STM32F103_485參考程序 源碼
gwq66
2018-4-28 15:22
STM32F103_485單片機源程序如下:
#include "e070.h"
//***********************內部全局變量聲明**********************************//
uint8_t eviewworkdata[300];
uint8_t eviewbuffer[300];
uint8_t eviewreadbuffer[12][300];
uint8_t out5buffer[300];
uint8_t UART5_RX_BUF[300];
uint16_t CheckOUT;
uint16_t shezhicanshu; //用于進入設置狀態
//***************************聲明結束***************************************//
//***********************調用外部函數聲明***********************************//
extern uint8_t gcode[8][200];
extern uint16_t wailiangdu,neiliangdu,LAMP_addr,LAMP_term;
extern uint16_t Bad_Num;
extern uint8_t yadangshuju[40];
extern uint8_t yadangshuju111[40];
extern uint8_t TPWM1,TPWM2;
extern uint8_t checkNum,wTpwm1,rTpwm2,goodNum;
uint8_t E070CONT1,E070CONT2,E070CONT3,E070CONT4;
extern osSemaphoreId Uart5RSemHandle; //串口接收完成信號量
extern osSemaphoreId Uart5WSemHandle; //串口發送完成信號量
void SCI5_Term(void)
UART5_trsmet_workdata();
UART5_read(3000);
UART5_read(3300);
UART5_read(3600);
UART5_read(3900);
UART5_read(4200);
UART5_read(4500);
UART5_read(4800);
UART5_read(5100);
UART5_read_sys(2000);
UART5_read_contr(2300);
if((eviewreadbuffer[0][150]*256 + eviewreadbuffer[0][151]) == 1111) EVIEW_EEPROM(0);
if((eviewreadbuffer[1][150]*256 + eviewreadbuffer[1][151]) == 1111) EVIEW_EEPROM(1);
if((eviewreadbuffer[2][150]*256 + eviewreadbuffer[2][151]) == 1111) EVIEW_EEPROM(2);
if((eviewreadbuffer[3][150]*256 + eviewreadbuffer[3][151]) == 1111) EVIEW_EEPROM(3);
if((eviewreadbuffer[4][150]*256 + eviewreadbuffer[4][151]) == 1111) EVIEW_EEPROM(4);
if((eviewreadbuffer[5][150]*256 + eviewreadbuffer[5][151]) == 1111) EVIEW_EEPROM(5);
if((eviewreadbuffer[6][150]*256 + eviewreadbuffer[6][151]) == 1111) EVIEW_EEPROM(6);
if((eviewreadbuffer[7][150]*256 + eviewreadbuffer[7][151]) == 1111) EVIEW_EEPROM(7);
if((eviewreadbuffer[8][150]*256 + eviewreadbuffer[8][151]) == 1111) EVIEW_EEPROM_SYS();
if((eviewreadbuffer[9][150]*256 + eviewreadbuffer[9][151]) == 1111) EVIEW_CONTRL();
/*函數名稱:觸摸屏 控制單燈或一組燈或全線測試 */
/*功能描述: */
/*返 回: */
/*2016年10月12日測試 */
void EVIEW_CONTRL(void)
uint8_t scope = 0;
uint8_t group = 0;
uint16_t AddL = 1; //地址下限
uint16_t AddH = 10; //地址上限
uint16_t LX; //亮度
uint8_t BuffData[11];
if((eviewreadbuffer[9][148]*256 + eviewreadbuffer[9][149]) == 6666)
E070CONT1 = 66;
UART5_write_two_word(2372,TPWM1,TPWM2);
else if((eviewreadbuffer[9][148]*256 + eviewreadbuffer[9][149]) == 7777)
E070CONT1 = 77;
LAMP_addr = eviewreadbuffer[9][0]*256+eviewreadbuffer[9][1];
TPWM1 = eviewreadbuffer[9][3];
TPWM2 = eviewreadbuffer[9][5];
else if((eviewreadbuffer[9][148]*256 + eviewreadbuffer[9][149]) == 8888)
E070CONT1 = 88;
LAMP_term = eviewreadbuffer[9][7];
TPWM1 = eviewreadbuffer[9][9];
TPWM2 = eviewreadbuffer[9][11];
E070CONT1 = 0;
if((eviewreadbuffer[9][146]*256 + eviewreadbuffer[9][147]) == 12345)
for(group = 0;group <= 14;group = group + 2)
BuffData[0] = AddL >> 8;
BuffData[1] = AddL;
BuffData[2] = AddH >> 8;
BuffData[3] = AddH;
write_add_char(group,0,BuffData,4);
AddL = AddH + 1;
AddH = AddH + 10;
LX = 5; //亮度下限
for(scope = 0;scope <= 24;scope++) //24個檔位
BuffData[0] = LX >> 8;
BuffData[1] = LX;
BuffData[2] = scope*4 + group + 1;
BuffData[3] = scope*3 + group + 1;
write_add_char(group,0X04 + 4*scope,BuffData,4);
LX = LX + 100 + scope + group; //將65000數值24等分
BuffData[0] = 0x02;BuffData[1] = 0x05;BuffData[2] = 0x00;BuffData[3] = 0x00;
BuffData[4] = 0x0a;BuffData[5] = 0x00;BuffData[6] = 0x01;BuffData[7] = 0x04;
BuffData[8] = 0x57;BuffData[9] = 0x00;BuffData[10] = 0x10;
write_add_char(0,150,BuffData,11);
UART5_write_one_word(2373,54321);
/*函數名稱:觸摸屏 向24C16寫 系統參數 */
/*功能描述: */
/*返 回: */
/*2016年10月11日測試通過 */
void EVIEW_EEPROM_SYS(void)
uint8_t BuffData[4] = {22,22,0x08,0xae};
write_add_char(0,150,&eviewreadbuffer[8][1],1); //地址
write_add_char(0,151,&eviewreadbuffer[8][3],1); //滯環參數,默認0.5
write_add_char(0,152,&eviewreadbuffer[8][5],9);
write_add_char(0,98,BuffData,4); //3075 0X08AE=2222
UART5_write_one_word(2075,2222);
/*函數名稱:觸摸屏向2416寫數字,一次寫入一屏的參數 */
/*功能描述: */
/*返 回 */
/*2016年9月30日測試通過 */
void EVIEW_EEPROM(uint8_t group2)
uint8_t scope2 ;
uint16_t eview_data_addr;
if(group2 == 0) eview_data_addr = 3000;
if(group2 == 1) eview_data_addr = 3300;
if(group2 == 2) eview_data_addr = 3600;
if(group2 == 3) eview_data_addr = 3900;
if(group2 == 4) eview_data_addr = 4200;
if(group2 == 5) eview_data_addr = 4500;
if(group2 == 6) eview_data_addr = 4800;
if(group2 == 7) eview_data_addr = 5100;
write_add_char(2*group2,0X00,&(eviewreadbuffer[group2][2]),4);
for(scope2=0;scope2<=24;scope2++) //24個檔位
write_add_char(2*group2,0X04+4*scope2,&(eviewreadbuffer[group2][6+6*scope2]),4);
write_add_char(2*group2,98,BuffData,4);
eviewreadbuffer[group2][150] = 0x08; //只寫一遍
eviewreadbuffer[group2][151] = 0xAE;
UART5_write_one_word(eview_data_addr + 75,2222);
/*函數名稱:從觸摸屏讀控制單燈或一組燈或全線測試數據 */
/*功能描述: */
/*返 回: */
/*2016年10月12日測試 */
void UART5_read_contr(uint16_t eview_data_addr)
uint8_t i;
out5buffer[0] = 0x01;
out5buffer[1] = 0x03;
out5buffer[2] = eview_data_addr >> 8;
out5buffer[3] = eview_data_addr; //發送起始地址
out5buffer[4] = 0;
out5buffer[5] = 80; //查詢64個字,128個字節
CheckOUT = CRC_Check(out5buffer,6);
out5buffer[6] = CheckOUT;
out5buffer[7] = CheckOUT >> 8;
HAL_GPIO_WritePin(GPIOB, GPIO_PIN_13, GPIO_PIN_RESET);
HAL_GPIO_WritePin(GPIOB, GPIO_PIN_13, GPIO_PIN_RESET); //RS485狀態變為發送
HAL_UART_Transmit_IT(&huart5,out5buffer,8); //數據發送
osSemaphoreWait(Uart5WSemHandle,100); //等待發送完成信號量
HAL_GPIO_WritePin(GPIOB, GPIO_PIN_13, GPIO_PIN_SET);
HAL_GPIO_WritePin(GPIOB, GPIO_PIN_13, GPIO_PIN_SET); //RS485狀態變為接收
HAL_UART_Receive_IT(&huart5,UART5_RX_BUF,165); //接收數據
osSemaphoreWait(Uart5RSemHandle,100); //等待接收完成信號量,等待時間<100ms
if(UART5_RX_BUF[0] == 0x01 && UART5_RX_BUF[1] == 0x03)
for(i=0;i<160;i++)
eviewreadbuffer[9][i] = UART5_RX_BUF[3 + i]; //eviewreadbuffer有用的數據0,1到126,127
UART5_RX_BUF[0] = 0;
UART5_RX_BUF[1] = 0;
/*函數名稱:從觸摸屏讀系統參數 */
/*功能描述: */
/*返 回: */
void UART5_read_sys(uint16_t eview_data_addr)
uint8_t i;
out5buffer[4] = 0;
out5buffer[5] = 80; //查詢80個字,160個字節
for(i = 0;i < 160;i++)
eviewreadbuffer[8][i] = UART5_RX_BUF[3 + i]; //eviewreadbuffer有用的數據0,1到126,127
/*函數名稱:從觸摸屏讀取80個字的數據 */
/*功能描述: */
/*返 回: */
/*2016年12月12日測試通過 */
void UART5_read(uint16_t eview_data_addr)
uint8_t i,group;
group = (eview_data_addr - 3000) / 300; //0表示讀出的第一組數據,1表示第二組
out5buffer[2] = eview_data_addr>>8;
out5buffer[4] = 0;
osSemaphoreWait(Uart5WSemHandle,50); //等待發送完成信號量,等待時間<50ms
osSemaphoreWait(Uart5RSemHandle,50); //等待接收完成信號量,等待時間<50ms
eviewreadbuffer[group][i] = UART5_RX_BUF[3+i]; //eviewreadbuffer有用的數據0,1到126,127
UART5_RX_BUF[0]=0;
UART5_RX_BUF[1]=0;
/*函數名稱:發送一組數據到觸摸屏 */
/*功能描述:發送一組數據到觸摸屏,初始化時向觸摸屏一組一組發送數據 */
/*返 回: */
/*2016年9月22日測試通過 */
/*功能參數:EVIEW中的首地址、發送數量、第幾組燈數據 */
void UART5_trsmet_term(uint16_t eview_data_addr,uint8_t number,uint8_t group)
eviewbuffer[0] = 0x01; //前4位為固定字節
eviewbuffer[1] = 0x10;
eviewbuffer[2] = eview_data_addr >> 8;
eviewbuffer[3] = eview_data_addr; //發送起始地址
eviewbuffer[4] = 0x00;
eviewbuffer[5] = number; //發送字的個數
eviewbuffer[6] = number * 2; //發送字節數
eview_eeprom_data(group); //eviewbuffer[7]到eviewbuffer[245]由此函數填充
eviewbuffer[246] = 246;
CheckOUT = CRC_Check(eviewbuffer,247);
eviewbuffer[247] = CheckOUT;
eviewbuffer[248] = CheckOUT>>8;
HAL_UART_Transmit_IT(&huart5,eviewbuffer,249); //數據發送
osDelay(30); //等待屏幕處理
HAL_UART_Receive_IT(&huart5,&UART5_RX_BUF[0],1); //偽接收,清空串口接收緩沖區
/*函數名稱:發送一組 控制 99數據到觸摸屏 */
/*功能描述:發送一組數據到觸摸屏,填充控制頁面 */
/*返 回: */
void UART5_trsmet_contral(uint16_t eview_data_addr)
uint8_t j;
for(j = 0;j < 250;j = j+2)
eviewbuffer[j] = 9;
eviewbuffer[j+1] = 0;
eviewbuffer[5] = 80; //發送字的個數
eviewbuffer[6] = 160; //發送字節數
eviewbuffer[248] = CheckOUT >> 8;
/*功能描述:發送系統數據到觸摸屏 */
/*返 回: */
/*2016年9月22日測試通過 */
/*EVIEW中的首地址、發送數量、第幾組燈數據 */
void UART5_trsmet_SYS(uint16_t eview_data_addr,uint8_t number)
uint8_t j;
for(j=0;j<250;j++)
eviewbuffer[j]=0;
eviewbuffer[2] = eview_data_addr>>8;
eviewbuffer[7] = 0;
eviewbuffer[8] = gcode[0][150]; //主機地址,默認01
eviewbuffer[9] = 0;
eviewbuffer[10] = gcode[0][151]; //滯環參數,默認0.5
eviewbuffer[11] = 0;
eviewbuffer[12] = gcode[0][152]; //調光方式,0為有級
eviewbuffer[13] = gcode[0][153]; //參數a
eviewbuffer[14] = gcode[0][154];
eviewbuffer[15] = gcode[0][155]; //參數b
eviewbuffer[16] = gcode[0][156];
eviewbuffer[17] = gcode[0][157]; //duchuanganqi;判斷哪個主機讀取傳感器
eviewbuffer[18] = gcode[0][158];
eviewbuffer[19] = gcode[0][159]; //繼電器動作值,默認16
eviewbuffer[20] = gcode[0][160];
osSemaphoreWait(Uart5RSemHandle,100); //等待發送完成信號量
/*函數名稱:發送工作數據到觸摸屏 */
/*功能描述:發送一組數據到觸摸屏 */
/*返 回: */
/*2016年9月23日測試通過 */
void UART5_trsmet_workdata(void)
uint8_t i,group,MAaddr_Temp; //計數器,組別,地址
uint8_t WPWM[10],RPWM[10]; //白色PWM,紅色PWM
uint16_t qliangdu,liangdu,kongzhiliang_Temp;
kongzhiliang_Temp = wailiangdu;
MAaddr_Temp = gcode[0][150];
eviewworkdata[0] = 0x01;
eviewworkdata[1] = 0x10;
eviewworkdata[2] = 0;
eviewworkdata[3] = 0; //發送起始地址
eviewworkdata[4] = 0x00;
eviewworkdata[5] = 44; //發送字的個數
eviewworkdata[6] = 88; //發送字節數
HAL_UART_Transmit_IT(&huart5,eviewworkdata,97); //數據發送
/*函數名稱:向觸摸屏寫1個字的數據 */
/*功能描述: */
/*返 回: */
/*2016年9月30日測試通過 */
void UART5_write_one_word(uint16_t eview_data_addr,uint16_t data)
out5buffer[1] = 0x06;
out5buffer[3] = eview_data_addr; //發送地址
out5buffer[4] = data >> 8;
out5buffer[5] = data;
/*函數名稱:向觸摸屏寫2個字的數據 */
/*功能描述: */
/*返 回: */
/*2016年9月30日測試通過 */
void UART5_write_two_word(uint16_t eview_data_addr,uint16_t data1,uint16_t data2)
out5buffer[1] = 0x10;
out5buffer[4] = 0;
out5buffer[5] = 2;
out5buffer[6] = 4;
out5buffer[7] = data1 >> 8;
out5buffer[8] = data1;
out5buffer[9] = data2 >> 8;
out5buffer[10] = data2;
CheckOUT = CRC_Check(out5buffer,11);
out5buffer[11] = CheckOUT;
out5buffer[12] = CheckOUT >> 8;
HAL_UART_Transmit_IT(&huart5,out5buffer,13); //數據發送
/*函數名稱:將24C16中的2維數組變成一維 */
/*功能描述:讀取AT24C16中的數據,共8組,每組5*24+4=124字節 */
/*返 回: */
/*2016年9月22日測試通過 */
void eview_eeprom_data(uint8_t group)
uint8_t scope;
eviewbuffer[7] = 0;
eviewbuffer[8] = group+1; //顯示第幾組燈
eviewbuffer[9] = gcode[group][0]; //地址下限的高字節
eviewbuffer[10] = gcode[group][1]; //地址下限的低字節
eviewbuffer[11] = gcode[group][2]; //地址上限的高字節
eviewbuffer[12] = gcode[group][3]; //地址上限的低字節
for(scope=0;scope<=24;scope++)
eviewbuffer[6*scope+13] = gcode[group][0X04+4*scope]; //亮度下限的高字節
eviewbuffer[6*scope+14] = gcode[group][0X05+4*scope]; //亮度下限的低字節
eviewbuffer[6*scope+15] = 0;
eviewbuffer[6*scope+16] = gcode[group][0X06+4*scope]; //亮度上限的高字節
eviewbuffer[6*scope+17] = 0;
eviewbuffer[6*scope+18] = gcode[group][0X07+4*scope]; //亮度上限的低字節
STM32_485參考程序.rar
(3.67 KB, 下載次數: 28)
2018-4-28 15:21 上傳
STM32_485參考程序
admin
2018-4-28 17:40
缺少頭文件,與原理圖 望補齊后評分
oyfmzyf
2018-10-9 15:22
這個包含的頭文件是自己寫的嗎?還是寫錯了?
canfly
2019-4-15 22:36
感謝樓主分享,學習了!
