求大神幫我看下這段程序的含義(大概一個(gè)流程就好謝謝)
[打印本頁(yè)]
葉陽(yáng)初語(yǔ)
時(shí)間:
2018-5-22 12:58
void produce()/*掃頻產(chǎn)生程序*/
n3=sett1*100000+sett2*10000+sett3*1000+sett4*100+sett5*10+sett6;
if(flag1==1&flag2==1)/*使用定時(shí)器0*/
a1=0;b1=0;c1=0;
n2=low;
while(n2<high)
n1=50000/n2;
c=n1;
chuzhi();
COM0=h;
COM0=e;
ET0=1;
TR0=1;
display1(n2);
while(n<50)
keyscan();
n=0;
ET0=0;
TR0=0;
n2=n2+n3;
if(star==0)
break;
n2=high;
while(n2>low)
n1=50000/n2;
c=n1;
chuzhi();
COM0=h;
COM0=e;
ET0=1;
TR0=1;
display1(n2);
while(n<50)
keyscan();
n=0;
ET0=0;
TR0=0;
n2=n2-n3;
if(star==0)
break;
if(flag1==2&flag2==2)/*使用定時(shí)器1*/
a1=1;b1=0;c1=0;
n2=low;
while(n2<high)
n1=1000000/n2;
c=n1;
chuzhi();
COM1=h;
COM1=e;
ET0=1;
TR0=1;
display1(n2);
while(n<50)
keyscan();
n=0;
ET0=0;
TR0=0;
n2=n2+n3;
if(star==0)
break;
n2=high;
while(n2>low)
n1=1000000/n2;
c=n1;
chuzhi();
COM1=h;
COM1=e;
ET0=1;
TR0=1;
display1(n2);
while(n<50)
keyscan();
n=0;
ET0=0;
TR0=0;
n2=n2-n3;
if(star==0)
break;
if(flag1==1&flag2==2)/*先使用定時(shí)器0,再使用定時(shí)器1*/
a1=0;b1=0;c1=0;
n2=low;
while(n2<5000)
n1=50000/n2;
c=n1;
chuzhi();
COM0=h;
COM0=e;
ET0=1;
TR0=1;
display1(n2);
while(n<50)
keyscan();
n=0;
ET0=0;
TR0=0;
n2=n2+n3;
if(star==0)
break;
a1=1;b1=0;c1=0;
while(n2<high)
n1=1000000/n2;
c=n1;
chuzhi();
COM1=h;
COM1=e;
ET0=1;
TR0=1;
display1(n2);
while(n<50)
keyscan();
n=0;
ET0=0;
TR0=0;
n2=n2+n3;
if(star==0)
break;
n2=high;
while(n2>low)
n1=1000000/n2;
c=n1;
chuzhi();
COM1=h;
COM1=e;
ET0=1;
TR0=1;
display1(n2);
while(n<50)
{keyscan();}
n=0;
ET0=0;
TR0=0;
n2=n2-n3;
if(star==0)
break;
a1=0;b1=0;c1=0;
while(n2>low)
n1=50000/n2;
c=n1;
chuzhi();
COM0=h;
COM0=e;
ET0=1;
TR0=1;
display1(n2);
while(n<50)
{keyscan();}
n=0;
ET0=0;
TR0=0;
n2=n2-n3;
if(star==0)
break;
COM8253=0x36;/*8253初始化,選擇定時(shí)器0,工作方式3,二進(jìn)制*/
COM8253=0x76;/*選擇定時(shí)器1,工作方式3,二進(jìn)制*/
init();/*1602初始化*/
display();/*頻率顯示界面*/
TMOD=0x01;/*定時(shí)器0工作方式1*/
TH0=(65536-50000)/256;/*定時(shí)器0初值裝入*/
TL0=(65536-50000)%256;
EA=1;/*開總中斷*/
ET0=0;/*允許定時(shí)器0中斷*/
TR0=0;/*允許定時(shí)器計(jì)數(shù)*/
a1=0;b1=0;c1=0;
keyscan();
setlow(set1,set2,set3,set4,set5,set6,set11,set22,set33,set44,set55,set66);
if(star==1)
produce();
void T0_time() interrupt 1/*使定時(shí)器中斷0*/
n++;
zyzhyue
時(shí)間:
2018-5-22 15:14
程序分3段。
第2段 main(),是上電執(zhí)行的內(nèi)容:先初始化MCU和外設(shè)的工作狀態(tài),然后進(jìn)入主循環(huán)。
第1段,被主循環(huán)調(diào)用,產(chǎn)生掃頻信號(hào)。
第3段,定時(shí)器中斷處理,重裝以保證定時(shí)器,計(jì)數(shù)。
A110brick
時(shí)間:
2018-5-30 20:15
這一段程序分為三部分
首先:先初始化MCU和外設(shè)的工作狀態(tài),然后進(jìn)入主循環(huán)。
接下來:被主循環(huán)調(diào)用,產(chǎn)生掃頻信號(hào)。
最后:定時(shí)器中斷處理,重裝以保證定時(shí)器,計(jì)數(shù)。
