標(biāo)題: 數(shù)碼管動態(tài)顯示 [打印本頁]
作者: 飛宇軒    時(shí)間: 2018-6-1 13:15
#include<reg52.h>
#define uint  unsigned int
uchar code table[10] = {0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
uchar code LED_W[8] = {0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};
void Delay(uint i)
uchar x,j;
for(j=0;j<i;j++)
for(x=0;x<=148;x++);
void Main(void)
  P0 = 0;
  P2 = LED_W[1];
  P0 = table[1];
  Delay(100);
  P0 = 0;
  P2 = LED_W[0];
  P0 = table[2];
  Delay(100);
