STM32矩陣鍵盤精簡版源碼
zhaoziyi
2018-4-2 23:40
STM32矩陣鍵盤精簡版源碼
此矩陣鍵盤簡短易懂!
#include "sys.h"
#include "delay.h"
#include "usart.h"
int key_can(void);
void GPIO_Configuration(void);
int cheak=0;
int main(void)
u8 ss[]={'1','2','3','A','4','5','6','B','7','8','9','C','*','0','#','D'};
u8 t=0;
delay_init(); //延時函數初始化
// NVIC_Configuration(); //設置NVIC中斷分組2:2位搶占優先級,2位響應優先級
uart_init(9600); //串口初始化為9600
GPIO_Configuration();
printf("請按鍵 \n");
t=key_can();
if(cheak)
printf("\n\r key=:%c \n\r",ss[t]);
cheak=0;
* 名稱 : Keyscan()
* 功能 : 實現按鍵的讀取。下面這個子程序是按處理 矩陣鍵盤 的基本方法處理的。
* 輸入 : 無
* 輸出 : 按鍵值
* 管腳 :C0-C7
________
7 | |
6 | |
5 | |
4 |______|
3 2 1 0
int key_can(void)
u8 BufferH[4] = {0x7f,0xbf, 0xdf,0xef};//
u8 j,temp;
u8 num=16;
for(j=0; j<4; j++)
GPIO_SetBits(GPIOC,GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7); //上拉輸入默認高電平
GPIO_ResetBits(GPIOC,GPIO_Pin_7>>j); //依次置0
temp=GPIOC->IDR;
temp=temp&BufferH[j];
if(temp!=BufferH[j])
delay_ms(5); //可以去掉消抖
temp=GPIOC->IDR;
if(GPIO_ReadInputDataBit(GPIOC, GPIO_Pin_0) == 0)
num=3+j*4;
else if(GPIO_ReadInputDataBit(GPIOC, GPIO_Pin_1) == 0)
num=2+j*4;
else if(GPIO_ReadInputDataBit(GPIOC, GPIO_Pin_2) == 0)
num=1+j*4;
else if(GPIO_ReadInputDataBit(GPIOC, GPIO_Pin_3) == 0 )
num=0+j*4;
while(temp!=BufferH[j])
temp=GPIOC->IDR;
cheak=1;
return(num);
RCC_APB2PeriphClockCmd( RCC_APB2Periph_GPIOA |RCC_APB2Periph_GPIOC,ENABLE); /*矩陣*/
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU; //上拉輸入
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_Init(GPIOC, &GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; //推挽輸出
矩陣鍵盤.rar
(301.75 KB, 下載次數: 243)
2018-4-3 03:20 上傳
矩陣鍵盤
hfh163
2018-9-14 13:47
參考用在stm32上
hyg1997
2019-1-16 10:54
硬件怎么連接?
彬bin
2019-7-24 19:19
hyg1997 發表于 2019-1-16 10:54
硬件怎么連接?
可以修改IO口
xibo95
2020-1-19 12:20
謝謝分享
ly2324
2020-7-25 17:34
您好,請問temp=temp&BufferH[j];是什么意思呢
ljz444666
2021-4-29 15:13
謝謝博主幫助!!!
