音樂(lè)頻譜FFT單片機(jī)源碼
[打印本頁(yè)]
hdh123
時(shí)間:
2018-3-31 13:46
音樂(lè)頻譜單片機(jī)源程序如下:
#include<STC12C5A60S2.H>
#define channel 0x01 //設(shè)置AD通道為 P1.0
#define ADC_POWER (1<<7)
#define ADC_SPEEDHH (0x03<<5)
#define ADC_START (1<<3)
#define PADCH (1<<5)
#define ADC_FLAG (1<<4)
sbit SDA_R=P1^5; //紅數(shù)據(jù)
sbit SDA_R_TOP=P1^4; //上紅數(shù)據(jù)
sbit SDA_G=P1^3; //綠數(shù)據(jù)
sbit SDA_G_TOP=P1^2; //上綠數(shù)據(jù)
sbit STCP=P1^6; //STR
sbit SHCP=P1^7; //CLK
//放大128倍后的sin整數(shù)表(128)
code char SIN_TAB[128] = { 0, 6, 12, 18, 24, 30, 36, 42, 48, 54, 59, 65, 70, 75, 80, 85, 89, 94, 98, 102,
105, 108, 112, 114, 117, 119, 121, 123, 124, 125, 126, 126, 126, 126, 126, 125, 124, 123, 121, 119, 117, 114, 112,
108, 105, 102, 98, 94, 89, 85, 80, 75, 70, 65, 59, 54, 48, 42, 36, 30, 24, 18, 12, 6, 0, -6, -12, -18, -24, -30,
-36, -42, -48, -54, -59, -65, -70, -75, -80, -85, -89, -94, -98, -102, -105, -108, -112, -114, -117, -119, -121,
-123, -124, -125, -126, -126, -126, -126, -126, -125, -124, -123, -121, -119, -117, -114, -112, -108, -105, -102,
-98, -94, -89, -85, -80, -75, -70, -65, -59, -54, -48, -42, -36, -30, -24, -18, -12, -6 };
//放大128倍后的cos整數(shù)表(128)
code char COS_TAB[128] = { 127, 126, 126, 125, 124, 123, 121, 119, 117, 114, 112, 108, 105, 102, 98, 94,
89, 85, 80, 75, 70, 65, 59, 54, 48, 42, 36, 30, 24, 18, 12, 6, 0, -6, -12, -18, -24, -30, -36, -42, -48, -54, -59,
-65, -70, -75, -80, -85, -89, -94, -98, -102, -105, -108, -112, -114, -117, -119, -121, -123, -124, -125, -126, -
126, -126, -126, -126, -125, -124, -123, -121, -119, -117, -114, -112, -108, -105, -102, -98, -94, -89, -85, -80,
-75, -70, -65, -59, -54, -48, -42, -36, -30, -24, -18, -12, -6, 0, 6, 12, 18, 24, 30, 36, 42, 48, 54, 59, 65, 70,
75, 80, 85, 89, 94, 98, 102, 105, 108, 112, 114, 117, 119, 121, 123, 124, 125, 126, 126 };
//采樣存儲(chǔ)序列表
code char LIST_TAB[128] = { 0, 64, 32, 96, 16, 80, 48, 112,
8, 72, 40, 104, 24, 88, 56, 120,
4, 68, 36, 100, 20, 84, 52, 116,
12, 76, 44, 108, 28, 92, 60, 124,
2, 66, 34, 98, 18, 82, 50, 114,
10, 74, 42, 106, 26, 90, 58, 122,
6, 70, 38, 102, 22, 86, 54, 118,
14, 78, 46, 110, 30, 94, 62, 126,
1, 65, 33, 97, 17, 81, 49, 113,
9, 73, 41, 105, 25, 89, 57, 121,
5, 69, 37, 101, 21, 85, 53, 117,
13, 77, 45, 109, 29, 93, 61, 125,
3, 67, 35, 99, 19, 83, 51, 115,
11, 75, 43, 107, 27, 91, 59, 123,
7, 71, 39, 103, 23, 87, 55, 119,
15, 79, 47, 111, 31, 95, 63, 127
uchar COUNT=15,COUNT1=0,ADC_Count=0,LINE=15,G,T;
uchar i,j,k,b,p;
int Temp_Real,Temp_Imag,temp; // 中間臨時(shí)變量
uint TEMP1;
int xdata Fft_Real[128];
int xdata Fft_Image[128]; // fft的虛部
uchar xdata LED_TAB2[16]; //記錄 漂浮物 是否需要 停頓一下
uchar xdata LED_TAB[16]; //記錄紅色柱狀
uchar xdata LED_TAB1[16]; //記錄 漂浮點(diǎn)
void FFT()
{ //uchar x;
for( i=1; i<=7; i++) /* for(1) */
b=1;
b <<=(i-1); //碟式運(yùn)算,用于計(jì)算 隔多少行計(jì)算 例如 第一極 1和2行計(jì)算,,第二級(jí)
for( j=0; j<=b-1; j++) /* for (2) */
p=1;
p <<= (7-i);
p = p*j;
for( k=j; k<128; k=k+2*b) /* for (3) 基二fft */
Temp_Real = Fft_Real[k]; Temp_Imag = Fft_Image[k]; temp = Fft_Real[k+b];
Fft_Real[k] = Fft_Real[k] + ((Fft_Real[k+b]*COS_TAB[p])>>7) + ((Fft_Image[k+b]*SIN_TAB[p])>>7);
Fft_Image[k] = Fft_Image[k] - ((Fft_Real[k+b]*SIN_TAB[p])>>7) + ((Fft_Image[k+b]*COS_TAB[p])>>7);
Fft_Real[k+b] = Temp_Real - ((Fft_Real[k+b]*COS_TAB[p])>>7) - ((Fft_Image[k+b]*SIN_TAB[p])>>7);
Fft_Image[k+b] = Temp_Imag + ((temp*SIN_TAB[p])>>7) - ((Fft_Image[k+b]*COS_TAB[p])>>7);
// 移位.防止溢出. 結(jié)果已經(jīng)是本值的 1/64
Fft_Real[k] >>= 1;
Fft_Image[k] >>= 1;
Fft_Real[k+b] >>= 1;
Fft_Image[k+b] >>= 1;
// Fft_Real[0]=Fft_Image[0]=0; //去掉直流分量
// Fft_Real[63]=Fft_Image[63]=0;
// x=((((Fft_Real[1]* Fft_Real[1]))+((Fft_Image[1]*Fft_Image[1])))>>5);
for(j=0;j<16;j++)
TEMP1=((((Fft_Real[j+1]* Fft_Real[j+1]))+((Fft_Image[j+1]*Fft_Image[j+1])))>>1);//求功率
if(TEMP1>1)TEMP1--;
else TEMP1=0;
if(TEMP1>31)TEMP1=31;
if(TEMP1>(LED_TAB[j]))LED_TAB[j]=TEMP1;
if(TEMP1>(LED_TAB1[j]))
{ LED_TAB1[j]=TEMP1;
LED_TAB2[j]=14; //提頓速度=12
void Init()
P1ASF = 0x02; //0000,0010, 將 P1.1 置成模擬口
P1M0 = 0x01; //0000,0001用于A/D轉(zhuǎn)換的P1.x口,先設(shè)為開(kāi)漏
P1M1 = 0x01; //0000,0001 P1.0先設(shè)為開(kāi)漏。斷開(kāi)內(nèi)部上拉電阻
AUXR1 &=0xFB; //1111,1011, 令 ADRJ=0
EADC=1; //AD中斷打開(kāi)
ADC_CONTR = ADC_POWER | ADC_SPEEDHH | ADC_START | channel;
//1110 1001 1打開(kāi) A/D (ADC_POWER)轉(zhuǎn)換電源;11速度為70周期一次;
//0中斷標(biāo)志清零;1啟動(dòng)adc(ADC_START);001AD通道打開(kāi)(這里為P1.1);
//P1M0=P1M1=1;
P2M0=1;
TMOD=0X12;
TH0=0xb0; //
TL0=0xb0;
TH1=0xEE;
TL1=0XC0;
ET0=1; //定時(shí)器0 打開(kāi)
TR0=0; //關(guān)閉定時(shí)器
ET1=1;
TR1=1;
PT1=0;
PT0=1;
IPH=PADCH;
IP=PADC; //中斷優(yōu)先級(jí)
EA=1; //總中斷打開(kāi)
void ADC_Finish() interrupt 5
{ ADC_CONTR &= !ADC_FLAG;
Fft_Real[LIST_TAB[ADC_Count]]=(int)((ADC_RES)<<1)+(ADC_RESL>>1)*2;//-512; //按LIST_TAB表里的順序,進(jìn)行存儲(chǔ) 采樣值,,
// ADC_CONTR = ADC_POWER | ADC_SPEEDHH| ADC_START | channel; // 為了采集負(fù)電壓,采用 偏置采集。電壓提高到1/2 vcc,,所以要減去256
if(ADC_Count<=127)ADC_Count++;
else {EADC=0;TR0=0;}
void LED_Display() interrupt 3 //中斷一次 顯示一行。。。
TH1=0xf2;
TL1=0XAa;
for (G=0;G<16;G++) //往點(diǎn)陣屏填充 一行的 數(shù)據(jù)
if(LED_TAB[G]<=LINE+16)SDA_R_TOP=1;
else SDA_R_TOP=0;
if(LED_TAB[G]<=LINE)SDA_R=1;
else SDA_R=0;
if(LED_TAB1[G]==LINE){SDA_G_TOP=1;SDA_G=0;}
else if(LED_TAB1[G]==(LINE+16)){SDA_G_TOP=0;SDA_G=1;}
else SDA_G=SDA_G_TOP=1;
SHCP=1;SHCP=0;
SHCP=1;SHCP=0;
SHCP=1;SHCP=0;
SDA_G_TOP=1;SDA_G=1;SDA_R_TOP=1;SDA_R=1;
SHCP=1;SHCP=0;
STCP=1;STCP=0;
P2=15-LINE; //16掃描輸出
if(LINE>0)LINE--;
else LINE=15;
if(LED_TAB[COUNT]>0)LED_TAB[COUNT]--; //柱狀遞減,
if(COUNT>0)COUNT--;
else COUNT=15;
if(COUNT>0)COUNT--;
else COUNT=15;
//漂浮物遞減
// if(LED_TAB2[COUNT1]==0) //判斷是否需要停頓
// if(LED_TAB1[COUNT1]>LED_TAB[COUNT1])LED_TAB1[COUNT1]--;//大于柱狀則遞減(保持漂浮物在柱狀之上)
// else LED_TAB2[COUNT1]--;
// COUNT1++;
// if(COUNT1>=16)COUNT1=0;
COUNT1++;
void Ad_Control() interrupt 1 //控制采樣率
ADC_CONTR = ADC_POWER | ADC_SPEEDHH| ADC_START | channel; //開(kāi)始AD采集
// ******************* main() *********************************
uchar i;
Init();
ADC_Count=0;
TR0=1;
EADC=1; //開(kāi)啟定時(shí)器中斷0,,開(kāi)啟ADC
while(ADC_Count<128);
for(i=0;i<128;i++)
Fft_Image[i]=0;
FFT();
//FFT運(yùn)算。并轉(zhuǎn)換為 功率值。。。
// TR1=1;
音樂(lè)頻譜顯示3264雙色點(diǎn)陣.rar
2018-3-31 13:45 上傳
點(diǎn)擊文件名下載附件
53.55 KB, 下載次數(shù): 63, 下載積分: 黑幣 -5
