秒表程序
單片機(jī)小白1995
時(shí)間:
2018-5-8 15:24
秒表程序
* 程序說明 ;使數(shù)碼管依次顯示0-8
#include "io430.h"
#define KeyPort P1IN //獨(dú)立鍵盤接在P60~P63
#define CPU_F ((double)1000000)
#define DelayUs(x) __delay_cycles((long)(CPU_F*(double)x/1000000.0))
#define DelayMs(x) __delay_cycles((long)(CPU_F*(double)x/1000.0))
#define KEY1 1
#define KEY2 2
#define KEY3 3
#define KEY4 4
#define KEY5 5
uchar KeyScan(void);
#define SMG_DATA P4OUT //573位選信號(hào)的輸入管腳
#define SMG_WEI P5OUT
//#define CLK_H P6OUT|=BIT6 //595時(shí)鐘信號(hào)的輸入置高
//#define CLK_L P6OUT&=~BIT6 //595時(shí)鐘信號(hào)的輸入置低
//#define ST_H P6OUT|=BIT5 //595鎖存信號(hào)置高
//#define ST_L P6OUT&=~BIT5 //595鎖存信號(hào)置低
//#define DATA_H P6OUT|=BIT4 //595數(shù)據(jù)信號(hào)輸入置高
//#define DATA_L P6OUT&=~BIT4 //595數(shù)據(jù)信號(hào)置低
//#define LED_E0 P5OUT&=~BIT7 //數(shù)碼管 573使能置低
//#define LED_E1 P5OUT|=BIT6 //點(diǎn)陣 573使能置高
uchar uc7leds[17]={0x3f,0x06,0x5b,0x4f, //0,1,2,3,
0x66,0x6d,0x7d,0x07, //4,5,6,7,
0x7f,0x6f,0x77,0x7c, //8,9,A,b,
0x39,0x5e,0x79,0x71,0x00}; //C,d,E,F
uchar jishu=0;
uchar mode=1;
uchar downtime=1;
void PortInit();
uchar number[4] = {0,0,0,0};
void ClockInit();
void display();
void TimerAInit();
void fentime(int num);
void fenshu(int num);
uint b;
WDTCTL=WDTPW+WDTHOLD;
ClockInit(); //時(shí)鐘初始化
TimerAInit();
PortInit();
uchar jishi=0;
uchar keyvalue=0;
uchar zhu=1;
uchar wait=1;
uchar mode2start=0;
if(b==0)
keyvalue=KeyScan();
if(zhu==1)
if(keyvalue==5)
zhu=0;
if(keyvalue==4)
mode++;
if(mode==4)
mode=1;
number[0]=mode+9;
number[1]=16;
number[2]=16;
number[3]=16;
else if(mode==1)
if(wait)
fentime(0);
wait=0;
if(keyvalue==1)
jishi=!jishi;
if(jishi)
TACTL=TASSEL_1+MC_1+ID_3+TAIE;
TACTL=TASSEL_1+MC_0+ID_3+TAIE;
else if(mode==2)
if(!mode2start)
if(wait)
fentime(60);
wait=0;
if(keyvalue==4)
downtime++;
fentime(downtime*60);
if(keyvalue==1)
mode2start=1;
if(keyvalue==2)
jishi=0;
keyvalue=0;
zhu=1;
wait=1;
mode2start=0;
jishu=0;
mode=1;
downtime=1;
TACTL=TASSEL_1+MC_0+ID_3+TAIE+TACLR;
P2OUT_bit.P0=0;
display();
if(keyvalue!=0)
b=0x8fff;
keyvalue=0;
if(b!=0)
b--;
* PortInit()
* 功能說明 ;IO初始化
* 參數(shù) :無
* 返回值 :無
void PortInit()
P4SEL=0X00;//普通
P4DIR=0XFF;//輸出
P5SEL=0X00;//普通
P5DIR=0XF0;//輸出
P5OUT=0XFF;
P2SEL = 0x00; //設(shè)置IO口為普通I/O模式
P2DIR = 0x01; //設(shè)置IO口方向?yàn)檩敵?br /> P2OUT = 0x00; //初始設(shè)置為00,即都為低電平
P1SEL = 0x00;
P1DIR = 0x00;
P4OUT=uc7leds[0];
//P6SEL=0X00;
//P6DIR=0XFF;
//P5SEL=0X00;
//P5DIR=0XFF;
//LED_E1;
//LED_E0;
* TimerAInit()
* 功能說明 ;定時(shí)器A初始化
* 參數(shù) :無
* 返回值 :無
void TimerAInit()
TACTL=TASSEL_1+MC_0+ID_3+TAIE;//選擇ACK,增計(jì)數(shù)模式,8分頻,使能定時(shí)器中斷
CCR0=4095;
__enable_interrupt();
void ClockInit()
uchar i;
BCSCTL1&=~XT2OFF; //設(shè)置XT2為有效
BCSCTL2|=SELM1+SELS;
do{
IFG1&=~OFIFG; //清除振蕩器失效標(biāo)志
for(i=0;i<100;i++)
__no_operation();
}while((IFG1&OFIFG)!=0); //如果振蕩失效標(biāo)志存在則繼續(xù)循環(huán)
IFG1&=~OFIFG;
* TimerA()
* 功能說明 ;定時(shí)器A中斷處理程序
* 參數(shù) :無
* 返回值 :無
#pragma vector = TIMERA1_VECTOR
__interrupt void TimerA(void)
switch(TAIV)
case 2:break;
case 4:break;
case 10:
jishu++;
if(mode==1)
fentime(jishu);
else if(mode==2)
fentime(downtime*60-jishu);
if(!(downtime*60-jishu))
P2OUT_bit.P0=1;
break;
* uchar KeyScan(void)
* 功能說明 ;按鍵檢測
* 參數(shù) :無
* 返回值 :KeyNum:按下的按鍵值
uchar KeyScan(void)
uchar keycode;
static uchar sta=0; //不支持連續(xù)按
//uchar sta=0; //支持連按
uchar tmp=0;
P1DIR |= 0X1f;
P1OUT = 0X1f;
P1DIR &= 0xe0; //設(shè)置P10 P11 P12為輸入
if(sta==0) //sta=0 時(shí)檢測按鍵是否按下
if((P1IN&0X1f)!=0X1f) // 掃描按鍵
DelayMs(10);
if((P1IN&0X1f)!=0X1f) //確認(rèn)按鍵按下
keycode=(P1IN&0X1f);
switch(keycode) //確認(rèn)按鍵
case 0x1e:tmp=1;;break;
case 0x1d:tmp=2;;break;
case 0x1b:tmp=3;;break;
case 0x17:tmp=4;;break;
case 0x0f:tmp=5;;break;
default : ;break;
sta=1;
else if((P1IN&0X1f)!=0X1f) // 確定按鍵是否松開
DelayMs(10);
if((P1IN&0X1f)!=0X1f) //若是按鍵松開,sta = 0;
sta=0;
return tmp; //返回按下的按鍵數(shù)
number[0]=num%10;
number[1]=(num%100)/10;
number[2]=(num%1000)/10;
number[3]=num/1000;
number[0]=(num%60)%10;
number[1]=(num%60)/10;
number[2]=(num/60)%10;
number[3]=(num/60)/10;
void display() //數(shù)碼管顯示
static uchar i=0;
i++;
if(i >= 4)
i = 0;
P4OUT =0x00; //消隱
switch(i) //位選
case 3: SMG_WEI=0x10; break;
case 2: SMG_WEI=0x20; break;
case 1: SMG_WEI=0x40; break;
case 0: SMG_WEI=0x80; break;
P4OUT = uc7leds[number
