標題: 求測熱敏電阻的阻值 [打印本頁]
作者: 12558222080    時間: 2018-7-3 17:02
標題: 求測熱敏電阻的阻值
把led顯示改為6位,并把顯示溫度改為熱敏電阻的阻值程序:
#include<reg51.h>
#include <intrins.h>
#define Disdata P3
#define discan P0
sbit adrd=P2^7;          //IO¿ú¶¨òå
sbit adwr=P2^6;
sbit csad=P2^4;
sbit  DIN=P3^7;       //LEDD¡êyμã¿ØÖÆ
unsigned char j,k,ad_data,t;
unsigned char dis[4]={0x00,0x00,0x00,0x00};
unsigned char code dis_7[12]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x77,0x40};
/* 12ÑôLED¶ÎÂë±í¶Ôó|           "0"  "1"  "2"  "3"  "4"  "5"  "6"  "7"  "8"  "9" "2»áá" "-" */
unsigned char code  scan_con[4]={0xfe,0xfd,0xfb,0xf7};      // áDé¨Ãè¿ØÖÆ×Ö
void delay(unsigned int t)
  for(;t>0;t--)
}  //11΢ÃëÑóê±oˉêy
void scan()
   char k;
   for(k=0;k<4;k++)        //ËÄλLEDé¨Ãè¿ØÖÆ
     Disdata=dis_7[dis[k]];
         if(k==1)
           DIN=1;                                  //¼óèëD¡êyμã
         discan=scan_con[k];
         delay(90);
         discan=0xff;
void ad0804()
  P1=0xff;              //¶áè¡P1¿ú֮ǰÏè¸øÆäD′è«1
  csad=0;               //Ñ¡í¨ADCS
  adrd=0;               //AD¶áê1Äü
  ad_data=P1;                        //ADêy¾Y¶á衸3¸øP1¿ú
  adrd=1;
  csad=1;               //1رÕADCS
  adwr=0;
void ad_compute()       //u=2.55+T/100, 2.55·′ó3ÔúADéÏÎa0x83
  unsigned char t_temp;
  //if(ad_data>=0x83)
    ad_data=ad_data-0x83;
    t_temp=ad_data*2-4;
        if(t_temp<=110)
         dis[3]=t_temp/100;
         dis[2]=t_temp/10-dis[3]*10;
         dis[1]=t_temp%10;
         dis[0]=t%5*2;
          t_temp=256-t_temp;
      dis[3]=11;
      dis[2]=t_temp/10;
      dis[1]=t_temp%10;
      dis[0]=t%5*2;
void main()                //        Ö÷3ìDò
    ad0804();
        ad_compute();
        scan();
改成測熱敏電阻的阻值并用六位LED顯示
作者: 675315461    時間: 2018-7-3 19:32
同求同求
