標(biāo)題: 接線如圖所示,程序如下,求大佬指點(diǎn) [打印本頁(yè)]
作者: 哭著笑    時(shí)間: 2018-5-23 20:05
/*********引腳定義**********/
#include "reg51.h"
typedef unsigned int uint;
typedef unsigned char uchar;
#define Duty_cycle   35                      //占空比
#define Cycle                  100                                //PWM周期
sbit Sensor_1 = P1^1;                                        //紅外檢測(cè)
sbit Sensor_2 = P1^2;
sbit Motor_1H = P0^0;                                        //電機(jī)控制
sbit Motor_1L = P0^1;
sbit Motor_2H = P0^2;
sbit Motor_2L = P0^3;
sbit Motor_3H =        P0^4;
sbit Motor_3L =        P0^5;
sbit Motor_4H =        P0^6;
sbit Motor_4L = P0^7;
sbit En_pwm1 = P1^4;                                        //使能信號(hào) (PWM)
sbit En_pwm2 = P1^5;
sbit En_pwm3 = P1^6;
sbit En_pwm4 = P1^7;
uchar timer1;                                                        //定義變量
/*********主函數(shù)**********/
void main ()
         Time1Config();                                                //定時(shí)器初始化
                if (Sensor_1 == 1 && Sensor_2 == 1)                        //狀態(tài):軌跡居中
                        Go_Straighe();                                                        //方向:前進(jìn)
                else if (Sensor_1 == 1 && Sensor_2 == 0)          //狀態(tài):偏左
                        Turn_Righr();                                                        //方向:右轉(zhuǎn)
                else if (Sensor_1 == 0 && Sensor_2 == 1)        //狀態(tài):偏右
                        Turn_Left();                                                        //方向:左轉(zhuǎn)
                else if (Sensor_1 == 0 && Sensor_2 == 0)        //狀態(tài):偏離軌跡
                        Stop();        //方向:停止
                else Go_Straight();                                                        //其他情況:前進(jìn)
/**********設(shè)置定時(shí)器**********/
void Time1Config()
        TMOD = 0x10;        //設(shè)置定時(shí)器計(jì)數(shù)器T1工作在模式1
        /**********定時(shí)器賦初值*********/
        TH1 = 0xFE;
        TL1 = 0x0c;
        ET1 = 1;        //開啟定時(shí)器1中斷
        EA = 1;
        TR1 = 1;        //開啟定時(shí)器
/**********定時(shí)器1的中斷函數(shù)**********/
void Time1(void) interrupt 3                                                 //3 為定時(shí)器的中斷信號(hào)
        Time1++;
        if (Timer1 > Cycre)        //PWM周期
                Time1 = 0;
        if (Timer1 < Duty_cycle)                                                   //改變Duty_cycle 這個(gè)值,可以改變直流電機(jī)的速度
                En_pwm1 = 1;
                En_pwm2 = 1;
                En_pwm3 = 1;
                En_pwm4 = 1;
                En_pwm1 = 0;
                En_pwm2 = 0;
                En_pwm3 = 0;
                En_pwm4 = 0;
        TH1 = 0xFE;        //重新賦值
        TL1 = 0x0C;
