單片機數字溫度計proteus設計資料
012
2018-4-13 10:45
單片機數字溫度計proteus設計資料
數字溫度計
(19.06 KB, 下載次數: 18)
2018-4-13 15:59 上傳
(55.05 KB, 下載次數: 19)
2018-4-13 15:59 上傳
#include<reg51.h>
sbit DS=P2^4;
uint temp;
int tempnew;
uchar a,b,test;
char num,temphigh=35,templow=1;
uchar code s7_table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x39,0x40};
uchar code s7_table1[]={0xbf,0x86,0xdb,0xcf,0xe6,0xed,0xfd,0x87,0xff,0xef};
uchar weishidisplay[]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};
uchar wendu[7];
uchar wendu0[3];
void shuzu();
void display();
void displaynew();
void dsreset(void);
void tmpchange(void);
void tmpwritebyte(uchar dat);
void delay(uint count)
uint i;
while(count)
i=200;
while(i>0)
i--;
count--;
void dsreset(void)
uint i;
DS=0;
i=103;
while(i>0)i--;
DS=1;
i=4;
while(i>0)i--;
bit tmpreadbit(void)
uint i;
bit dat;
DS=0;i++;
DS=1;i++;i++;
dat=DS;
i=8;
while(i>0) i--;
return(dat);
uchar tmpread(void)
uchar i,j,dat;
dat=0;
for(i=1;i<=8;i++)
j=tmpreadbit();
dat=(j<<7)|(dat>>1);
return(dat);
uint i;
uchar j;
bit testb;
for(j=1;j<=8;j++)
testb=dat&0x01;
dat=dat>>1;
if(testb)
DS=0;
i++;i++;
DS=1;
i=8;
while(i>0) i--;
DS=0;
i=8;
while(i>0) i--;
DS=1;
i++;i++;
dsreset();
delay(1);
tmpwritebyte(0xcc);
tmpwritebyte(0x44);
void tmp()
float tt;
uchar a,b;
dsreset();
delay(1);
tmpwritebyte(0xcc);
tmpwritebyte(0xbe);
a=tmpread();
b=tmpread();
temp=b;
temp<<=8;
temp=temp|a;
if(temp<= 0x0fff)
test=0;
tt=temp*0.0625;
tempnew=tt*100;
temp=~temp+1;
tt=temp*0.0625;
tempnew=tt*100;
test=1;
void shuzu()
uchar i,j;
wendu0[0]=tempnew/100/100;
wendu0[1]=tempnew/100%100;
wendu0[2]=tempnew%100;
for(i=0,j=0;j<3;j++,i+=2)
wendu[i]=wendu0[j]/10;
wendu[i+1]=wendu0[j]%10;
}wendu[6]=10;
void display(uchar n)
uchar i,j;
shuzu();
for(j=0;j<=10;j++)
for(i=n;i<=6;i++)
{if(i==3||i==3)
P0=0x00;
P3=0xff;
P3=weishidisplay[i-1];
P0=P0=s7_table1[wendu[i]];
delay(1);
else if(i==5) {
P0=0x00;
P3=0xff;
P0=P0=0x63;
delay(1);
P0=0x00;
P3=0xff;
P0=P0=s7_table[wendu[i]];
delay(1);
if(test==1)
P0=0x00;
P3=0xff;
P3=weishidisplay[0];
P0=P0=s7_table[11];
delay(1);
…………限于本文篇幅 余下代碼請從51黑下載附件…………
數字溫度計.rar
(64.12 KB, 下載次數: 27)
2018-4-13 10:45 上傳
123456dy
2019-1-3 20:50
你好,我下載的你那個64k的材料,里面都有是啥?能不能分類給我說一下?
