單片機計時器Keil源程序文件
略略略。
2018-4-7 15:55
單片機計時器Keil源程序文件
#include <reg52.h>
sbit ADDR0 = P1^0;
sbit ADDR1 = P1^1;
sbit ADDR2 = P1^2;
sbit ADDR3 = P1^3;
sbit ENLED = P1^4;
unsigned char code image[10][8] = {
{0xFF,0xE7,0xDB,0xDB,0xDB,0xDB,0xDB,0xE7}, //動畫幀1
{0xFF,0xE7,0xE3,0xE7,0xE7,0xE7,0xE7,0xC3}, //動畫幀2
{0xFF,0xC3,0xDF,0xDF,0xC3,0xFB,0xFB,0xC3}, //動畫幀3
{0xFF,0xC3,0xDF,0xDF,0xC3,0xDF,0xDF,0xC3}, //動畫幀4
{0xFF,0xDB,0xDB,0xDB,0xC3,0xDF,0xDF,0xDF}, //動畫幀5
{0xFF,0xC3,0xFB,0xFB,0xC3,0xDF,0xDF,0xC3}, //動畫幀6
{0xFF,0xC3,0xFB,0xFB,0xC3,0xDB,0xDB,0xC3}, //動畫幀7
{0xFF,0xC3,0xDF,0xDF,0xDF,0xDF,0xDF,0xDF}, //動畫幀8
{0xFF,0xC3,0xDB,0xDB,0xC3,0xDB,0xDB,0xC3}, //動畫幀9
{0xFF,0xC3,0xDB,0xDB,0xC3,0xDF,0xDF,0xC3}, //動畫幀10
unsigned char led=0xff;
unsigned char code LedChar[] = { //數碼管顯示字符轉換表
0xC0, 0xF9, 0xA4, 0xB0, 0x99, 0x92, 0x82, 0xF8,
0x80, 0x90, 0x88, 0x83, 0xC6, 0xA1, 0x86, 0x8E
unsigned char LedBuff[6] = { //數碼管顯示緩沖區,初值0xFF確保啟動時都不亮
0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF
unsigned int cnt = 0; //記錄T1中斷次數
unsigned int cnt1=0;
char j; //循環變量
unsigned char m=0;
unsigned long sec = 100000; //記錄經過的秒數,倒計時初值為999999+1
unsigned char buf[6]; //中間轉換緩沖區
unsigned char dir = 0; //定義移位方向變量dir,用于控制移位的方向
unsigned char shift = 0x01;
EA = 1; //使能總中斷
ENLED = 0; //使能U3
TMOD = 0x01; //設置T1為模式1
TH0 = 0xFC; //為T1賦初值0xFC67,定時1ms
TL0 = 0x67;
ET0 = 1; //使能T1中斷
TR0 = 1; //啟動T1
while (1)
if(cnt1>=1000)
{ cnt1=0;
led=~shift;
if (dir == 0) //移位方向變量為0時,左移
shift = shift << 1; //循環移位變量左移1位
if (shift == 0x80) //左移到最左端后,改變移位方向
dir = 1;
else //移位方向變量不為0時,右移
shift = shift >> 1; //循環移位變量右移1位
if (shift == 0x01) //右移到最右端后,改變移位方向
dir = 0;
if (cnt >= 1000) //判斷T1溢出是否達到1000次
cnt = 0; //達到1000次后計數值清零
sec--; //秒計數自減1
//將sec按十進制位從低到高依次提取到buf數組中
buf[0] = sec%60%10;
buf[1] = sec%60/10;
buf[2] = sec%3600/60%10;
buf[3] = sec%3600/60/10;
buf[4] = sec/3600%24%10;
buf[5] = sec/3600%24/10;
//從最高為開始,遇到0不顯示,遇到非0退出循環
for (j=5; j>=1; j--)
if (buf[j] == 0)
LedBuff[j] = 0xFF;
break;
//將剩余的有效數字位如實轉換
for ( ; j>=0; j--) //for()起始未對j操作,j即保持上個循環結束時的值
LedBuff[j] = LedChar[buf[j]];
/* 定時器1中斷服務函數 */
void InterruptTimer1() interrupt 1
static unsigned char i = 0; //動態掃描的索引
static unsigned int tmr = 0; //1s軟件定時器
static unsigned char index = 0; //圖片刷新索引
TH0 = 0xfe; //重新加載初值
TL0 = 0x33;
cnt++;
cnt1++; //中斷次數計數值加1
//以下代碼完成數碼管動態掃描刷新
P0 = 0xFF; //顯示消隱
switch (i)
case 0: ADDR3 = 1;ADDR2=0; ADDR1=0; ADDR0=0; i++; P0=LedBuff[0]; break;
case 1: ADDR3 = 1;ADDR2=0; ADDR1=0; ADDR0=1; i++; P0=LedBuff[1]; break;
case 2: ADDR3 = 1;ADDR2=0; ADDR1=1; ADDR0=0; i++; P0=LedBuff[2]&0x7f; break;
case 3: ADDR3 = 1;ADDR2=0; ADDR1=1; ADDR0=1; i++; P0=LedBuff[3]; break;
case 4: ADDR3 = 1;ADDR2=1; ADDR1=0; ADDR0=0; i++; P0=LedBuff[4]&0x7f; break;
case 5: ADDR3 = 1;ADDR2=1; ADDR1=0; ADDR0=1; i++; P0=LedBuff[5]; break;
case 6: ADDR3 = 0;ADDR2=0; ADDR1=0; ADDR0=0; i++; P0=image[index][0]; break;
case 7: ADDR3 = 0;ADDR2=0; ADDR1=0; ADDR0=1; i++; P0=image[index][1]; break;
case 8: ADDR3 = 0;ADDR2=0; ADDR1=1; ADDR0=0; i++; P0=image[index][2]; break;
case 9: ADDR3 = 0;ADDR2=0; ADDR1=1; ADDR0=1; i++; P0=image[index][3]; break;
case 10:ADDR3 = 0;ADDR2=1; ADDR1=0; ADDR0=0; i++; P0=image[index][4]; break;
case 11:ADDR3 = 0;ADDR2=1; ADDR1=0; ADDR0=1; i++; P0=image[index][5]; break;
case 12:ADDR3 = 0;ADDR2=1; ADDR1=1; ADDR0=0; i++; P0=image[index][6]; break;
case 13:ADDR3 = 0;ADDR2=1; ADDR1=1; ADDR0=1; i++; P0=image[index][7]; break;
case 14: ADDR3 = 1;ADDR2=1; ADDR1=1; ADDR0=0; i=0; P0=led; break;
default: break;
tmr++;
if (tmr >= 2000) //達到1s時改變一次圖片索引
tmr = 0;
index++;
if (index >= 10) //圖片索引達到10后歸零
index = 0;
下載:
計時器.rar
(22.59 KB, 下載次數: 11)
2018-4-7 15:54 上傳
計時器程序
