標(biāo)題: 按鍵檢測 [打印本頁]
作者: 2.31    時(shí)間: 2018-5-8 20:19
標(biāo)題: 按鍵檢測
#include "key.h"
void KEY_GPIO_Config(){
        RCC_APB2PeriphClockCmd(KEY1_G_GPIO_CLK,ENABLE);
        GPIO_InitStructure.GPIO_Pin=KEY1_G_GPIO_PIN;
        GPIO_InitStructure.GPIO_Mode=GPIO_Mode_IN_FLOATING;
        GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz;
         GPIO_Init(KEY1_G_GPIO_PORT, &GPIO_InitStructure);
uint8_t Key_Scan(GPIO_TypeDef * GPIOx,uint16_t GPIO_Pin){
        if(GPIO_ReadInputDataBit(GPIOx, GPIO_Pin)==KEY1_ON)
                return KEY1_ON;
                return KEY1_OFF;
作者: xiaoyu.    時(shí)間: 2018-5-18 15:18
獨(dú)立按鍵檢測程序
#include<reg52.h>
sbit dula=P2^6;
sbit wela=P2^7;
sbit K1=P3^4;
sbit K2=P3^5;
sbit K3=P3^6;
sbit K4=P3^7;
uchar code table[]={
0x3f,0x06,0x5b,0x4f,
0x66,0x6d,0x7d,0x07,
0x7f,0x6f,0x77,0x7c,
0x39,0x5e,0x79,0x71};
uint aa;
uchar num1,num2,shi1,ge1,shi2,ge2;
void delay(uint z)
        uint x,y;
        for(x=z;x>0;x--)
                for(y=110;y>0;y--);
void display(uchar num1,uchar num2)
        shi1=num1/10;
        ge1=num1%10;
        shi2=num2/10;
        ge2=num2%10;
        dula=1;
        P0=table[shi1];
        dula=0;
        P0=0xff;
        wela=1;
        P0=0xfe;
        wela=0;
        delay(1);
        dula=1;
        P0=table[ge1];
        dula=0;
        P0=0xff;
        wela=1;
        P0=0xfd;
        wela=0;
        delay(1);
        dula=1;
        P0=table[shi2];
        dula=0;
        P0=0xff;
        wela=1;
        P0=0xfb;
        wela=0;
        delay(1);
        dula=1;
        P0=table[ge2];
        dula=0;
        P0=0xff;
        wela=1;
        P0=0xf7;
        wela=0;
        delay(1);
void key()
        if(K1==0)
                delay(5);
                if(K1==0)
                        TR0=0;
                        while(!K1);
        if(K2==0)
                delay(5);
                if(K2==0)
                        if(num1==0)
                                num1=60;
                        num1--;
                        while(!K2);
        if(K3==0)
                delay(5);
                if(K3==0)
                        num1++;
                        if(num1>=60)
                                num1=num1-60;
                        while(!K3);
        if(K4==0)
                delay(5);
                if(K4==0)
                        TR0=1;
                        while(!K4);
void inint()
        TMOD=0x01;
        TH0=(65536-50000)/256;
        TL0=(65536-50000)%256;
        EA=1;
        ET0=1;
        TR0=1;
        inint();
                key();
                display(num1,num2);
void zhongduan()interrupt 1
        aa++;
        if(aa==20)
                aa=0;
                num2++;
                if(num2==60)
                        num2=0;
                        num1++;
                        if(num1==60)
                                num1=0;
