標題: 如何用ESP8266做一個天氣預報 [打印本頁]
作者: lsalp 時間: 2018-6-15 17:26
1、硬件
用一個四博智聯提供的nodemcu。一個OLED屏,一個USB線,4根杜邦線,可以上網的路由器,電腦。
2018-6-16 04:17 上傳
3V3---VCC
GND---GND
GPIO4(D2)---SDA
GPIO5(D1)---SCL
2、設置路由器
把路由器賬號設置為把路由器賬號設置為
賬號:xh003
密碼:zxd+19901120=
3、燒錄程序
打開ESP_TOOLS下載工具,選擇8266.
2018-6-16 04:17 上傳
點擊START.等待燒錄完成。
燒錄完成后復位一下nodemcu。等待10s左右。
測試結果如下:
2018-6-16 04:17 上傳
2018-6-16 04:17 上傳
Arduino代碼如下:
#include
#include
#include
#include "OLED.h"
static const char logo[] PROGMEM={
0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0x7f,
0xff,0xff,0xff,0xff,0xff,0xff,0x7f,0x80,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0x7f,
0xff,0xff,0xff,0xff,0xff,0xff,0x03,0x00,0xf0,0xff,0xff,0xff,0xff,0xff,0xff,0x7f,
0xff,0xff,0xff,0xff,0xff,0x7f,0x00,0x00,0x80,0xff,0xff,0xff,0xff,0xff,0xff,0x7f,
0xff,0xff,0xff,0xff,0xff,0x0f,0x00,0x00,0x00,0xfe,0xff,0xff,0xff,0xff,0xff,0x7f,
0xff,0xff,0xff,0xff,0xff,0x03,0x00,0x00,0x00,0xf8,0xff,0xff,0xff,0xff,0xff,0x7f,
0xff,0xff,0xff,0xff,0xff,0xe0,0xff,0x03,0x00,0xe0,0xff,0xff,0xff,0xff,0xff,0x7f,
0xff,0xff,0xff,0xff,0x1f,0x1c,0xf0,0x1f,0x00,0x80,0xff,0xff,0xff,0xff,0xff,0x7f,
0xff,0xff,0xff,0xff,0x0f,0x00,0x80,0x7f,0x00,0x00,0xff,0xff,0xff,0xff,0xff,0x7f,
0xff,0xff,0xff,0xff,0x0f,0x00,0x00,0xff,0x01,0x00,0xfc,0xff,0xff,0xff,0xff,0x7f,
0xff,0xff,0xff,0xff,0x07,0x00,0x00,0xfe,0x03,0x00,0xf8,0xff,0xff,0xff,0xff,0x7f,
0xff,0xff,0xff,0xff,0x03,0x00,0x00,0xfc,0x07,0x00,0xf8,0xff,0xff,0xff,0xff,0x7f,
0xff,0xff,0xff,0xff,0x01,0x00,0x00,0xf8,0x0f,0x00,0xf0,0xff,0xff,0xff,0xff,0x7f,
0xff,0xff,0xff,0xff,0x00,0x00,0x00,0xf0,0x1f,0x00,0xf0,0xff,0xff,0xff,0xff,0x7f,
0xff,0xff,0xff,0x3f,0x00,0x00,0x00,0xf0,0x1f,0x00,0xf0,0xff,0xff,0xff,0xff,0x7f,
0xff,0xff,0xff,0x1f,0x00,0x00,0x00,0xf0,0x1f,0x00,0xf0,0xff,0xff,0xff,0xff,0x7f,
0xff,0xff,0xff,0x0f,0x00,0x00,0x00,0xf0,0x3f,0x00,0xf0,0xff,0xff,0xff,0xff,0x7f,
0xff,0xff,0xff,0x07,0x00,0x00,0x00,0xf0,0x1f,0x00,0xf8,0xff,0xff,0xff,0xff,0x7f,
0xff,0xff,0xff,0x07,0x00,0x00,0x00,0xf0,0x0f,0x00,0xf8,0xff,0xff,0xff,0xff,0x7f,
0xff,0xff,0xff,0x03,0x00,0x00,0x00,0xf8,0x03,0x00,0xfc,0xff,0xff,0xff,0xff,0x7f,
0xff,0xff,0xff,0x01,0x00,0x00,0x00,0xfc,0x00,0x00,0x7e,0xff,0xff,0xff,0xff,0x7f,
0xff,0xff,0xff,0x01,0x00,0x00,0x00,0x7f,0x00,0x00,0x7f,0xf8,0xff,0xff,0xff,0x7f,
0xff,0xff,0xff,0x00,0x00,0x00,0x80,0x1f,0x00,0x80,0x7f,0xf8,0xff,0xff,0xff,0x7f,
0xff,0xff,0xff,0x00,0x00,0x00,0xe0,0x07,0x00,0xc0,0x3f,0xf0,0xff,0xff,0xff,0x7f,
0xff,0xff,0xff,0x00,0x00,0x00,0xf8,0x01,0x00,0xe0,0x3f,0xf0,0xff,0xff,0xff,0x7f,
0xff,0xff,0x7f,0x00,0x00,0x00,0x7f,0x00,0x00,0xf8,0x3f,0xf0,0xff,0xff,0xff,0x7f,
0xff,0xff,0x7f,0x00,0x00,0xe0,0x1f,0x00,0x00,0xfe,0x0f,0xf0,0xff,0xff,0xff,0x7f,
0xff,0xff,0x7f,0x00,0x00,0xf8,0x03,0x00,0x80,0xff,0x0f,0xf8,0xff,0xff,0xff,0x7f,
0xff,0xff,0x7f,0x00,0x00,0x7e,0x00,0x00,0xe0,0xff,0x01,0xf0,0xff,0xff,0xff,0x7f,
0xff,0xff,0x7f,0x00,0x00,0x1f,0x00,0x00,0xf8,0xff,0x00,0xf8,0xff,0xff,0xff,0x7f,
0xff,0xff,0x7f,0x00,0xc0,0x0f,0x00,0x00,0xfe,0x7f,0x00,0xfc,0xff,0xff,0xff,0x7f,
0xff,0xff,0x7f,0x00,0xe0,0x03,0x00,0x80,0xff,0x1f,0x00,0xfe,0xff,0xff,0xff,0x7f,
0xff,0xff,0x7f,0x00,0xf8,0x01,0x00,0xe0,0xff,0x07,0x00,0xfe,0xff,0xff,0xff,0x7f,
0xff,0xff,0x7f,0x00,0x7c,0x00,0x00,0xfc,0xff,0x00,0x00,0xfc,0xff,0xff,0xff,0x7f,
0xff,0xff,0x7f,0x00,0x3e,0x00,0x00,0xff,0x07,0x00,0x00,0xfc,0xff,0xff,0xff,0x7f,
0xff,0xff,0x7f,0x00,0x0f,0x00,0xc0,0xff,0x07,0x00,0x00,0xff,0xff,0xff,0xff,0x7f,
0xff,0xff,0xff,0x80,0x07,0x00,0xf0,0xff,0xff,0x0f,0xc0,0xff,0xff,0xff,0xff,0x7f,
0xff,0xff,0xff,0xc0,0x03,0x00,0xf8,0xff,0xff,0x3f,0xf8,0xff,0xff,0xff,0xff,0x7f,
0xff,0xff,0xff,0xc0,0x01,0x00,0xfe,0xf8,0xc7,0xff,0xff,0xff,0xff,0xff,0xff,0x7f,
0xff,0xff,0xff,0xe1,0x01,0x00,0x7f,0xc0,0x03,0x87,0x00,0xfe,0xff,0xff,0xff,0x7f,
0xff,0xff,0xff,0xe1,0x00,0xc0,0x7f,0x80,0x01,0x86,0x00,0xfe,0xff,0xff,0xff,0x7f,
0xff,0xff,0xff,0x63,0x00,0xe0,0x7f,0x80,0x01,0x86,0x00,0xfe,0xff,0xff,0xff,0x7f,
0xff,0xff,0xff,0x63,0x00,0xe0,0x7f,0x8c,0x31,0x86,0xc3,0xff,0xff,0xff,0xff,0x7f,
0xff,0xff,0xff,0x67,0x00,0xc0,0x7f,0x8c,0x31,0x86,0x83,0xff,0xff,0xff,0xff,0x7f,
0xff,0xff,0xff,0x6f,0x00,0xc0,0x7f,0x8c,0x31,0x86,0x83,0xff,0xff,0xff,0xff,0x7f,
0xff,0xff,0xff,0x7f,0x00,0xc0,0x7f,0x8c,0x31,0x86,0x83,0xff,0xff,0xff,0xff,0x7f,
0xff,0xff,0xff,0xff,0x00,0x80,0x7f,0x80,0x01,0x86,0x83,0xff,0xff,0xff,0xff,0x7f,
0xff,0xff,0xff,0xff,0x01,0x00,0x7f,0x80,0x01,0x86,0x83,0xff,0xff,0xff,0xff,0x7f,
0xff,0xff,0xff,0xff,0x03,0x00,0x7c,0xc0,0x03,0x87,0x83,0xff,0xff,0xff,0xff,0x7f,
0xff,0xff,0xff,0xff,0x07,0x00,0xf8,0xff,0xff,0xf1,0xff,0xff,0xff,0xff,0xff,0x7f,
0xff,0xff,0xff,0xff,0x0f,0x00,0xe0,0xff,0x7f,0xf0,0xff,0xff,0xff,0xff,0xff,0x7f,
0xff,0xff,0xff,0xff,0x3f,0x00,0x00,0xfe,0x07,0xfc,0xff,0xff,0xff,0xff,0xff,0x7f,
0xff,0xff,0xff,0xff,0x7f,0x00,0x00,0x00,0x00,0xff,0xff,0xff,0xff,0xff,0xff,0x7f,
0xff,0xff,0xff,0xff,0xff,0x03,0x00,0x00,0xe0,0xff,0xff,0xff,0xff,0xff,0xff,0x7f,
0xff,0xff,0xff,0xff,0xff,0x0f,0x00,0x00,0xfc,0xff,0xff,0xff,0xff,0xff,0xff,0x7f,
0xff,0xff,0xff,0xff,0xff,0x7f,0x00,0x80,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0x7f,
0xff,0xff,0xff,0xff,0xff,0xff,0x3f,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0x7f,
//GPIO4(SDA) GPIO5(SCL)
OLED display(4, 5);
const char* ssid = "xh003"; // XXXXXX -- 使用時請修改為當前你的 wifi ssid
const char* password = "zxd+19901120="; // XXXXXX -- 使用時請修改為當前你的 wifi 密碼
const char* host = "api.seniverse.com";
const char* APIKEY = "wcmquevztdy1jpca"; //API KEY
const char* city = "shenzhen";
const char* language = "en";//zh-Hans 簡體中文 會顯示亂碼
const unsigned long BAUD_RATE = 115200; // serial connection speed
const unsigned long HTTP_TIMEOUT = 5000; // max respone time from server
const size_t MAX_CONTENT_SIZE = 1000; // max size of the HTTP response
// 我們要從此網頁中提取的數據的類型
struct UserData {
char city[16];//城市名稱
char weather[32];//天氣介紹(多云...)
char temp[16];//溫度
char udate[32];//更新時間
WiFiClient client;
char response[MAX_CONTENT_SIZE];
char endOfHeaders[] = "";
* @Desc 初始化操作
void setup() {
WiFi.mode(WIFI_STA); //設置esp8266 工作模式
Serial.begin(BAUD_RATE);
delay(10);
Serial.println();
Serial.println();
Serial.print("Connecting to ");//寫幾句提示,哈哈
Serial.println(ssid);
WiFi.begin(ssid, password); //連接wifi
while (WiFi.status() != WL_CONNECTED) {
//這個函數是wifi連接狀態,返回wifi鏈接狀態
delay(100);
Serial.print(".");
Serial.println("");
Serial.println("WiFi connected");
delay(100);
Serial.println("IP address: ");
Serial.println(WiFi.localIP());//WiFi.localIP()返回8266獲得的ip地址
client.setTimeout(HTTP_TIMEOUT);
* @Desc 主函數
void loop() {
//初始化oled
display.begin();
//測試顯示信息
display.print("Hello DOIT",2,3);
display.print("www.doit.am",4,3);
delay(2*1000);
display.clear();
while (!client.connected()){
if (!client.connect(host, 80)){
Serial.println("connection....");
delay(100);
if (sendRequest(host, city, APIKEY) && skipResponseHeaders()) {
clrEsp8266ResponseBuffer();
readReponseContent(response, sizeof(response));
UserData userData;
if (parseUserData(response, &userData)) {
printUserData(&userData);
delay(300);//每5s調用一次
* @發送請求指令
bool sendRequest(const char* host, const char* cityid, const char* apiKey) {
// We now create a URI for the request
//心知天氣
String GetUrl = "/v3/weather/now.json?key=";
GetUrl += apiKey;
GetUrl += "&location=";
GetUrl += city;
GetUrl += "&language=";
GetUrl += language;
// This will send the request to the server
client.print(String("GET ") + GetUrl + " HTTP/1.1" +
"Host: " + host + "" +
"Connection: close");
Serial.println("create a request:");
Serial.println(String("GET ") + GetUrl + " HTTP/1.1" +
delay(100);
return true;
* @Desc 跳過 HTTP 頭,使我們在響應正文的開頭
bool skipResponseHeaders() {
// HTTP headers end with an empty line
bool ok = client.find(endOfHeaders);
if (!ok) {
Serial.println("No response or invalid response!");
return ok;
* @Desc 從HTTP服務器響應中讀取正文
void readReponseContent(char* content, size_t maxSize) {
size_t length = client.peekBytes(content, maxSize);
delay(100);
Serial.println("Get the data from Internet!");
content[length] = 0;
Serial.println(content);
Serial.println("Read data Over!");
client.flush();//這句代碼需要加上 不然會發現每隔一次client.find會失敗
* @Desc 解析數據
* 數據格式如下:
* "results": [
* "location": {
* "id": "WX4FBXXFKE4F",
* "name": "北京",
* "country": "CN",
* "path": "北京,北京,中國",
* "timezone": "Asia/Shanghai",
* "timezone_offset": "+08:00"
* "now": {
* "text": "多云",
* "code": "4",
* "temperature": "23"
* "last_update": "2017-09-13T09:51:00+08:00"
bool parseUserData(char* content, struct UserData* userData) {
// -- 根據我們需要解析的數據來計算JSON緩沖區最佳大小
// 如果你使用StaticJsonBuffer時才需要
// const size_t BUFFER_SIZE = 1024;
// 在堆棧上分配一個臨時內存池
// StaticJsonBuffer jsonBuffer;
// -- 如果堆棧的內存池太大,使用 DynamicJsonBuffer jsonBuffer 代替
DynamicJsonBuffer jsonBuffer;
JsonObject& root = jsonBuffer.parseObject(content);
if (!root.success()) {
Serial.println("JSON parsing failed!");
return false;
//復制我們感興趣的字符串
strcpy(userData->city, root["results"][0]["location"]["name"]);
strcpy(userData->weather, root["results"][0]["now"]["text"]);
strcpy(userData->temp, root["results"][0]["now"]["temperature"]);
strcpy(userData->udate, root["results"][0]["last_update"]);
// -- 這不是強制復制,你可以使用指針,因為他們是指向“內容”緩沖區內,所以你需要確保
// 當你讀取字符串時它仍在內存中
return true;
// 打印從JSON中提取的數據
void printUserData( struct UserData* userData) {
Serial.println("Print parsed data :");
display.print("City: ",0,0);
display.print(userData->city,0,6);
display.print("Weat: ",2,0);
display.print(userData->weather,2,6);
display.print("Temp: ",4,0);
display.print(userData->temp,4,6);
// display.print("Last Updata : ",7,2);
display.print(userData->udate,6,0);
// display.print("");
delay(4*1000);
// 關閉與HTTP服務器連接
void stopConnect() {
Serial.println("Disconnect");
client.stop();
void clrEsp8266ResponseBuffer(void){
memset(response, 0, MAX_CONTENT_SIZE); //清空
