標(biāo)題: AVR驅(qū)動(dòng)COG液晶代碼 [打印本頁]
作者: dengzhen11    時(shí)間: 2018-5-5 12:06
#include <iom64v.h>
#include <macros.h>
#include "lcd.h"
#include "key.h"
#include "uart.h"
#pragma data:data
extern float   todao[4];
extern unsigned char wd_shang;
extern unsigned char wd_xia;
extern unsigned char sd_shang;
extern unsigned char sd_xia;
extern unsigned char pf_shang;
extern unsigned char pf_xia;
extern unsigned char Body_Flag;
extern unsigned char rt_gy;
extern unsigned char db_du;
extern unsigned char mima;
extern unsigned char InIt_Para[];
** 函數(shù)名稱:delay_nms()
** 函數(shù)功能:delay_nms:nms延時(shí)函數(shù)
** 入口參數(shù):
** 出口參數(shù):
** 說    明:
void delay_nms(unsigned int ms)
     unsigned int i;
         unsigned int j;
         for (i=0;i<ms;i++)
                   for(j=0;j<0x500;j++) ;
** 函數(shù)名稱:delay()
** 函數(shù)功能:186us
** 入口參數(shù):
** 出口參數(shù):
** 說    明:
void delay(unsigned int n)
        unsigned int i;
        for(i=0;i<=n;i++);
** 函數(shù)名稱: wcomd(unsigned char cdat)
** 函數(shù)功能: lcd寫命令
** 入口參數(shù): cdat:命令字
** 出口參數(shù): 無
** 說    明:
void wcomd(unsigned char cdat)
          LCD_CS_OUT0;                                    //CS低電平被激活
          LCD_RS_OUT0;                                    //RS=0寫的是命令
          LCD_RW_OUT0;                                    //上升沿?cái)?shù)據(jù)被鎖存
          LCD_ERW_OUT1;                                    //ERW=0低電瓶讀狀態(tài),ERW=1寫
      PORTA = cdat;
          delay(10);
          LCD_RW_OUT1;                                    //上升沿?cái)?shù)據(jù)被鎖存
                LCD_ERW_OUT0;                                    //ERW=0低電瓶讀狀態(tài),ERW=1寫
    LCD_CS_OUT1;
** 函數(shù)名稱: wdata(unsigned char cdat)
** 函數(shù)功能: lcd顯示數(shù)據(jù)
** 出口參數(shù): 無
** 說    明:寫的是顯示數(shù)據(jù)
void wdata(unsigned char ddat)
    LCD_RS_OUT1;                                       //RS=1寫的是顯示數(shù)據(jù)
    PORTA = ddat;
                delay(10);
                LCD_CS_OUT1;
** 函數(shù)名稱: LCD_CLS()
** 函數(shù)功能: LCD清屏
** 入口參數(shù): 無
** 出口參數(shù): 無
** 說    明:
void LCD_CLS(void)
  unsigned int i,j;
  for(j=0;j<16;j++)
    wcomd(j|0xb0);                  /*Set Page Address*/
    wcomd(0x10);                    /*Set Column Address   MSI*/
    wcomd(0x00);                    /*Set Column Address   LSI*/
    for(i=0;i<128;i++)
      wdata(0x00);
** 函數(shù)名稱:Lcd_Init()
** 函數(shù)功能:lcd對(duì)比度調(diào)整及l(fā)cd初始化
** 入口參數(shù):
** 出口參數(shù):無
** 說    明:
void Lcd_Init(void)
        LCD_RS_OUT1;
        LCD_CS_OUT1;
    LCD_RST_OUT0;
    delay_nms(1);
    LCD_RST_OUT1;
    delay_nms(1);
    wcomd(0x48);      //* duty 占空比設(shè)置*
    wcomd(128);        //* duty 一次更新96行 占空比1/96 *
    wcomd(0xa0);      //* 左右反轉(zhuǎn) ADC=1: SEG reverse direction         SEGMENT方向設(shè)置: 7FH 到 00H 為正向  map or Re-map
    wcomd(0xc8);      //* 上下反轉(zhuǎn)SHL=0: COM normal direction COM輸出方向設(shè)置: COM0 →COM127 為?
    wcomd(0x44);      //* com0 register 設(shè)置COM0顯示的起始行*
    wcomd(0x00);      //* com0 register PAGE2 為COM0起始顯示行*
    wcomd(0x40);      //set start line
    wcomd(0xab);      //* oscilator start 晶振開始 *
    wcomd(0x66);      //* Set 6 dc-dc step-up   DC到 DC變換6倍升壓 62*
    wcomd(0x24);      //* Internal Regulator Resistor Ratio 內(nèi)部調(diào)壓電阻比率*
    wcomd(0x81);      //* Set white mode and 1st/2nd frame
    wcomd(0x20);      //* gray scal register1
    wcomd(0x53);          //清晰度53
    wcomd(0x94);      //  3FRC,9PWM; 0x94  //
    wcomd(0x88);      //* Set white mode and 1st/2nd frame *
    wcomd(0x00);      //* gray scal register1 *
    wcomd(0x89);      //* Set White Mode, Frame 4th, Frame 3rd *
    wcomd(0x8a);      //* Set Dark Mode, Frame 4th & Frame 3rd *
    wcomd(0x8b);      //* Set Dark Mode, Frame 4th & Frame 3rd *
    wcomd(0x8c);      //* Set Dark Mode, Frame 4th & Frame 3rd *
    wcomd(0x99);      //* gray scal register1 *
    wcomd(0x8d);      //* Set Dark Mode, Frame 4th & Frame 3rd *
    wcomd(0x8e);      //* Set Dark Mode, Frame 4th & Frame 3rd *
        wcomd(0x8f);      //* Set Dark Mode, Frame 4th & Frame 3rd *
    wcomd(0x09);      //* gray scal register1 *
    wcomd(0x2c);      //* Set-power VC *
    delay_nms(10);
    wcomd(0x2e);      //* Set-power VC VR *
    delay_nms(10);
    wcomd(0x2f);      //* Set-power VC VR VF *
    delay_nms(10);
    wcomd(0xaf);     //open display
    LCD_CLS();
