標題: 按鍵 [打印本頁]
作者: 1628762424    時間: 2018-6-26 22:06
標題: 按鍵
#include <reg52.h>
sbit KEY_IN_1  = P2^4;
sbit KEY_IN_2  = P2^5;
sbit KEY_IN_3  = P2^6;
sbit KEY_IN_4  = P2^7;
sbit KEY_OUT_1 = P2^3;
sbit KEY_OUT_2 = P2^2;
sbit KEY_OUT_3 = P2^1;
sbit KEY_OUT_4 = P2^0;
unsigned char code KeyCodeMap[4][4] = { //矩陣按鍵編號到標準鍵盤鍵碼的映射表
    { '1',  '2',  '3', 0x26 }, //數字鍵1、數字鍵2、數字鍵3、向上鍵
    { '4',  '5',  '6', 0x25 }, //數字鍵4、數字鍵5、數字鍵6、向左鍵
    { '7',  '8',  '9', 0x28 }, //數字鍵7、數字鍵8、數字鍵9、向下鍵
    { '0', 0x1B, 0x0D, 0x27 }  //數字鍵0、ESC鍵、  回車鍵、 向右鍵
unsigned char pdata KeySta[4][4] = {  //全部矩陣按鍵的當前狀態
    {1, 1, 1, 1},  {1, 1, 1, 1},  {1, 1, 1, 1},  {1, 1, 1, 1}
extern void Reset();
extern void GetResult();
extern void NumKeyAction(unsigned char n);
extern void OprtKeyAction(unsigned char type);
extern void LcdShowStr(unsigned char x, unsigned char y, unsigned char *str);
void KeyAction(unsigned char keycode)
        if((keycode >= '0') && (keycode <= '9'))
                NumKeyAction(keycode - '0');
        else if(keycode == 0x26)
                OprtKeyAction(0);
        else if(keycode == 0x28)
                OprtKeyAction(1);
        else if(keycode == 0x25)
                OprtKeyAction(2);
        else if(keycode == 0x27)
                OprtKeyAction(3);
        else if(keycode == 0x0D)
                GetResult();
        else if(keycode == 0x1B)
                Reset();
                LcdShowStr(15, 1, "0");
/* 按鍵驅動函數,檢測按鍵動作,調度相應動作函數,需在主循環中調用 */
void KeyDriver()
    unsigned char i, j;
    static unsigned char pdata backup[4][4] = {  //按鍵值備份,保存前一次的值
    for (i=0; i<4; i++)  //循環檢測4*4的矩陣按鍵
        for (j=0; j<4; j++)
            if (backup[i][j] != KeySta[i][j])    //檢測按鍵動作
                if (backup[i][j] != 0)           //按鍵按下時執行動作
                    KeyAction(KeyCodeMap[i][j]); //調用按鍵動作函數
                backup[i][j] = KeySta[i][j];     //刷新前一次的備份值
/* 按鍵掃描函數,需在定時中斷中調用,推薦調用間隔1ms */
void KeyScan()
    unsigned char i;
    static unsigned char keyout = 0;   //矩陣按鍵掃描輸出索引
    static unsigned char keybuf[4][4] = {  //矩陣按鍵掃描緩沖區
        {0xFF, 0xFF, 0xFF, 0xFF},  {0xFF, 0xFF, 0xFF, 0xFF},
    //將一行的4個按鍵值移入緩沖區
    keybuf[keyout][0] = (keybuf[keyout][0] << 1) | KEY_IN_1;
    keybuf[keyout][1] = (keybuf[keyout][1] << 1) | KEY_IN_2;
    keybuf[keyout][2] = (keybuf[keyout][2] << 1) | KEY_IN_3;
    keybuf[keyout][3] = (keybuf[keyout][3] << 1) | KEY_IN_4;
    //消抖后更新按鍵狀態
    for (i=0; i<4; i++)  //每行4個按鍵,所以循環4次
        if ((keybuf[keyout][i] & 0x0F) == 0x00)
        {   //連續4次掃描值為0,即4*4ms內都是按下狀態時,可認為按鍵已穩定的按下
            KeySta[keyout][i] = 0;
        else if ((keybuf[keyout][i] & 0x0F) == 0x0F)
        {   //連續4次掃描值為1,即4*4ms內都是彈起狀態時,可認為按鍵已穩定的彈起
            KeySta[keyout][i] = 1;
    //執行下一次的掃描輸出
    keyout++;         //輸出索引遞增
    keyout &= 0x03;   //索引值加到4即歸零
    switch (keyout)   //根據索引,釋放當前輸出引腳,拉低下次的輸出引腳
        case 0: KEY_OUT_4 = 1; KEY_OUT_1 = 0; break;
        case 1: KEY_OUT_1 = 1; KEY_OUT_2 = 0; break;
        case 2: KEY_OUT_2 = 1; KEY_OUT_3 = 0; break;
        case 3: KEY_OUT_3 = 1; KEY_OUT_4 = 0; break;
        default: break;
