驗證通過的不帶字庫12864液晶顯示程序
pcbchuxuezhe
2018-5-10 20:57
看看吧 反正又不要錢
#include <reg52.h>
#include <intrins.h>
#define nop _nop_()
#define LCD_data P0 //數據口
sbit LCD_RS = P2^6; //寄存器選擇輸入
sbit LCD_RW = P2^5; //液晶讀/寫控制
sbit LCD_EN = P2^7; //液晶使能控制
sbit LCD_CS1 = P3^2; //低電平有效 控制左半屏
sbit LCD_CS2 = P3^3; //低電平有效 控制右半屏
//sbit LCD_RST = P3^4; //液晶復位端口
uchar code wo[]={0x20,0x24,0x24,0x24,0xFE,0x23,0x22,0x20,0x20,0xFF,0x20,0x22,0x2C,0xA0,
0x20,0x00,
0x00,0x08,0x48,0x84,0x7F,0x02,0x41,0x40,0x20,0x13,0x0C,0x14,0x22,0x41,0xF8,0x00,};
void delay(uchar a) //延時
uchar x,y;
for(x=0;x<a;x++)
for(y=0;y<10;y++);
void LCD_busy() //忙檢測函數
LCD_data=0x00;
LCD_RS = 0;
LCD_RW = 1;
LCD_EN = 1;
while( LCD_data & 0x80 );
LCD_EN = 0;
LCD_RS = 0;
LCD_RW = 1;
void LCD_write_cmmand(uchar cmd) //寫指令函數
// LCD_busy();
LCD_RS = 0;
LCD_RW = 0;
LCD_EN = 0;
LCD_data = cmd; // nop;
// nop;
delay(2);
LCD_EN = 1;
// nop;
// nop;
delay(2);
LCD_EN = 0;
void LCD_write_data(uchar dat) //寫數據函數
// LCD_busy();
LCD_RS = 1;
LCD_RW = 0;
LCD_EN = 0;
LCD_data = dat;
delay(2);
LCD_EN = 1;
delay(2);
LCD_EN = 0;
void set_page(uchar page)//設置頁,要那一頁直接是那個數字就行了
{ //總共有 8頁,一頁是 8 行點陣點,即 128*8
page=0xb8|page; //頁得首地址為 0xB8 1011 1XXX
LCD_write_cmmand(page);
void set_line(uchar startline) //設置顯示的起始行
startline=0xc0|startline; //起始行地址為 0xc0
LCD_write_cmmand(startline); //設置從哪一行開始,共 0--63 11XX XXXX
void set_column(uchar column) //設置顯示的列
column=column&0x3f; //列的最大值為 64,因為分成兩個屏了
column=0x40|column; //列的首地址為 0x40; 01XX XXXX
LCD_write_cmmand(column); //設置列位置
void setonoff(uchar onoff) //顯示開關函數,1 為開,0 為關
{ onoff=0x3e|onoff; //0x3e是關顯示,0x3f 是開顯示 0011 111X onoff 只能為0 或者1;
LCD_write_cmmand(onoff);
void selectscreen(uchar screen) //選屏
switch(screen)
case 0:LCD_CS1=0;LCD_CS2=0;break; //全屏
case 1:LCD_CS1=0;LCD_CS2=1;break; //選左半屏
case 2:LCD_CS1=1;LCD_CS2=0;break; //選右半屏
default:break;
void clearscreen(uchar screen) //清屏
uchar i,j;
selectscreen(screen);
LCD_write_cmmand((0xb8)+0);
LCD_write_cmmand((0x40)+0);
for(i=0;i<8;i++) //控制頁數 0--7,共8 頁
set_page(i);
// set_column(0);
for(j=0;j<64;j++) //控制列數 0-63,共 64 列
LCD_write_data(0x00); //寫入 0,地址指針自加 1
void LCD_init() //lcd 的初始化
// LCD_busy(); //忙檢測
delay(100);
selectscreen(0); //兩個屏都選
setonoff(0); //關顯示
selectscreen(0); //選屏
setonoff(1); //開顯示
clearscreen(0); //清屏
set_line(0); //開始行為 0
// set_column(0); //開始列為 0
// set_page(0); //開始頁為0 }
void display(uchar ss,uchar page,uchar column,uchar *p) //顯示漢字
uchar i;
selectscreen(ss); //選屏
delay(2);
set_page(page); //寫上半頁
set_column(column); //控制列
for(i=0;i<16;i++) //控制 16列的數據輸出,因為一個漢字是 16*16 點陣的
LCD_write_data(p[i]); //漢字的上半部分
set_page(page+1); //寫下半頁
for(i=0;i<16;i++) //控制16 列數據的輸出
LCD_write_data(p[i+16]);//漢字的下半部分
LCD_init(); //lcd 初始化
clearscreen(0);
set_line(0);
display(0,0,4,wo); //我
