標(biāo)題: 霍夫曼編碼CPP實現(xiàn) [打印本頁]
作者: 反光鏡    時間: 2018-5-27 15:28
本帖最后由 反光鏡 于 2018-5-27 15:29 編輯
#include <iostream>
#include <list>
#include <vector>
#include <iomanip>
using namespace std;
struct Huff_node
    int bit;
    float prob;
//    Huff_node*next_node1;
//    Huff_node*next_node2;
//    Huff_node*next_node3;
    Huff_node*pre_node;
bool compareProb(Huff_node*, Huff_node*);
void ClearHuffNodeIndex(list<Huff_node*> *);
void print_Huff_Code(list<Huff_node*> *);
int main()
    //vector里依次輸入N個概率,N未定
   list<Huff_node*> Huff_node_index_B;
   list<Huff_node*> Huff_node_encode_B;
   list<Huff_node*> Huff_node_index_T;
   list<Huff_node*> Huff_node_encode_T;
    int num;
    Huff_node*tmpHuff_node;
    Huff_node*tmpHuff_node1;
    Huff_node*tmpHuff_node2;
    Huff_node*tmpHuff_node3;
        //每輸入一個概率,new一個node,存入概率
        cout<< "請輸入大于3的概率數(shù)量n=" ;
        cin>> num;
       if(num<=3)
            cout<< "請檢查輸入概率數(shù)量n是否大于3!!"<< endl << endl;
           continue;
        cout<< endl << "請輸入概率:" << endl;
       while(num>0)
           tmpHuff_node1 = new Huff_node;
           tmpHuff_node2 = new Huff_node;
            cin >> tmpHuff_node1->prob;
           tmpHuff_node1->pre_node= nullptr;
           tmpHuff_node1->bit = -1;
           *tmpHuff_node2 = *tmpHuff_node1;
//二進制和三進制分別存儲一份數(shù)據(jù)
           Huff_node_index_B.push_back(tmpHuff_node1);
            Huff_node_index_T.push_back(tmpHuff_node2);
            --num;
//       if(sumProb>1)
//                cout << "ERROR!概率輸入有誤,請重新輸入全部概率" << endl << endl;
//               ClearHuffNodeIndex(&Huff_node_index_B);
//清空所有霍夫曼節(jié)點和索引
//                ClearHuffNodeIndex(&Huff_node_index_T);
//               continue;
        //輸入完畢,vector進行sort,從大到小排序,并建立編碼vector組
       Huff_node_index_B.sort(compareProb);
       Huff_node_index_T.sort(compareProb);
       Huff_node_encode_B = Huff_node_index_B;
       Huff_node_encode_T = Huff_node_index_T;
        //霍夫曼二進制編碼
       while(Huff_node_encode_B.size()!=1)//當(dāng)vector的元素不等于1
           tmpHuff_node1 = Huff_node_encode_B.back();
           Huff_node_encode_B.pop_back();
           tmpHuff_node2 = Huff_node_encode_B.back();
           tmpHuff_node1->bit = 0;
           tmpHuff_node2->bit = 1;
            //建立前向鏈接
           tmpHuff_node = new Huff_node;
tmpHuff_node->bit=-1;
           tmpHuff_node->pre_node = nullptr;
           tmpHuff_node->prob=tmpHuff_node1->prob+ tmpHuff_node2->prob;
            //取出最前面的兩個node,掛接到新new的node后面
           tmpHuff_node1->pre_node = tmpHuff_node;
           tmpHuff_node2->pre_node = tmpHuff_node;
            //將new node放入vector尾部
           Huff_node_encode_B.push_back(tmpHuff_node);
            //重新sort
           Huff_node_encode_B.sort(compareProb);
        //執(zhí)行霍夫曼二進制的輸出
         cout<< endl << endl << "霍夫曼二進制編碼為:"<< endl;
       print_Huff_Code(&Huff_node_index_B);
        //霍夫曼三進制編碼
       while(Huff_node_encode_T.size()>2)//當(dāng)vector的元素不等于1
           tmpHuff_node1 = Huff_node_encode_T.back();
           Huff_node_encode_T.pop_back();
            tmpHuff_node2= Huff_node_encode_T.back();
           tmpHuff_node3 = Huff_node_encode_T.back();
            tmpHuff_node3->bit = 2;
            //建立前向鏈接
            tmpHuff_node->pre_node =nullptr;
tmpHuff_node->prob=tmpHuff_node1->prob+tmpHuff_node2->prob+tmpHuff_node3->prob;
           tmpHuff_node3->pre_node = tmpHuff_node;
           Huff_node_encode_T.push_back(tmpHuff_node);
            //重新sort
           Huff_node_encode_T.sort(compareProb);
       if(Huff_node_encode_T.size()==2)
           tmpHuff_node2 = Huff_node_encode_T.back();
        //執(zhí)行霍夫曼三進制的輸出
        cout<< endl << endl << "霍夫曼三進制編碼為:"<< endl;
       print_Huff_Code(&Huff_node_index_T);
       cout<< endl << endl << endl;
    }//Processingcompleted, go to next circle
bool compareProb(Huff_node* node1, Huff_node* node2)
    if(node1->prob > node2->prob )
        returntrue;
        returnfalse;
void ClearHuffNodeIndex(list<Huff_node*> *index)
    for(list<Huff_node*>::iterator i = (*index).begin();i!= (*index).end();i++)
       delete(*i);
   (*index).clear();
void print_Huff_Code(list<Huff_node*> *to_print)
    Huff_node*curHuff_node;
   vector<int> curCode;
    for(list<Huff_node*>::iterator i =(*to_print).begin();i != (*to_print).end();i++)
       curHuff_node = (*i);
        cout<< setw(8) << curHuff_node->prob << " 的編碼: " ;
       while(curHuff_node->pre_node!=nullptr)
           curCode.push_back(curHuff_node->bit);
           curHuff_node = curHuff_node->pre_node;
       if(curHuff_node->bit!=-1)
        for(intj=curCode.size();j>0;j--)
            cout<< curCode[j-1];
       curCode.clear();
        cout<< endl;
