標題: stm32不連續IO口矩陣鍵盤的源碼 [打印本頁]
作者: zlkj    時間: 2018-5-29 22:14
不連續IO口矩陣鍵盤
  1. #include "pkey.h"
  2. #include "delay.h"
  3. #include "sys.h"
  4. void HardwareInit(void);
  5. int main(void)
  6. {
  7.         HardwareInit();
  8.
  9.         while(1)
  10.         {
  11.     GetKeyVal();
  12.
  13.   }
  14. }
  15. void HardwareInit(void)
  16. {
  17.    uart_init(9600);   //串口,便于觀察
  18.    Key_Config();                                  //按鍵初始化
  19.          delay_init();                                //延時函數
  20. }
  3. #include "sys.h"
  4. /**
  5. ** PB5-PB8,列,輸出。 PB10-PB14,行,輸入
  6. **/
  7. void Key_Config(void)
  8. {
  9.    GPIO_InitTypeDef GPIO_InitStructure;
  10.          RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_GPIOB|RCC_APB2Periph_GPIOC|RCC_APB2Periph_GPIOD|RCC_APB2Periph_AFIO, ENABLE);
  11.    GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable, ENABLE);
  12.
  13.          /********4行輸出*********/
  14.          GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_10 | GPIO_Pin_11| GPIO_Pin_12 ;
  15.          GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  16.    GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  17.    GPIO_Init(GPIOC, &GPIO_InitStructure);
  18.
  19.          GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  20.    GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  21.          GPIO_InitStructure.GPIO_Pin = GPIO_Pin_15 ;
  22.    GPIO_Init(GPIOA, &GPIO_InitStructure);
  23.          /********4列輸入*********/
  24.          GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_3 | GPIO_Pin_4 | GPIO_Pin_5;
  25.          GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPD;
  26.    GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  27.    GPIO_Init(GPIOB, &GPIO_InitStructure);
  28.
  29.          GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPD;
  30.    GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  31.          GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
  32.          GPIO_Init(GPIOD, &GPIO_InitStructure);
  33. }
  34. int KeyScan(void)
  35. {
  36.    uchar KeyVal;
  37.
  38.    GPIO_Write(GPIOC, (GPIOC->ODR & 0xE3FF | 0x1C00));         //不管其余12位0xf0ff,先讓PC10到PC12全部輸出高。
  39.          GPIO_Write(GPIOA, (GPIOA->ODR & 0x7FFF | 0x8000));         //不管其余12位0xf0ff,先讓PA15輸出高。
  40.          if(((GPIOB->IDR & 0x0038)|(GPIOD->IDR & 0x0004))==0x0000)        //如果PB12到PB15全為零則沒有按鍵按下
  41.                   return -1;
  42.          else
  43.          {
  44.             delay_ms(5);    //延時5ms去抖動
  45.             if(((GPIOB->IDR & 0x0038)|(GPIOD->IDR & 0x0004))==0x0000)
  46.             return -1;
  47.          }
  48.
  49.
  50.          GPIO_Write(GPIOC, (GPIOC->ODR & 0xE3FF | 0x0000));         //不管其余12位0xf0ff,先讓PC10到PC12全部輸出高。
  51.          GPIO_Write(GPIOA, (GPIOA->ODR & 0x7FFF | 0x8000));         //不管其余12位0xf0ff,先讓PA15輸出高。
  52.          switch((GPIOB->IDR & 0x0038)|(GPIOD->IDR & 0x0004))        //第一行,由低到高,同理,不贅述
  53.          {
  54.              case 0x0004: KeyVal=13;  break;
  55.                         case 0x0008: KeyVal=12;        break;
  56.                         case 0x0010: KeyVal=11;        break;
  57.                         case 0x0020: KeyVal=10;        break;
  58.    }
  59.          while((GPIOB->IDR & 0x0038)|(GPIOD->IDR & 0x0004)        > 0);     //等待按鍵釋放
  60.
  61.          GPIO_Write(GPIOC, (GPIOC->ODR & 0xE3FF | 0x0400));         //不管其余12位0xf0ff,先讓PC10到PC12全部輸出高。
  62.          GPIO_Write(GPIOA, (GPIOA->ODR & 0x7FFF | 0x0000));         //不管其余12位0xf0ff,先讓PA15輸出高。
  63.                 switch((GPIOB->IDR & 0x0038)|(GPIOD->IDR & 0x0004))
  64.                 {
  65.              case 0x0004: KeyVal=14;  break;
  66.                         case 0x0008: KeyVal=9;        break;
  67.                         case 0x0010: KeyVal=6;        break;
  68.                         case 0x0020: KeyVal=3;        break;
  69.                 }
  70.     while((GPIOB->IDR & 0x0038)|(GPIOD->IDR & 0x0004)        > 0);
  71.
  72.          GPIO_Write(GPIOC, (GPIOC->ODR & 0xE3FF | 0x0800));         //不管其余12位0xf0ff,先讓PC10到PC12全部輸出高。
  73.          GPIO_Write(GPIOA, (GPIOA->ODR & 0x7FFF | 0x0000));         //不管其余12位0xf0ff,先讓PA15輸出高。
  74.                 switch((GPIOB->IDR & 0x0038)|(GPIOD->IDR & 0x0004))
  75.                 {
  76.              case 0x0004: KeyVal=0;  break;
  77.                         case 0x0008: KeyVal=8;        break;
  78.                         case 0x0010: KeyVal=5;        break;
  79.                         case 0x0020: KeyVal=2;        break;
  80.                 }
  81.     while((GPIOB->IDR & 0x0038)|(GPIOD->IDR & 0x0004)        > 0);
  82.
  83.           GPIO_Write(GPIOC, (GPIOC->ODR & 0xE3FF | 0x1000));         //不管其余12位0xf0ff,先讓PC10到PC12全部輸出高。
  84.           GPIO_Write(GPIOA, (GPIOA->ODR & 0x7FFF | 0x0000));         //不管其余12位0xf0ff,先讓PA15輸出高。
  85.                 switch((GPIOB->IDR & 0x0038)|(GPIOD->IDR & 0x0004))
  86.                 {
  87.              case 0x0004: KeyVal=15;  break;
  88.                         case 0x0008: KeyVal=7;        break;
  89.                         case 0x0010: KeyVal=4;        break;
  90.                         case 0x0020: KeyVal=1;        break;
  91.                 }
  92. //                printf("%#x\n  ",(GPIOB->IDR & 0x0038));
  93. //          printf("%#x\n  ",(GPIOD->IDR & 0x0004));
  94. //          //printf("%#x\n  ",(GPIOD->IDR & 0x0004)|(GPIOB->IDR & 0x0038));
  95.                 while((GPIOB->IDR & 0x0038)|(GPIOD->IDR & 0x0004)        > 0);
  96.
  97.                 return KeyVal;
  98. }
  99. /************************************
  100. 按鍵表盤為:                0  1  2  3
  101.                                                         4  5  6  7
  102.                                                         8  9  10 11
  103.                                                         12 13 14 15
  104. ************************************/
  105. void GetKeyVal(void)
  106. {
  107.     int num;
  108.           num = KeyScan();
  109.           switch(num)
  110.           {
  111.         case 0: printf("0\n"); break;
  112.                                 case 1: printf("1\n"); break;
  113.                                 case 2: printf("2\n"); break;
  114.                                 case 3: printf("3\n"); break;
  115.                                 case 4: printf("4\n"); break;
  116.                                 case 5: printf("5\n"); break;
  117.                                 case 6: printf("6\n"); break;
  118.                                 case 7: printf("7\n"); break;
  119.                                 case 8: printf("8\n"); break;
  120.                                 case 9: printf("9\n"); break;
  121.                           case 10: printf("10\n"); break;
  122.                                 case 11: printf("11\n"); break;
  123.                                 case 12: printf("12\n"); break;
  124.                           case 13: printf("13\n"); break;
  125.                                 case 14: printf("14\n"); break;
  126.                                 case 15: printf("15\n"); break;
  127.     }
  128. }
不連續IO口矩陣鍵盤.rar (281.38 KB, 下載次數: 26)
