單片機(jī)控制電力柜用操控狀態(tài)儀表程序源碼
[打印本頁(yè)]
dengzhen11
時(shí)間:
2018-5-5 12:47
前幾年做的操控狀態(tài)儀表,里邊有COG液晶,串口,按鍵,IO,溫濕度傳感器,EEPROM等等
對(duì)于單片機(jī)的初學(xué)者有幫助,可以了解單片機(jī)和外設(shè)工作的基本原理
和簡(jiǎn)單的數(shù)據(jù)處理,
(35.78 KB, 下載次數(shù): 125)
2018-5-5 15:28 上傳
全部資料51hei下載地址:
CaoKonog20120110.rar
(850.75 KB, 下載次數(shù): 28)
2018-5-5 12:47 上傳
點(diǎn)擊文件名下載附件
操控狀態(tài)
單片機(jī)源碼如下:
#include <iom64v.h>
#include <macros.h>
#include <string.h>
#include <stdlib.h>
#include <ctype.h>
#include <eeprom.h>
#include <math.h>
#include "IO.h"
#include "uart.h"
#include "lcd.h"
#include "key.h"
#include "sht.h"
#pragma data:data
unsigned char temp_flag=0;
unsigned char wd_shang;
unsigned char wd_xia;
unsigned char sd_shang;
unsigned char sd_xia;
unsigned char pf_shang;
unsigned char pf_xia;
unsigned char Body_Flag; //人體靠近帶電標(biāo)志位
unsigned char rt_gy; // 人體感應(yīng)非投入,1:投入,2:非投入
unsigned char db_du;
unsigned char InIt_Para[]={0x0a,0x05,0x5D,0x55,0x37,0x32,0x01,0x01};
unsigned char wd_bz;
unsigned char sd_bz;
unsigned char pf_bz;
unsigned char wendu1_biaozhi;
unsigned char wendu2_biaozhi;
unsigned char mima;
unsigned int R_ms_Timer,mincount1;
unsigned int timer_count;
unsigned char timer_count1;
unsigned char timer_count2;
unsigned char timer_count3;
unsigned char Cls_Lcd_Flag;
unsigned char GPIOSamp_counter_Flag;
unsigned char GPIOSamp_counter;
extern unsigned char bz; //位標(biāo)志
extern unsigned char bz1; //位標(biāo)志,判斷是地址還是數(shù)據(jù)
extern unsigned char di_zhi;
extern unsigned char Receiver_Flag; // 接受數(shù)據(jù)標(biāo)志
extern unsigned char Back_Light_Flag;
extern unsigned char rx0_buf[16]; // 接收數(shù)據(jù)緩存器
extern unsigned char rx0_index; // 接收數(shù)據(jù)計(jì)數(shù)器
extern unsigned char Tx0_buf[16]; // 發(fā)送數(shù)據(jù)緩存器
extern unsigned char R_KeyValue1;
//todao[0]:濕度測(cè)量 1; todao[1]: 溫度測(cè)量 1; todao[2]:濕度測(cè)量 2; todao[3]:溫度測(cè)量 2
extern float todao[4]; //{temp,rh}; 模擬量寄存器從1到2
extern unsigned char Q,n,TT1,T,TT2;
extern unsigned char ch,cl;
extern unsigned char Up_Counter;
extern unsigned char Page_Flag;
extern unsigned char Page_Flag1;
** 函數(shù)名稱:init_para()
** 函數(shù)功能:開機(jī)時(shí)取得、設(shè)定各項(xiàng)參數(shù)
** 入口參數(shù):
** 出口參數(shù):無(wú)
** 說(shuō) 明:
void init_para(void)
EEPROMReadBytes(0x0010,&wd_shang,1);
delay_nms(10);
EEPROMReadBytes(0x0011,&wd_xia,1);
delay_nms(10);
EEPROMReadBytes(0x0012,&sd_shang,1);
EEPROMReadBytes(0x0013,&sd_xia,1);
delay_nms(10);
EEPROMReadBytes(0x0014,&pf_shang,1);
EEPROMReadBytes(0x0015,&pf_xia,1);
EEPROMReadBytes(0x0016,&rt_gy,1);
EEPROMReadBytes(0x0017,&di_zhi,1);
* 函數(shù)名稱:EEprom_init()
* 入口參數(shù):
* 出口參數(shù):無(wú)
* 說(shuō) 明:
void EEprom_init(void)
unsigned char EEP_Read=0,Eep_Write=0;
EEPROMReadBytes(0x03,&EEP_Read,1);
if( EEP_Read != 0x55)
Eep_Write = 0x55;
EEPROMWriteBytes(0x0003,&Eep_Write,1);
EEPROMWriteBytes(0x0010,InIt_Para,8);
init_para();
init_para();
** 函數(shù)名稱:timer0_init()
** 函數(shù)功能:初始化定時(shí)器0,10ms定時(shí)器
** 入口參數(shù):無(wú)
** 出口參數(shù):無(wú)
** 說(shuō)明: 8位定時(shí)器,和8051相似,只是注意定時(shí)器時(shí)鐘是晶振分頻以后
void Timer0_init(void)
TCCR0 = 0x00;
ASSR = 0x00;
TCNT0 = 0xB1; // 定時(shí)初值 8Mhz
//TCNT0 = 0x93; // 定時(shí)初值 11Mhz
OCR0 = 0x00;
TCCR0 = 0x07; // 時(shí)鐘1024分頻 ,啟動(dòng)定時(shí)器
TIMSK |= 0x01; // timer0中斷使能
** 函數(shù)名稱:timer0_ovf_isr()
** 函數(shù)功能:定時(shí)器0溢出中斷服務(wù)程序
** 入口參數(shù):無(wú)
** 出口參數(shù):無(wú)
** 說(shuō)明:
#pragma interrupt_handler Timer0_ovf_isr:iv_TIMER0_OVF
void Timer0_ovf_isr(void)
TCNT0 = 0xB1;
R_ms_Timer++;
timer_count1++;
if(timer_count1>=4)
KeyValue_Pro();
timer_count1=0;
if(GPIOSamp_counter_Flag)
GPIOSamp_counter++;
if((Back_Light_Flag==1)&&((Body_Flag == 0)||(Body_Flag == 2))) // 液晶背光
mincount1++;
if(mincount1 >= Ldc_Timer ) // 30秒
mincount1 = 0;
DI_jdq5_ZHMIN_OUT1;
LCD_LED_OUT1;
if(Back_Light_Flag==0)
LCD_LED_OUT0;
DI_jdq5_ZHMIN_OUT0;
mincount1 = 0;
** 函數(shù)名稱:timer1_init()
** 函數(shù)功能:初始化定時(shí)器1
** 入口參數(shù):無(wú)
** 出口參數(shù):無(wú)
** 說(shuō)明:
** 16位定時(shí)器,和8051相似,只是注意定時(shí)器時(shí)鐘是晶振分頻以后
** TCNT1 = 65536 - (Focs X m) / 1024; m: 為定時(shí)時(shí)間,單位 s
** TCNT1分為TCNT1H和TCNT1L
void Timer1_init(void)
TCCR1B = 0x00; //stop
//TCNT1H = 0x0D5; //計(jì)數(shù)初值 , 定時(shí)為1秒 Focs = 11.0592Mhz
//TCNT1L = 0x0D0;
//TCNT1H = 0x02D; //計(jì)數(shù)初值 , 定時(shí)為5秒 Focs = 11.0592Mhz
//TCNT1L = 0x00F;
//TCNT1H = 0x0E1; //計(jì)數(shù)初值, 定時(shí)為1秒 Focs = 8Mhz
//TCNT1L = 0x07B;
TCNT1H = 0x0F0; //計(jì)數(shù)初值, 定時(shí)為0.5秒 Focs = 8Mhz
TCNT1L = 0x0BD;
OCR1AH = 0x98; // 輸出比較寄存器A初值
OCR1AL = 0x96;
OCR1BH = 0x98; // 輸出比較寄存器B初值
OCR1BL = 0x96;
ICR1H = 0x98; // 輸入捕獲寄存器初值
ICR1L = 0x96;
TCCR1A = 0x00; // 比較匹配模式禁止
TCCR1B = 0x05; // start Timer,時(shí)鐘分頻1024分頻
TIMSK |= 0x04; // timer1中斷使能
** 函數(shù)名稱:timer1_ovf_isr()
** 函數(shù)功能:定時(shí)器1溢出中斷服務(wù)程序
** 入口參數(shù):
** 出口參數(shù):無(wú)
** 說(shuō) 明:500ms
#pragma interrupt_handler Timer1_ovf_isr:iv_TIMER1_OVF
void Timer1_ovf_isr(void)
TCNT1H = 0x0F0;
TCNT1L = 0x0BD;
timer_count2++;
if((Page_Flag !=0))
timer_count3++;
if(timer_count3 >=60) // 一定時(shí)間內(nèi)沒(méi)有按鍵,強(qiáng)制返回溫濕度顯示頁(yè)面
timer_count3 = 0;
Cls_Lcd_Flag = 1;
if(timer_count2 >= 2) // 1.5秒重新檢測(cè)一次溫濕度
timer_count2 = 0;
temp_flag=1;
if(Body_Flag == 1) // 人體感應(yīng)設(shè)置為投時(shí),檢測(cè)到人體感應(yīng)時(shí)
LCD_LED_OUT0;
DI_jdq5_ZHMIN_OUT0;
timer_count = 0;
if(Body_Flag == 0) // 人體感應(yīng)設(shè)置為投時(shí),未檢測(cè)到人體感應(yīng)時(shí)
timer_count++;
if(timer_count >= Body_Timer ) // 1分鐘后關(guān)閉液晶背光
timer_count = 0;
LCD_LED_OUT1;
DI_jdq5_ZHMIN_OUT1;
** 函數(shù)名稱:QuanJu_Var_Init()
** 函數(shù)功能:全局變量初始化
** 入口參數(shù):
** 出口參數(shù):無(wú)
** 說(shuō) 明:
void QuanJu_Var_Init(void)
bz1 = 1;
T=15;
TT1=18;
TT2=18;
Q=n=ch=cl=0;
rx0_index = 0;
Up_Counter = 1;
Receiver_Flag = 0;
Back_Light_Flag = 1;
db_du =0x70;
Body_Flag = 0;
LCD_LED_OUT0;
memset(Tx0_buf,0,sizeof(Tx0_buf));
memset(rx0_buf,0,sizeof(rx0_buf));
memset(todao,0,sizeof(todao));
** 函數(shù)名稱:Hardware_Init()
** 函數(shù)功能:所有外設(shè)端口初始化
** 入口參數(shù):
** 出口參數(shù):無(wú)
** 說(shuō) 明:
void Hardware_Init(void)
//keyboard
PORTD |= 0x0f0; //輸入置為上拉
KY1_IN;
KY2_IN;
KY3_IN;
KY4_IN;
// 溫濕度
SHT10_SCK1_OUT;
SHT10_SDA1_OUT;
SHT10_SCK2_OUT;
SHT10_SDA2_OUT;
//LED燈
DI_led1_OUT;
DI_led2_OUT;
DI_led3_OUT;
DI_led4_OUT;
DI_led5_OUT;
DI_led6_OUT;
DI_led7_OUT;
DI_led8_OUT;
DI_led1_OUT0;
DI_led2_OUT1;
DI_led3_OUT0;
DI_led4_OUT0;
DI_led5_OUT0;
DI_led6_OUT0;
DI_led7_OUT0;
DI_led8_OUT1;
//繼電器
DI_jdq0_JRA_OUT;
DI_jdq1_JRB_OUT;
DI_jdq2_PF_OUT;
DI_jdq3_BJ_OUT;
DI_jdq4_BS_OUT;
DI_jdq5_ZHMIN_OUT;
DI_jdq0_JRA_OUT1;
DI_jdq1_JRB_OUT1;
DI_jdq2_PF_OUT1;
DI_jdq3_BJ_OUT1;
DI_jdq4_BS_OUT1;
DI_jdq5_ZHMIN_OUT1;
//語(yǔ)音
DI_yu_ying1_OUT;
DI_yu_ying2_OUT;
DI_yu_ying3_OUT;
DI_yu_ying4_OUT;
DI_yu_ying5_ZD_OUT;
DI_yu_ying1_OUT0;
DI_yu_ying2_OUT0;
DI_yu_ying3_OUT0;
DI_yu_ying4_OUT0;
DI_yu_ying5_ZD_OUT0;
//HC165輸入端口
HC165_SCK_OUT;
HC165_LD_OUT;
HC165_SD_IN;
PORTG |= 0x04;
// 人體感應(yīng)
Re_gyin_RT;
PORTD |= 0x01;
//LCD端口
LCD_DIR1_OUT;
LCD_DIR2_OUT;
LCD_CS_OUT;
LCD_RST_OUT;
LCD_RS_OUT;
LCD_RW_OUT;
LCD_ERW_OUT;
LCD_LED_OUT;
DDRA = 0xff; // PA為輸出
LCD_DIR1_OUT1;
LCD_DIR2_OUT1;
//RS485 接收發(fā)送選擇:接收
SET_485_EN_OUT;
SET_485_EN_OUT1;
DI_jdq5_ZHMIN_OUT0; //照明
** 函數(shù)名稱:main()
** 函數(shù)功能:
** 入口參數(shù):
** 出口參數(shù):無(wú)
** 說(shuō) 明:
void main(void)
CLI();
EEprom_init();
Hardware_Init();
uart0_init();
Timer0_init();
Timer1_init();
QuanJu_Var_Init();
Lcd_Init();
Temp_Humi_Init();
SEI();
Init_LcdDis();
//KeyValue_Pro();
if((Page_Flag1==1)&&(Page_Flag !=0))
Page_Flag1 = 0;
LCD_CLS();
if(Cls_Lcd_Flag)
Cls_Lcd_Flag = 0;
Page_Flag = 0;
LCD_CLS();
Up_Counter = 1;
Menu_Display();
if(temp_flag && (Page_Flag == 0)) // 由于溫度檢測(cè)測(cè)量時(shí)間較長(zhǎng)影響按鍵和通訊,只有在溫度顯示頁(yè)面才進(jìn)行溫度刷新
Temp_Humi_Init();
temp_flag=0;
Out_Logic();
Check_IO_Pra();
if(Receiver_Flag)
shuju_chuli();
clear_rx0_tx0_buf();
Receiver_Flag = 0;
…………限于本文篇幅 余下代碼請(qǐng)從51黑下載附件…………
