標題: OSRAM 車用頭燈最新LED OBF系列 [打印本頁] 作者: geopan 時間: 2018-5-6 17:31 標題: OSRAM 車用頭燈最新LED OBF系列 OSLON Black Flat S is able to meet a wide range of requirements. The SMT device is very stable, durable and can be used with standard processes. A new solder pad layout allows for high reliability and improved thermal management.The compact chips not only deliver high light output, they are also individually addressable with an ensured chip-to-chip contrast which makes this LED an ideal solution for Adaptive Driving Beam (ADB)
