 = 1;Q2 = 0;Q3 = 0;}        //反轉(zhuǎn)
#define         STOP        { Q0 = 1;Q1 = 0;Q2 = 1;Q3 = 0;}        //停止
//禁止出現(xiàn) Q0 = 0;Q1 = 1;Q2 = 0;Q3 = 1; 不然會(huì)燒掉mos管
//************************ PID *************************************
float now = 0,bef = 0,bbef = 0;         //本次采樣值,上次采樣值,上上次采樣值
float err_now,err_bef,err_bbef;                //當(dāng)前偏差,上次偏差,上上次偏差
float error_add = 0;                                //所有偏差之和
float set = 25;                                                //設(shè)定值
float kp = 25;
float ki = 25;
float kd = 0;
void delayms(uint ms)//延時(shí)?個(gè) ms
    uchar a,b,c;
        while(ms--)
          for(c=1;c>0;c--)
        for(b=142;b>0;b--)
            for(a=2;a>0;a--);
void timer_init()
        EA = 1;
        ET0 = 1;
        ET1 = 1;
        ET2 = 1;
        TMOD = 0x15; //定時(shí)器0 計(jì)數(shù)模式 定時(shí)器1模式1
        T2MOD = 0x01;
        TH0 = TL0 = 255;
        TH2 = 0x3C;
        TL2 = 0xB0;                //50MS
void timer1() interrupt 3
        if(t1_flag == 0)
                t1_flag = 1;
                PWM = 1;
                TH1 = (tuint - tpwm + 1)/256;
                TL1 = (tuint - tpwm + 1)%256;
                t1_flag = 0;
                PWM = 0;
                TH1 = (tuint - 10000 + tpwm + 1)/256;
                TL1 = (tuint - 10000 + tpwm + 1)%256;
void timer0() interrupt 1
        TH0 = TL0 = 255;
        t0_flag++;
void timer2() interrupt 5
        TF2 = 0;
        TH2 = 0x3C;
        TL2 = 0xB0;                //50MS
        t2_flag++;
        if(t2_flag == 2)
                TR0 = 0;
                TR2 = 0;
                t2_flag = 0;
                t2_over = 1;        //表示100ms時(shí)間到
void GetPulse()
        t0_flag = 0;
        t2_flag = 0;
        TH0 = TL0 = 255;
        TH2 = 0x3C;
        TL2 = 0xB0;                //50MS
        TR0 = 1;
        TR2 = 1;
int PID()        //增量式PID
        int change;
        err_now = set - now;
        err_bef = set - bef;
        err_bbef = set - bbef;
        change = kp*(err_now - err_bef) + ki*err_now + kd*(err_now - 2*err_bef + err_bbef);
        if(set >= now)
                if(set - now > 1)
                        change = 0.2*kp*(err_now - err_bef) + 0.5*ki*err_now + kd*(err_now - 2*err_bef + err_bbef);
        else if(now > set)
                if(now - set > 1)
        //change = (kp + ki + kd)*(set - now) + (-kp - 2*kd)*(set - bef) + kd*(set - bbef);
        //change = kp*(set - now) + ki*(set - bef) + kd*(set - bbef);
        if(change > 0)
                printchar(1,10,'+');
                printuint(1,11,4,change);
        else if(change < 0)
                printchar(1,10,'-');
                printuint(1,11,4,-change);
        else if(change == 0)
                printchar(1,10,' ');
                printword(1,11," 0  ");
        return(change);
int PID2()                //位置式PID
        int num = 0;
        static num_bef = 0;
        error_add = error_add + err_now;  //誤差累加。一旦誤差為0則error_add的值不變,PID輸出值不變
        num = kp*err_now + ki*error_add + kd*(err_now - err_bef);
        if(set - now >= 0)
                if(set - now > 1)
                        num = 0.1*kp*err_now + ki*error_add + kd*(err_now - err_bef);
                if(now - set > 1)
        if(num > num_bef)
                printuint(1,11,4,num - num_bef);
        else if(num < num_bef)
                printuint(1,11,4,num_bef - num);
                printuint(1,11,4,0);
        num_bef = num;
        return((uint)num);
        lcd_init();
        timer_init();
        TH1 = TL1 = 255;
        printword(0,0,"P:");                //比例系數(shù)
        printword(0,5,"S:");                //設(shè)定值
        printword(1,0,"TPWM:");                //當(dāng)前占空比
        printword(0,10,"PS:");                //當(dāng)前電機(jī)反饋的每秒脈沖數(shù)
                if(GORB == 1)
                {        ZZ;                }
                {        FZ;                }
                if(ADDSPEED == 0)
                        set++;
                if(SUBSPEED == 0)
                        set--;
                if(Just_Get == 1)
                        Just_Get = 0;
                        GetPulse();
                else if(t2_over == 1)
                        t2_over = 0;
                        Just_Get = 1;
                        pulse = t0_flag;
                        bbef = bef;
                        bef = now;
                        now = t0_flag;
                        if(set != 0)
                                TR1 = 1;
                                TR1 = 0;
                                PWM = 0;
                //        tpwm = tpwm + PID();                //增量式PID
                        tpwm = PID2();                                //位置式PID
                if(UP == 0)
                        kp = kp + 1;
                if(DOWM == 0)
                        kp = kp - 1;
                printuint(0,2,3,kp);
                printuint(0,7,3,set);
                printuint(1,5,4,tpwm);
                printuint(0,13,5,pulse);
作者: a164188    時(shí)間: 2018-7-19 02:08
急急急  求各位大神幫忙看一下
作者: wulin    時(shí)間: 2018-7-19 07:35
unsigned char print;  這里少了分號(hào)。
作者: panzishi123456    時(shí)間: 2018-7-19 07:36
在哪行少打了分號(hào)‘;’
作者: 2895659127    時(shí)間: 2018-7-19 08:28
有少分號(hào)的地方
作者: HC6800-ES-V2.0    時(shí)間: 2018-7-19 08:29
錯(cuò)誤第一:第三行少了一個(gè)分號(hào)
錯(cuò)誤第二:第四行是多余的,因?yàn)槟愕膔eg52.h頭文件中已經(jīng)申明。
作者: huaxinnan    時(shí)間: 2018-7-19 08:44
unsigned char        print      你這是在定義一個(gè)變量   不是宏定義   語句結(jié)束需要分號(hào)。
作者: CY1994    時(shí)間: 2018-7-19 09:48
首先你的第三行 unsigned char print 沒有分號(hào);
其次你的特殊功能寄存器的使用(sfr )T2MOD,參考reg2.h頭文件里面的定義、
從錯(cuò)誤來看,僅僅是第三行少了個(gè)分號(hào)
作者: STC89C51    時(shí)間: 2018-7-19 12:15
第三行少分號(hào)。
作者: 364611194    時(shí)間: 2018-7-19 13:38
unsigned char        print  定義少了個(gè) ';'
作者: coolsun    時(shí)間: 2018-7-19 14:02
STC89C51 發(fā)表于 2018-7-19 12:15
第三行少分號(hào)。
unsigned char print 后面少分號(hào),你把print當(dāng)作定義的變量,后面自然要加分號(hào)
作者: coolsun    時(shí)間: 2018-7-19 14:03
第三行定義變量時(shí)要加分號(hào)
作者: 18789007389    時(shí)間: 2018-7-19 14:39
第三句少了一個(gè)分號(hào)
作者: lanyu8388    時(shí)間: 2018-7-20 00:02
unsigned char print  少了個(gè);分號(hào)。雙擊錯(cuò)信息提示,跳到對(duì)應(yīng)行很上找,就可以找到問題,提示中before 'sfr' j 已經(jīng)說明了在sfr的前面出錯(cuò)。
作者: 15873002171    時(shí)間: 2018-7-20 08:48
unsigned char        print這句沒有分號(hào),定義變量都是要分號(hào)的
作者: 關(guān)外秀才    時(shí)間: 2018-7-20 08:55
編譯錯(cuò)誤已經(jīng)提示你了,在這個(gè)語句完成后要加一個(gè)“;”號(hào)。
作者: dzsj1    時(shí)間: 2018-7-20 09:12
print后面少了分號(hào)啊
作者: zhaoyinlo    時(shí)間: 2018-9-4 16:02
unsigned char        print   //第三行   后面少個(gè)分號(hào)
加油
作者: zmc419    時(shí)間: 2018-9-4 20:51
keil會(huì)指示出位置,提示是少了;       可分段注釋掉找到問題。
