標(biāo)題: 單片機(jī)xdata可以直接映射到IO口嗎?全局變量搞不懂 [打印本頁(yè)]
作者: mengsiu    時(shí)間: 2018-5-27 23:01
最近淘到一片顯示屏,用的是6963的芯片。在網(wǎng)上找了段驅(qū)動(dòng)代碼,但是自己讀不懂...代碼可以正常通過(guò)編譯,說(shuō)明代碼是正確的。
而我不懂的是:
附單片機(jī)代碼:
  1. /*----------------------------------------------------------------------------------------*/
  2. //240*128液晶顯示驅(qū)動(dòng)程序
  3. //控制器件為:AT89S52
  4. //T6963C接口:直接訪問(wèn)形式
  5. //程序設(shè)計(jì):盧印舉
  6. /*----------------------------------------------------------------------------------------*/
  7. #include <reg51.h>
  8. #include <math.h>
  9. #include <hzk.c>
  10.
  11. //信號(hào)管腳定義(全局變量)(注意:因?yàn)橐壕?shù)據(jù)口接P0,直接訪問(wèn)方式)
  12. unsigned char xdata Lcd_Cmd_Reg _at_ 0xfdff;    // C/D-P2.0   CE-P2.1  p2.0=1 p2.1=0
  13. unsigned char xdata Lcd_Data_Reg _at_ 0xfcff;   // C/D-P2.0   CE-P2.1  p2.0=0 p2.1=0
  14.
  15. //以8*8字符計(jì)算,顯示屏橫向、縱向可以顯示的點(diǎn)陣坐標(biāo);左、上、右、下以及當(dāng)前的位置坐標(biāo)
  16. #define LCD_LEFT 0
  17. #define LCD_TOP  0
  18. #define LCD_RIGHT 239
  19. #define LCD_BOTTOM 127
  20. unsigned char data Lcd_CurrentX,Lcd_CurrentY,Lcd_Mask;
  21.
  22. unsigned char data LeftMask[]={0xff,0x7f,0x3f,0x1f,0x0f,0x07,0x03,0x01};
  23. unsigned char data RightMask[]={0xff,0x80,0xc0,0xe0,0xf0,0xf8,0xfc,0xfe};
  24.
  25. /*----------------------------------------------------------------------------------------*/
  26. //延時(shí)子程序
  27. /*----------------------------------------------------------------------------------------*/
  28. void Lcddelay(unsigned int t)
  29. {  unsigned int i,j;
  30.    for(i=0;i<t;i++)
  31.       for(j=0;j<10;j++)
  32.          ;
  33. }
  34.
  35. void lcdwc(unsigned char cmdcode)
  36. {  while((Lcd_Cmd_Reg & 0x3) != 0x3) ;  //當(dāng)Lcd_Cmd_Reg低兩位不同時(shí)為1
  37.       Lcd_Cmd_Reg = cmdcode;
  38. }
  39.
  40. void lcdwc2(unsigned char cmdcode,unsigned char cmddata)
  41. {  while((Lcd_Cmd_Reg & 0x3) != 0x3) ;
  42.       Lcd_Data_Reg = cmddata;
  43.    while((Lcd_Cmd_Reg & 0x3) != 0x3) ;
  44.       Lcd_Cmd_Reg = cmdcode;
  45. }
  46.
  47. void lcdwc3(unsigned char cmdcode,unsigned char cmddata,unsigned char cmddata2)
  48. {  while((Lcd_Cmd_Reg & 0x3) != 0x3) ;
  49.       Lcd_Data_Reg = cmddata;
  50.    while((Lcd_Cmd_Reg & 0x3) != 0x3) ;
  51.       Lcd_Data_Reg = cmddata2;
  52.    while((Lcd_Cmd_Reg & 0x3) != 0x3) ;
  53.       Lcd_Cmd_Reg = cmdcode;
  54. }
  55.
  56. void lcdwd(unsigned char dispdata)           //寫數(shù)據(jù)
  57. {  while((Lcd_Cmd_Reg & 0x3) != 0x3) ;
  58.       Lcd_Data_Reg = dispdata;
  59.    while((Lcd_Cmd_Reg & 0x3) != 0x3) ;
  60.       Lcd_Cmd_Reg = 0xc0;
  61. }
  62.
  63. unsigned char lcdrdata(void)                 //讀數(shù)據(jù)
  64. {  while((Lcd_Cmd_Reg & 0x3) != 0x3) ;
  65.       Lcd_Cmd_Reg = 0xc5;
  66.    while((Lcd_Cmd_Reg & 0x3) != 0x3) ;
  67.       return Lcd_Data_Reg;
  68. }
  69.
  70. void lcdpos(void)                            //內(nèi)部寫數(shù)指針定位
  71. {  unsigned int CurrentAddress;
  72.    CurrentAddress = Lcd_CurrentY * 30 ;
  73.    CurrentAddress += Lcd_CurrentX/8;
  74.    lcdwc3(0x24,CurrentAddress & 0xff,CurrentAddress/256);
  75. }
  76.
  77. unsigned char lcdrd(void)                    //讀數(shù)據(jù)
  78. {  lcdpos();
  79.    return lcdrdata();
  80. }
  81.
  82. void lcdcursornextbyte(void)  //當(dāng)前坐標(biāo)移動(dòng)到下一個(gè)點(diǎn)
  83. {  Lcd_CurrentX+=8;
  84.    if(Lcd_CurrentX > LCD_RIGHT)
  85.    {  Lcd_CurrentX = LCD_LEFT;
  86.       Lcd_CurrentY++;
  87.       if(Lcd_CurrentY > LCD_BOTTOM) Lcd_CurrentY = LCD_TOP;
  88.    }
  89. }
  90.
  91. void displaybyte(unsigned char dispdata)
  92. {  lcdpos();
  93.    if(Lcd_Mask == 0xff) lcdwd(dispdata);
  94.    else
  95.    {  unsigned char d=lcdrd();
  96.       d&=(~Lcd_Mask);
  97.       d|=(dispdata & Lcd_Mask);
  98.       lcdwd(d);
  99.    }
  100.    lcdcursornextbyte();
  101. }
  102.
  103. void Fill_Scr(unsigned char FillData)    //LCD整屏顯示
  104. {  Lcd_Mask=0xff;
  105.    for(Lcd_CurrentX = LCD_LEFT,Lcd_CurrentY = LCD_TOP;1;)
  106.    {  displaybyte(FillData);
  107.       if((Lcd_CurrentX == LCD_LEFT) && (Lcd_CurrentY == LCD_TOP)) break;
  108.    }
  109. }
  110.
  111. void lcdreset()             //初始化LCD屏
  112. {  lcdwc(0x80);
  113.    lcdwc(0x98);
  114.    lcdwc3(0x42,0,0);
  115.    lcdwc3(0x43,30,0);
  116. }
  117.
  118. void displaychinesechardot(unsigned int Index);
  119. void displayenglishchardot(unsigned int Index);
  120. void putsizeimage(unsigned char XSIZE,unsigned char YSIZE,unsigned char code *s);
  121.
  122. void putchar(unsigned int uChar)  //信息顯示
  123. {  unsigned int i;
  124.    if(uChar<128)
  125.       for(i=0;i != ENGLISHCHARNUMBER;i++)
  126.       {  if(uChar ==EnglishCode[i])
  127.          {  displayenglishchardot(i);
  128.             break;
  129.          }
  130.       }
  131.    else
  132.       for(i=0;i != CHINESECHARNUMBER;i++)
  133.       {  if(uChar ==ChineseCode[i])
  134.          {  displaychinesechardot(i);
  135.             break;
  136.          }
  137.       }
  138. }
  139.
  140. void put_str(unsigned char code *s) //顯示漢字或英文字符
  141. {  unsigned int i;
  142.    for (;*s != 0;s++)
  143.    {  i=*s;
  144.       if(*s > 127)
  145.       {  s++;
  146.          i=i*256+*s;
  147.       }
  148.       if(i == '\n')
  149.       {  Lcd_CurrentX = LCD_LEFT;
  150.          if(Lcd_CurrentY > LCD_BOTTOM-CHINESECHARSIZE+1)
  151.             Lcd_CurrentY=LCD_TOP;
  152.          else
  153.             Lcd_CurrentY+=CHINESECHARSIZE;
  154.       }
  155.       putchar(i);
  156.    }
  157. }
  158.
  159. void put_str_xy(unsigned char x,unsigned char y,unsigned char code *s)//顯示漢字或英文字符
  160. {  Lcd_CurrentX=x;
  161.    Lcd_CurrentY=y;
  162.    put_str(s);
  163. }
  164.
  165. void displaychinesechardot(unsigned int Index)
  166. {  unsigned char code *s;
  167.    s=ChineseCharDot+Index*CHINESECHARDOTSIZE;
  168.    if(Lcd_CurrentX > LCD_RIGHT-CHINESECHARSIZE+1)
  169.    {   Lcd_CurrentX = LCD_LEFT;
  170.        Lcd_CurrentY+=CHINESECHARSIZE;
  171.        if(Lcd_CurrentY > LCD_BOTTOM-CHINESECHARSIZE+1) Lcd_CurrentY=LCD_TOP;
  172.    }
  173.    putsizeimage(CHINESECHARSIZE,CHINESECHARSIZE,s);
  174. }
  175.
  176. void displayenglishchardot(unsigned int Index)
  177. {  unsigned char code *s;
  178.    s=EnglishCharDot+Index*ENGLISHCHARDOTSIZE;
  179.    if(Lcd_CurrentX > LCD_RIGHT-ENGLISHCHARSIZE+1)
  180.    {  Lcd_CurrentX = LCD_LEFT;
  181.       Lcd_CurrentY+=CHINESECHARSIZE;
  182.       if(Lcd_CurrentY > LCD_BOTTOM-CHINESECHARSIZE+1)
  183.          Lcd_CurrentY=LCD_TOP;
  184.    }
  185.    putsizeimage(ENGLISHCHARSIZE,CHINESECHARSIZE,s);
  186. }
  187.
  188. void point(unsigned char bitdata)
  189. {  if(bitdata==0)
  190.       bitdata=0xf0+(0x7-(Lcd_CurrentX & 0x7));
  191.    else
  192.       bitdata=0xf8+(0x7-(Lcd_CurrentX & 0x7));
  193.    while((Lcd_Cmd_Reg & 0x3) != 0x3) ;
  194.       Lcd_Cmd_Reg = bitdata;
  195. }
  196.
  197. /*----------------------------------------------------------------------------------------*/
  198. //繪制點(diǎn)子程序,最后一位為像素大小
  199. /*----------------------------------------------------------------------------------------*/
  200. void pointxy(unsigned char x,unsigned char y,unsigned char bitdata)
  201. {  Lcd_CurrentX=x;
  202.    Lcd_CurrentY=y;
  203.    lcdpos();
  204.    point(bitdata);
  205. }
  206.
  207. /*----------------------------------------------------------------------------------------*/
  208. //畫線子程序:最后一位為線條的像素寬度
  209. /*----------------------------------------------------------------------------------------*/
  210. void linexy(unsigned char x0,unsigned char y0,unsigned char x1,unsigned char y1,unsigned char bitdata)
  211. {                                                       //線
  212.    unsigned char i,k;
  213.    if(abs(y1-y0)>abs(x1-x0))
  214.    {  if(y1>y0)
  215.          for(i=y0;i<=y1;i++)
  216.          {  if(x1>x0)
  217.             {  k=x1-x0;
  218.                k*=(i-y0);
  219.                k/=y1-y0;
  220.                pointxy(x0+k,i,bitdata);
  221.             }
  222.             else  //x1<x0
  223.             {  k=x0-x1;
  224.                k*=(i-y0);
  225.                k/=y1-y0;
  226.                pointxy(x0-k,i,bitdata);
  227.             }
  228.          }
  229.       else        //y1<y0
  230.          for(i=y0;i>=y1;i--)
  231.          {  if(x1>x0)
  232.             {  k=x1-x0;
  233.                k*=(y0-i);
  234.                k/=y0-y1;
  235.                pointxy(x0+k,i,bitdata);
  236.             }
  237.             else   //x1<x0
  238.             {  k=x0-x1;
  239.                k*=(y0-i);
  240.                k/=y0-y1;
  241.                pointxy(x0-k,i,bitdata);
  242.             }
  243.          }
  244.    }
  245.    else            //abs(y1-y0)<abs(x1-x0)
  246.    {  if(x1>x0)
  247.          for(i=x0;i<=x1;i++)
  248.          {  if(y1==y0)
  249.                pointxy(i,y0,bitdata);
  250.             else if(y1>y0)
  251.             {  k=y1-y0;
  252.                k*=(i-x0);
  253.                k/=x1-x0;
  254.                pointxy(i,y0+k,bitdata);
  255.             }
  256.             else     //y1<y0
  257.             {  k=y0-y1;
  258.                k*=(i-x0);
  259.                k/=x1-x0;
  260.                pointxy(i,y0-k,bitdata);
  261.             }
  262.          }
  263.       else
  264.          for(i=x0;i>=x1;i--)
  265.          {  if(y1==y0)
  266.                pointxy(i,y0,bitdata);
  267.             else if(y1>y0)
  268.             {  k=y1-y0;
  269.                k*=(x0-i);
  270.                k/=x0-x1;
  271.                pointxy(i,y0+k,bitdata);
  272.             }
  273.             else     //y1<y0
  274.             {  k=y0-y1;
  275.                k*=(x0-i);
  276.                k/=x0-x1;
  277.                pointxy(i,y0-k,bitdata);
  278.             }
  279.        }
  280.   }
  281. }
  282.
  283. void rect(unsigned char x0,unsigned char y0,unsigned char x1,unsigned char y1,unsigned char bitdata)
  284. {                                                      //矩形
  285.    linexy(x0,y0,x0,y1,bitdata);
  286.    linexy(x0,y0,x1,y0,bitdata);
  287.    linexy(x0,y1,x1,y1,bitdata);
  288.    linexy(x1,y0,x1,y1,bitdata);
  289. }
  290.
  291. void putsizeimage(unsigned char XSIZE,unsigned char YSIZE,unsigned char code *s)
  292. {  unsigned char k,lx,ly,a1,a2,x;
  293.    Lcddelay(1000);
  294.    k=Lcd_CurrentX&0X7;
  295.    XSIZE+=k;
  296.    x=Lcd_CurrentX;
  297.    for(ly=0;ly<YSIZE;ly++,Lcd_CurrentY++)
  298.       for(Lcd_CurrentX=x,lx=k,a1=0;lx<XSIZE;s++)
  299.       {  unsigned char p;
  300.          a2=*s;
  301.          for(p=0;p<k;p++)
  302.          {  a2>>=1;
  303.             if((a1&0x1)==1) a2+=0x80;
  304.             a1>>=1;
  305.          }
  306.          lcdpos();
  307.          p=XSIZE&0X7;
  308.          if(lx<8)
  309.          {  if(XSIZE<8)
  310.             {  Lcd_Mask=LeftMask[k] & RightMask[p];
  311.                a1=lcdrd();
  312.                a1&=(~Lcd_Mask);
  313.                a1|=(a2 & Lcd_Mask);
  314.                lcdwd(a1);
  315.                lx=XSIZE;
  316.                 Lcd_CurrentX+=XSIZE-k;
  317.             }
  318.             else   //XSIZE>=8
  319.             {  Lcd_Mask=LeftMask[k];
  320.                a1=lcdrd();
  321.                a1&=(~Lcd_Mask);
  322.                a1|=(a2 & Lcd_Mask);
  323.                lcdwd(a1);
  324.                lx+=8-k;
  325.                Lcd_CurrentX+=8-k;
  326.             }
  327.          }
  328.          else if(lx>=XSIZE-p)  //lx>=8
  329.          {  if(k>=p)
  330.             {  s--;
  331.                a1=*s;
  332.                a2=0;
  333.                for(p=0;p<k;p++)
  334.                {  a2>>=1;
  335.                   if((a1&0x1)==1) a2+=0x80;
  336.                      a1>>=1;
  337.                }
  338.                p=XSIZE&0X7;
  339.             }
  340.             Lcd_Mask=RightMask[p];
  341.             a1=lcdrd();
  342.             a1&=(~Lcd_Mask);
  343.             a1|=(a2 & Lcd_Mask);
  344.             lcdwd(a1);
  345.             lx+=p;
  346.             Lcd_CurrentX+=p;
  347.          }
  348.          else    //lx>=8 and lx<XSIZE-p
  349.          {  lcdwd(a2);
  350.             lx+=8;
  351.             Lcd_CurrentX+=8;
  352.          }
  353.          a1=*s;
  354.       }
  355.   Lcd_CurrentY-=YSIZE;
  356. }
  357.
  358. void main()
  359. {
  360.    lcdreset();
  361.    Fill_Scr(0x55);            //顯示豎條
  362.    Lcddelay(6000);            //系統(tǒng)延時(shí)
  363.    Fill_Scr(0xff);            //顯示黑屏
  364.    Lcddelay(6000);
  365. //   put_str_xy(0,0,"創(chuàng)新科技檢測(cè)技術(shù)有限公司,聯(lián)系電話0512-86163888");//顯示漢字
  366.    put_str("創(chuàng)新科技檢測(cè)技術(shù)有限公司,聯(lián)系電話0512-86163888");
  367.    Fill_Scr(0x00);
  368. //
  369.    rect(12,12,88,88,6);
  370.    Lcddelay(5000);
  371.    //Fill_Scr(0xff);
  372.    //rect(12,12,88,120,0);
  373.    lcdreset();
  374. }
作者: mengsiu    時(shí)間: 2018-5-28 22:03
24小時(shí)必答嗎?已經(jīng)24小時(shí)了嗎?已經(jīng)快24小時(shí)了。
作者: mengsiu    時(shí)間: 2018-6-2 09:45
24小時(shí)必答嗎?已經(jīng)24小時(shí)了嗎?已經(jīng)100小時(shí)了。
作者: mengsiu    時(shí)間: 2018-6-7 13:28
24小時(shí)必答嗎?已經(jīng)24小時(shí)了嗎?已經(jīng)240小時(shí)了。
作者: mengsiu    時(shí)間: 2018-9-7 10:24
24小時(shí)必答嗎?已經(jīng)24小時(shí)了嗎?已經(jīng)2400+小時(shí)了。
作者: sxhwdz    時(shí)間: 2018-9-18 19:49
早先的51單片機(jī)內(nèi)部沒(méi)有XRAM,而且都是使用總線結(jié)構(gòu),P0是數(shù)據(jù)8位數(shù)據(jù)總線,與低8位地址總線,P2是高8位地址總線。而外部設(shè)備的尋址也是通過(guò)映射到XRAM段,操作外設(shè)與XRAM讀取類似。12、13行定義的應(yīng)該是液晶屏的命令和數(shù)據(jù)的選通信號(hào)。
作者: angmall    時(shí)間: 2018-9-18 21:31
題主你好,你這樣的提問(wèn)。我估計(jì)沒(méi)幾個(gè)人會(huì)回答你的。
其實(shí)就一條解決方案:研讀T6963C手冊(cè)。。
作者: sxhwdz    時(shí)間: 2018-9-19 06:58
液晶屏C/D連接的是P2.0,CE連接的是P2.1,RD連接P3.7,WR連接P3.6。當(dāng)對(duì)地址 0xfdff 的 Lcd_Cmd_Reg 讀/寫時(shí),C/D=1,CE=0,完成對(duì)液晶屏指令寄存器的讀寫。對(duì)地址 0xfcff 的 Lcd_Data_Reg 讀/寫時(shí),C/D=0,CE=0,完成對(duì)液晶屏數(shù)據(jù)寄存器的讀寫。
