PCB設(shè)計中專業(yè)英譯術(shù)語之綜合詞匯
板兒妹0517
2018-4-27 09:34
1. 板:board
2. 印制板:printed board
3. 印制電路:printed circuit
4. 印制線路:printed wiring
5. 印制線路板:printed wiring board(PWB)
6. 印制板電路:printed circuit board (PCB)
7. 印制接點:printed contact
8. 印制組件:printed component
9. 印制板裝配:printed board assembly
10. 單面印制板:single-sided printed board(SSB)
11. 雙面印制板:double-sided printed board(DSB)
12. 多層印制板:mulitlayer printed board(MLB)
13. 多層印制電路板:mulitlayer printed circuit board
14. 多層印制線路板:mulitlayer prited wiring board
15. 剛性印制板:rigid printed board
16. 剛性單面印制板:rigid single-sided printed borad
17. 剛性雙面印制印制板裝配:printed board assembly
18. 剛性多層印制板:rigid multilayer printed board
19. 撓性多層印制板:flexible multilayer printed board
20. 撓性印制板:flexible printed board
21. 撓性單面印制板:flexible single-sided printed board
22. 撓性雙面印制板:flexible double-sided printed board
23. 撓性印制電路:flexible printed circuit (FPC)
24. 撓性印制線路:flexible printed wiring
25. 剛性印制板:flex-rigid printed board, rigid-flex printed board
26. 剛性雙面印制板:flex-rigid double-sided printed board, rigid-flex double-sided printed
27. 剛性多層印制板:flex-rigid multilayer printed board, rigid-flex multilayer printed board
28. 齊平印制板:flush printed board
29. 金屬芯印制板:metal core printed board
30. 金屬基印制板:metal base printed board
31. 多重布線印制板:mulit-wiring printed board
32. 陶瓷印制板:ceramic substrate printed board
33. 導(dǎo)電膠印制板:electroconductive paste printed board
34. 模塑電路板:molded circuit board
35. 模壓印制板:stamped printed wiring board
36. 順序?qū)訅憾鄬佑≈瓢澹簊equentially-laminated mulitlayer
37. 散線印制板:discrete wiring board
38. 微線印制板:micro wire board
39. 積層印制板:buile-up printed board
40. 積層多層印制板:build-up mulitlayer printed board (BUM)
41. 積層撓印制板:build-up flexible printed board
42. 表面層合電路板:surface laminar circuit (SLC)
43. 埋入凸塊連印制板:B2it printed board
44. 多層膜基板:multi-layered film substrate(MFS)
45. 層間全內(nèi)導(dǎo)通多層印制板:ALIVH multilayer printed board
46. 載芯片板:chip on board (COB)
47. 埋電阻板:buried resistance board
48. 母板:mother board
49. 子板:daughter board
50. 背板:backplane
51. 裸板:bare board
52. 鍵盤板夾心板:copper-invar-copper board
53. 動態(tài)撓性板:dynamic flex board
54. 靜態(tài)撓性板:static flex board
55. 可斷拼板:break-away planel
56. 電纜:cable
57. 撓性扁平電纜:flexible flat cable (FFC)
58. 薄膜開關(guān):membrane switch
59. 混合電路:hybrid circuit
60. 厚膜:thick film
61. 厚膜電路:thick film circuit
62. 薄膜:thin film
63. 薄膜混合電路:thin film hybrid circuit
64. 互連:interconnection
65. 導(dǎo)線:conductor trace line
66. 齊平導(dǎo)線:flush conductor
67. 傳輸線:transmission line
68. 跨交:crossover
69. 板邊插頭:edge-board contact
70. 增強板:stiffener
71. 基底:substrate
72. 基板面:real estate
73. 導(dǎo)線面:conductor side
74. 組件面:component side
75. 焊接面:solder side
76. 印制:printing
77. 網(wǎng)格:grid
78. 圖形:pattern
79. 導(dǎo)電圖形:conductive pattern
80. 非導(dǎo)電圖形:non-conductive pattern
81. 字符:legend
82. 標志:mark
