proteus仿真DAC0832數(shù)模轉(zhuǎn)換示波器顯示波形
[打印本頁(yè)]
tsylovely
時(shí)間:
2018-6-8 09:46
數(shù)模轉(zhuǎn)換proteus仿真波形顯示
(16.85 KB, 下載次數(shù): 75)
2018-6-8 17:14 上傳
(47.2 KB, 下載次數(shù): 63)
2018-6-8 17:14 上傳
單片機(jī)源程序如下:
#include <reg52.h>
sbit key1=P1^0; //定義方波發(fā)生按鈕
sbit key2=P1^1; //定義三角波發(fā)生按鈕
sbit key3=P1^2; //定義正弦波發(fā)生按鈕
unsigned char code S[256]={0x80,0x83,0x86,0x89,0x8d,0x90,0x93,0x96,0x99,0x9c,0x9f,0xa2,0xa5,0xa8,0xab,0xae,0xb1,0xb4,0xb7,0xba,0xbc,0xbf,0xc2,0xc5
,0xc7,0xca,0xcc,0xcf,0xd1,0xd4,0xd6,0xd8,0xda,0xdd,0xdf,0xe1,0xe3,0xe5,0xe7,0xe9,0xea,0xec,0xee,0xef,0xf1,0xf2,0xf4,0xf5
,0xf6,0xf7,0xf8,0xf9,0xfa,0xfb,0xfc,0xfd,0xfd,0xfe,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xfe,0xfd
,0xfd,0xfc,0xfb,0xfa,0xf9,0xf8,0xf7,0xf6,0xf5,0xf4,0xf2,0xf1,0xef,0xee,0xec,0xea,0xe9,0xe7,0xe5,0xe3,0xe1,0xde,0xdd,0xda
,0xd8,0xd6,0xd4,0xd1,0xcf,0xcc,0xca,0xc7,0xc5,0xc2,0xbf,0xbc,0xba,0xb7,0xb4,0xb1,0xae,0xab,0xa8,0xa5,0xa2,0x9f,0x9c,0x99
,0x96,0x93,0x90,0x8d,0x89,0x86,0x83,0x80,0x80,0x7c,0x79,0x76,0x72,0x6f,0x6c,0x69,0x66,0x63,0x60,0x5d,0x5a,0x57,0x55,0x51
,0x4e,0x4c,0x48,0x45,0x43,0x40,0x3d,0x3a,0x38,0x35,0x33,0x30,0x2e,0x2b,0x29,0x27,0x25,0x22,0x20,0x1e,0x1c,0x1a,0x18,0x16
,0x15,0x13,0x11,0x10,0x0e,0x0d,0x0b,0x0a,0x09,0x08,0x07,0x06,0x05,0x04,0x03,0x02,0x02,0x01,0x00,0x00,0x00,0x00,0x00,0x00
,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x02 ,0x02,0x03,0x04,0x05,0x06,0x07,0x08,0x09,0x0a,0x0b,0x0d,0x0e,0x10,0x11,0x13,0x15
,0x16,0x18,0x1a,0x1c,0x1e,0x20,0x22,0x25,0x27,0x29,0x2b,0x2e,0x30,0x33,0x35,0x38,0x3a,0x3d,0x40,0x43,0x45,0x48,0x4c,0x4e
,0x51,0x55,0x57,0x5a,0x5d,0x60,0x63,0x66 ,0x69,0x6c,0x6f,0x72,0x76,0x79,0x7c,0x80 }; //正弦波編碼
int t=0;
void Delay(int i);
void Fangbo(void);
void Sanjiaobo(void);
void Zhengxianbo(void);
if(key1==0) //按鍵掃描
Delay(1);
if(key1==0)
while(!key1)
t=0;
if(key2==0)
Delay(1);
if(key2==0)
while(!key2)
t=1;
if(key3==0)
Delay(1);
if(key3==0)
while(!key3)
t=2;
switch(t)
case 0:
Fangbo();
break;
case 1:
Sanjiaobo();
break;
case 2:
Zhengxianbo();
break;
void Delay(int i) //延時(shí)函數(shù)
int j=255;
for(i;i>=0;i--)
for(j;j>=0;j--)
void Fangbo(void) //方波發(fā)生函數(shù)
P2=0;
Delay(1);
P2=255;
Delay(1);
void Sanjiaobo(void) //三角波發(fā)生函數(shù)
int i=0;
for(i;i<255;i++)
P2=i;
for(i;i>0;i--)
P2=i;
void Zhengxianbo(void) //正弦波發(fā)生函數(shù)
int i=0;
for(i;i<=255;i++)
P2=S[i];
數(shù)據(jù)采集DA轉(zhuǎn)化.rar
(84.89 KB, 下載次數(shù): 106)
2018-6-8 09:45 上傳
點(diǎn)擊文件名下載附件
wyhmtt
時(shí)間:
2018-7-27 20:07
very good!
wyhmtt
時(shí)間:
2018-7-27 20:08
非常非常的好!
超級(jí)無(wú)敵磊果果
時(shí)間:
2018-8-29 09:41
波好差
anksy
時(shí)間:
2018-8-31 09:29
謝謝分享。下載中。學(xué)習(xí)了
zzlazl
時(shí)間:
2018-9-1 13:49
謝謝分享。學(xué)習(xí)了
fuzening
時(shí)間:
2020-4-23 11:10
挺好的
