標題: STC89C51智能小車運行程序 [打印本頁]
作者: 餓餓額2    時間: 2018-6-7 16:47
#include <reg52.h>
sbit SET1=P2^4  ;
sbit SET2 =P2^5;
sbit SET3 =P2^6;
sbit SET4 =P2^7;
uchar code seg7code[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
void delay(uchar t) //延時程序1
    uchar j;
    while(t--)
    {for(j=50;j>0;j--);}
void display ()
    P2=P2|0XF0;
    P0=~seg7code[1];
    SET1=0;
    delay(10);
    P2=P2|0XF0;
    P0=~seg7code[2];
    SET2=0;
    delay(10);
    P2=P2|0XF0;
    P0=~seg7code[3];
    SET3=0;
    delay(10);
    P2=P2|0XF0;
P0=~seg7code[4];
    SET4=0;
    delay(10);
    P2=P2|0XF0;
    P1=0XFF;
    P2=0XFF;
    P3=0XFF;
    P0=0XFF;
        display();
