標題: 求大神幫我看看我為什么顯示實際參數太少 [打印本頁]
作者: 13lxw    時間: 2018-5-28 16:13
#include<reg52.h>
#define DATA P2//數據輸出端0~7
sbit RS=P3^5;
sbit RW=P3^6;
sbit EN=P3^4;
sbit PSB=P3^7;
void delayms(uint xms)
        uint i,j;
        for(i=xms;i>0;i--)
                for(j=110;j>0;j--);
/*判斷液晶忙不忙,如果忙則等待*/
void Busy()
        uchar busy;
        do
                EN=0;
                RS=0;
                RW=1;
                delayms(5);
                EN=0;
                busy=P1;
                delayms(5);
                EN=0;
        }while(busy&0x80);                 //判斷最高位是否為1,如果為1再循環
/*寫LCD1602命令*/
void Write_Cmd(uchar cmd)
        Busy();                //判斷忙
        EN=1;
        RS=0;
        RW=0;
        DATA=cmd;
        delayms(5);
        EN=0;
        delayms(5);
/*寫一個字節數據*/
void Write_Data(uchar k)
        Busy();
        EN=1;
        RS=1;
        RW=0;
        DATA=k;
        delayms(5);
        EN=0;
        delayms(5);
void init()                                  //數據初始化
        PSB=1;
        delayms(5);
        Write_Cmd(0x30);                 //基本指令集
        delayms(5);
        Write_Cmd(0x0c);                 //整體顯示打開,游標關閉
        delayms(5);
void clear_Screen()
        Write_Cmd(0x01);                           //清屏
        delayms(5);
//------------------清整個GDRAM空間----------------------------
void clear_GDRAM()
        uchar i,j;
        Write_Cmd(0x34);           //擴充指令及動作
        Write_Cmd(0x34);           //關繪圖顯示功能
        for(i=0;i<32;i++)           //上半屏
                Write_Cmd(0x80+i);       //垂直地址
                Write_Cmd(0x80);         //水平地址,水平地址自動加一
                for(j=0;j<16;j++)
                        Write_Data(0x00);
                for(i=0;i<32;i++)                 //下半屏
                Write_Cmd(0x88+i);       //垂直地址
                Write_Cmd(0x88);         //水平地址,水平地址自動加一
                for(j=0;j<16;j++)
                        Write_Data(0x00);
        Write_Cmd(0x36);           //開繪圖顯示
        Write_Cmd(0x30);           //回到基本指令
void display_Image(uchar *p)            //顯示圖片
        uchar i,j;
                for(j=0;j<16;j++)
                        Write_Data(*p);                 //連續寫入16個字節
                        p++;
                for(j=0;j<16;j++)
                        Write_Data(*p);
                        p++;
uchar code Image[]=       //點陣圖
      0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF8,0x00,0x00,0x00,
      0xFF,0xFE,0xDF,0x00,0x1C,0x0E,0x1D,0xFE,0xAF,0xFF,0xFF,0xFF,0xF8,0x00,0x00,0x00,
      0xFF,0xFE,0xBF,0xF5,0xFD,0xEF,0xD0,0x21,0xB7,0xFF,0xFF,0xFF,0xF8,0x00,0x00,0x00,
      0xFF,0xFD,0x81,0x80,0x3C,0x0E,0xD7,0xBD,0xBF,0xFF,0xFF,0xFF,0xF8,0x00,0x00,0x00,
      0xFF,0xF9,0x7D,0xB5,0xBD,0xEE,0xD0,0x20,0x03,0xFF,0xFF,0xFF,0xF8,0x00,0x00,0x00,
      0xFF,0xF4,0xEF,0x80,0x3C,0x0E,0xD7,0xFD,0xBF,0xFF,0xFF,0xFF,0xF8,0x00,0x00,0x00,
      0xFF,0xFD,0xAB,0xF7,0xFF,0xFE,0x10,0x3D,0x37,0xFF,0xFF,0xFF,0xF8,0x00,0x00,0x00,
      0xFF,0xFD,0xAB,0x00,0x00,0x03,0xD2,0xB8,0xAF,0xFF,0xFF,0xFF,0xF8,0x00,0x00,0x00,
      0xFF,0xFD,0x6D,0xEE,0xFB,0x7F,0x90,0x25,0xDF,0xFF,0xFF,0xFF,0xF8,0x00,0x00,0x00,
      0xFF,0xFC,0xED,0xC5,0xF9,0x06,0x4A,0xBD,0x9B,0xFF,0xFF,0xFF,0xF8,0x00,0x00,0x00,
      0xFF,0xFD,0xEF,0xF8,0xF6,0x7F,0xDA,0xBC,0x6B,0x7B,0xEF,0xBD,0xF8,0x00,0x00,0x00,
      0xFF,0xFD,0x8F,0x07,0x2F,0x03,0x1F,0x31,0xF3,0xFF,0xFF,0xFF,0xF8,0x00,0x00,0x00,
      0xEA,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xE1,0xFF,0xFD,0xFF,0xF8,0x00,0x00,0x00,
      0xF1,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xE0,0x3F,0xDC,0xFF,0xF8,0x00,0x00,0x00,
      0xC0,0x2F,0xFF,0xFF,0xF3,0xFF,0xFF,0xFF,0xFF,0xBD,0x8C,0xFF,0xF8,0x00,0x00,0x00,
      0xF1,0xFF,0xFF,0xFF,0xC7,0xEF,0xFF,0xFC,0xFF,0xB9,0x04,0xFF,0xF8,0x00,0x00,0x00,
      0xE8,0xFF,0xFF,0xFF,0x07,0x1F,0x7F,0xFF,0x3F,0xF0,0x20,0xFF,0xF8,0x00,0x00,0x00,
      0xDB,0x7F,0xFF,0xFC,0x0C,0x1C,0x7F,0x7F,0xCF,0xEE,0x71,0xFF,0xF8,0x00,0x00,0x00,
      0xFB,0xF7,0xE3,0xF8,0x00,0x10,0xDF,0x8F,0xF3,0xFE,0x7D,0xFF,0xF8,0x00,0x00,0x00,
      0xFF,0xFB,0xC1,0xF0,0x00,0x00,0x97,0xC1,0xF8,0xFE,0xFF,0xEF,0xF8,0x00,0x00,0x00,
      0xFB,0xEB,0x98,0xE0,0x00,0x39,0x10,0xF0,0x3C,0x3F,0xFF,0xBF,0xF8,0x00,0x00,0x00,
      0xFF,0xF1,0xA4,0xE0,0x00,0x04,0x10,0x1C,0x06,0x1F,0x8F,0x97,0xF8,0x00,0x00,0x00,
      0xFF,0xD1,0x8A,0xC0,0x00,0x00,0x30,0x00,0x01,0x0F,0x07,0x8F,0xF8,0x00,0x00,0x00,
      0xFF,0xE0,0x8A,0x00,0x00,0x00,0x30,0x38,0x00,0x06,0x33,0x1B,0xF8,0x00,0x00,0x00,
      0xFF,0xA0,0x44,0x00,0x00,0x00,0x50,0x40,0x00,0x06,0x4B,0x17,0xF8,0x00,0x00,0x00,
      0xFF,0xC0,0x60,0x00,0x0F,0xC0,0x48,0x00,0x00,0x02,0xA2,0x05,0xF8,0x00,0x00,0x00,
      0xFF,0x40,0x70,0x00,0x3F,0xE0,0x88,0x00,0x00,0x00,0xA2,0x03,0xF8,0x00,0x00,0x00,
      0xFF,0x80,0xF8,0x00,0x00,0xF1,0x04,0x07,0xE0,0x00,0x44,0x01,0xF8,0x00,0x00,0x00,
      0xFE,0x81,0xE8,0x00,0x01,0xC2,0x04,0x4F,0xF8,0x00,0x0F,0x03,0xF8,0x00,0x00,0x00,
      0xFF,0x00,0x08,0x00,0x01,0x84,0x02,0x3E,0x00,0x00,0x1F,0x82,0xF8,0x00,0x00,0x00,
      0xFD,0x00,0x10,0x00,0x00,0x88,0x01,0x06,0x00,0x00,0x10,0x41,0xF8,0x00,0x00,0x00,
      0xFE,0x01,0xE0,0x01,0x13,0x08,0x00,0x87,0x00,0x00,0x10,0x01,0xB8,0x00,0x00,0x00,
      0xFF,0x06,0x20,0x00,0x88,0x10,0x00,0x43,0x00,0x00,0x10,0x01,0x18,0x00,0x00,0x00,
      0xFD,0x0A,0x10,0x01,0x44,0x10,0x00,0x22,0x00,0x00,0x18,0x01,0xB8,0x00,0x00,0x00,
      0xF8,0x11,0x10,0x00,0x80,0x10,0x00,0x21,0x91,0x00,0x14,0x01,0xF8,0x00,0x00,0x00,
      0xFC,0x10,0x88,0x70,0x00,0x10,0x00,0x10,0x22,0x03,0xE0,0x00,0xB8,0x00,0x00,0x00,
      0xFE,0x20,0x84,0x4C,0x00,0x20,0x00,0x10,0x45,0x05,0x31,0x00,0xF8,0x00,0x00,0x00,
      0xF4,0x20,0x43,0x8B,0x80,0xC0,0x00,0x10,0x02,0x08,0x88,0x80,0xB8,0x00,0x00,0x00,
      0xFC,0x20,0x40,0x08,0xFF,0x00,0x00,0x10,0x00,0x18,0x40,0x40,0x78,0x00,0x00,0x00,
      0xF6,0x20,0x40,0x08,0x80,0x00,0x00,0x08,0x00,0x68,0x40,0x00,0xD8,0x00,0x00,0x00,
      0xFC,0x20,0x40,0x08,0x80,0x00,0x00,0x06,0x03,0x90,0x20,0x20,0x68,0x00,0x00,0x00,
      0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
        init();
        display_Image();
        while(1);
SOCUSE CODE\C\2.C(203): warning C209: '_display_Image': too few actual parameters
謝謝各位大神
作者: ccchengjinwang    時間: 2018-5-28 17:08
同學,你main函數里面調用display_image()沒寫參數。
作者: 13lxw    時間: 2018-6-1 10:24
ccchengjinwang 發表于 2018-5-28 17:08
那應該在display_image()中加什么參數啊
作者: 余較瘦    時間: 2018-6-1 11:21
你在main函數中調用這個函數,C語言學過,總知道該怎么寫參數吧?
作者: 小貓貓愛吃魚    時間: 2018-6-1 12:24
display_Image(Image);    //改成這樣試試
作者: 13lxw    時間: 2018-6-6 21:48
小貓貓愛吃魚 發表于 2018-6-1 12:24
謝謝
