標題: 超聲波倒車語音報警 [打印本頁]
作者: muxiaolin    時間: 2018-4-25 17:32
標題: 超聲波倒車語音報警
#include "STC12C5A.H"
#include "lcd1602.h"
#include "delay.h"
#include "string.h"
#include "typedef.h"
#include "key.h"
#include "mp3_uart.h"
#include "24c02.h"
sbit BUZZER = P2^0;   //蜂鳴器
sbit RLED = P1^0;   //紅燈
sbit GLED = P1^1;   //綠燈
sbit TX1=P1^2;
sbit RX1=P1^3;
unsigned char OverFlag=0;
unsigned int  Distance=0;
unsigned int  AlarmDistance=20;
unsigned char AutoFlag=0;
uint  Speed=0;
uint  AlarmSpeed=80;
unsigned char  Page=0;
unsigned int  Pulse=0;  //測速脈沖數
sbit INA=P3^4;
extern unsigned char PlayFlag;
void Timer0_Init(void);  //1毫秒@11.0592MHz
void Timer1_Init(void);     //定時器1初始化
void GetDistance(void);     //超聲波測距
void DistanceCheck(void);   //測距函數
void UART_Init(void);       //串口初始化
void PageInit(void);
void DataLoad(void);
void PageDisplay(void);
void PlayCheck(void)
static unsigned char con=0;
static unsigned char T50MS=0;
static unsigned char TINT=0;
if(KeyVal=='S')
  KeyVal=0;
  AutoFlag=(AutoFlag==1)?0:1;
if(AutoFlag)
  GLED=0;
  GLED=1;
if(AutoFlag)
  con++;
if(con>=80)
   con=0;
   MP3_UART_Send_Cmd(0x41,15);  //速度
   if(Speed==0)
     MP3_UART_Send_Cmd(0x41,1);  //速度
    MP3_UART_Send_Cmd(0x41,Speed/10+1);  //速度
    MP3_UART_Send_Cmd(0x41,Speed%10+1);  //速度
    MP3_UART_Send_Cmd(0x41,14);  //距離
    MP3_UART_Send_Cmd(0x41,Distance/100+1);
    MP3_UART_Send_Cmd(0x41,12);  //點
    MP3_UART_Send_Cmd(0x41,Distance%100/10+1);
    MP3_UART_Send_Cmd(0x41,Distance%10+1);
    MP3_UART_Send_Cmd(0x41,13);
/*----------------------------小于50每10里面播報一次------------------------------------------------*/
if((TINT==0)&&(Distance%10==0)&&(Distance<51)&&(Distance>0))
    TINT=1;
if(TINT>0)
  TINT++;
  if(TINT>=30)
   TINT=0;
/*------------------------距離太近請停車播報---------------------------------------*/
if((Distance<=10)&&(T50MS==0)&&(Distance>0))
  MP3_UART_Send_Cmd(0x41,16);
  T50MS=1;
if(T50MS>0)
  T50MS++;
  if(T50MS>=20)
   T50MS=0;
if((Distance<AlarmDistance)&&(Distance>0))
  BUZZER=0;
  RLED=0;
  BUZZER=1;
  RLED=1;
void main(void)
  Delay_1ms(500);
  LCD_Init();    //LCD顯示初始化
  PageInit();    //頁面顯示初始化
  Timer0_Init();   //計數器0初始化
  Timer1_Init();   //定時器1初始化
  DataLoad();    //報警數據讀出
  UART_Init();     //串口初始化
  MP3_UART_SetVic(23);
  Delay_1ms(200);
  PageDisplay();    //頁面顯示
  PlayCheck();
  GetDistance();
  Delay_1ms(50);    //延時50毫秒
void UART_Server() interrupt 4   //串口接收中斷
    unsigned char ch=0;
    EA=0;
if(RI)
   ch = SBUF;
   if(ch=='S'||ch=='T'||ch=='P')
   PlayFlag=0;
   RI = 0;
EA=1;
void Timer0_ISR(void) interrupt 1   //1毫秒@11.0592MHz
static unsigned char sta=0;
static unsigned int  T1MS=0;
static unsigned char KS=0;
TL0 = 0xCD;  //設置定時初值
TH0 = 0xD4;  //設置定時初值
T1MS++;
if(T1MS>=1000)
  T1MS=0;
  Speed=Pulse/2;
  Pulse=0;
KS++;
if(KS>=20)
  KS=0;
  KEY_Scan();
switch(sta)
  case 0:
     if(INA==0)
     sta=1;
     sta=0;
    }break;
  case 1:
     if(INA==0)
     sta=2;
     Pulse++;
     sta=0;
    }break;
  case 2:
     if(INA==0)
     sta=2;
     sta=0;
    }break;
  default:sta=0;break;
void Timer0_Init(void)  //1毫秒@11.0592MHz
AUXR |= 0x80;  //定時器時鐘1T模式
TMOD &= 0xF0;  //設置定時器模式
TMOD |= 0x01;  //設置定時器模式
TF0 = 0;  //清除TF0標志
TR0 = 1;  //定時器0開始計時
ET0=1;
EA=1;
PCON &= 0x7F;  //波特率不倍速
SCON = 0x50;  //8位數據,可變波特率
AUXR |= 0x04;  //獨立波特率發生器時鐘為Fosc,即1T
BRT = 0xDC;  //設定獨立波特率發生器重裝值
AUXR |= 0x01;  //串口1選擇獨立波特率發生器為波特率發生器
AUXR |= 0x10;  //啟動獨立波特率發生器
ES = 1;
EA=1;
TMOD = (TMOD&0x0f)| 0x10;
TL1 = 0x00;  //設定定時初值
TH1 = 0x00;  //設定定時器重裝值
ET1 = 1;  //禁止定時器0中斷
TR1 = 0;  //啟動定時器0
EA=1;
    unsigned int retry=0;
unsigned int time=0;
float S=0;
    TR1 = 0;
    OverFlag=0;
    TX1 = 1;
    delay_1us(3);
    TX1 = 0;
    while(!RX1);
    TH1=0;
    TL1=0;
    TR1 = 1;
    retry=0;
    while((RX1==1)&&(OverFlag==0)&&(retry<50000))
      retry++;
   delay_1us(1);
    TR1 = 0;
/*--------------計算---------------------*/
    time=TH1*256+TL1;
    TH1=0;
    TL1=0;
    if(OverFlag==0)     //沒有溢出
        S=(time*1.7)/100;     //算出來是CM
  if(S>300)
   S=0;
      S=0;
Distance=S;
  con++;
  if(con>20)
    con=0;
    DistanceCheck();
void DataLoad(void)
U16_Read(&AlarmSpeed,0);
Delay_1ms(50);
U16_Read(&AlarmDistance,10);
void PageInit(void)
LCD_Clr();
switch(Page)
  case 0:  //速度和距離同時顯示
       LCD_DispStr( 0,"Speed:      cm/s");
   LCD_DispStr(16,"Dis:        cm");
    }break;
  case 1:   //顯示距離  和設置距離
        LCD_DispStr( 0,"Dis:       cm");
   LCD_DispStr(16,"Set:       cm");
    }break;
  case 2: //顯示速度 和設置速度
   LCD_DispStr(16,"Alarm:      cm/s");
    }break;
  default:break;
/*---------------頁面切換----------------*/
if(KeyVal=='E')
  KeyVal=0;
  Page++;
  if(Page>2)
    Page=0;
  PageInit();
switch(Page)
  case 0://速度和距離同時顯示
     LCD_DispU16( 6,Speed);
   if(Distance>0)
    LCD_DispU16(22,Distance);
       LCD_DispStr(22,"-----");
    }break;
   if(Distance>0)
    LCD_DispU16( 6,Distance);
       LCD_DispStr(6,"-----");
         LCD_DispU16(22,AlarmDistance);
   if(KeyVal=='+')
    KeyVal=0;
    AlarmDistance++;
    U16_Save(&AlarmDistance,10);
   if(KeyVal=='-')
    KeyVal=0;
    if(AlarmDistance>2)
    AlarmDistance--;
    }break;
      LCD_DispU16(22,AlarmSpeed);
    if(KeyVal=='+')
     KeyVal=0;
     AlarmSpeed++;
     U16_Save(&AlarmSpeed,0);
    if(KeyVal=='-')
     KeyVal=0;
     if(AlarmSpeed>2)
     AlarmSpeed--;
    }break;
  default:
     Page=0;
   PageInit();
    }break;
