單片機兩位電子秒表源碼+仿真
3510
2018-6-27 23:00
單片機兩位電子秒表源碼+仿真
兩位電子秒表
(20.4 KB, 下載次數: 70)
2018-6-28 04:10 上傳
(45.78 KB, 下載次數: 61)
2018-6-28 04:10 上傳
#include<reg51.h>
sbit K1 = P3^7;
uchar i,s=0,Key_Flag_Idx=0,shi=0,ge=0;
bit Key_State;
uchar DSY_CODE[]=
0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f
void DelayMS(uint ms)
uchar t;
while(ms--)
for(t=0;t<120;t++);
void qidong()
for(i=1;i<=10;i++)
{DelayMS(100);
if(Key_State != K1)
DelayMS(10);
Key_State = K1;
if(Key_State == 0)
Key_Flag_Idx=(Key_Flag_Idx+1)%3;
return;
ge=(ge+1)%10;
if(ge==0)shi=shi+1;
if(shi==6)shi=0;
void zhanting()
while(Key_Flag_Idx==2)
{if(Key_State != K1)
DelayMS(10);
Key_State = K1;
if(Key_State == 0)
Key_Flag_Idx=(Key_Flag_Idx+1)%3;return;
P0 = 0x3f;
P2 = 0x3f;
Key_State = 1; //P3.7引腳的初始狀態為1
if(Key_State != K1)//若P3.7引腳值有變化,其中K1為P3.7引腳值
DelayMS(10);//消抖
Key_State = K1; //將當前P3.7值賦給Key_State變量
if(Key_State == 0) //若當前P3.7值為0,即若有按鍵按下
Key_Flag_Idx=(Key_Flag_Idx+1)%3; //按鍵按下次數為...
switch(Key_Flag_Idx)
case 1:qidong();break;
case 2:zhanting();break;
case 0:shi=0;ge=0;
P0 = DSY_CODE[shi];
P2 = DSY_CODE[ge];
秒表.zip
(57.24 KB, 下載次數: 23)
2018-6-27 23:00 上傳
簡單的電子秒表
