標題: 樓道燈的聲光控 [打印本頁]
作者: cityone    時間: 2018-7-7 14:47
標題: 樓道燈的聲光控
#include <reg52.h>                 //μ÷óÃμ¥Ƭ»úí·Îļt
#define uchar unsigned char  //ÎT·ûoÅ×Ö·ûDí o궨òå        ±äá¿·¶Î§0~255
#define uint  unsigned int         //ÎT·ûoÅÕûDí o궨òå        ±äá¿·¶Î§0~65535
sbit GM=P1^0;        //1aÃô
sbit shengyin=P1^4;        //éùòô
sbit relay=P3^4;        //¼ìμçÆ÷¿ØÖÆμÆ
μçλÆ÷íùóòμ÷ 1aÃô′«¸DÆ÷μÄáéÃô¶èÔö¼ó
void delay_1ms(uint x)//Ñóê±oˉêy
        uint i,j;
        for(i=0;i<x;i++)
        for(j=0;j<120;j++);
void work()//1¤×÷oˉêy
        static uint value,miao;
        if(GM==0)//1aÃô£¨ííéÏ£©
                delay_1ms(1);//Ñóê±1ms
                if(GM==0)//è·¶¨êÇííéÏ
                        if(shengyin==0)//óDéùòô
                                relay=0;//¼ìμçÆ÷ÎüoÏ
                                miao = 0;
                                value = 0;
        if(relay == 0)    //¼ìμçÆ÷ÎüoÏ ¼Æê±10Ãë
                value ++;
                if(value >= 1000)
                        value = 0;
                        miao ++;
                        if(miao >= 10)          //10ÃëμÄê±¼ä
                                miao = 0;
                                relay = 1;    //1رռìμçÆ÷
void main()//Ö÷oˉêy
        while(1)//Ñ-»·
                work();//μ÷óÃ1¤×÷oˉêy
                delay_1ms(1);   //1ms
