標題: 基于單片機的水庫防汛報警系統設計與仿真 程序 [打印本頁]
作者: 莫默。 時間: 2018-3-30 14:03
#include<REGX52.H>
#include<intrins.h>
#include<absacc.h>
#include<stdio.h>
#define ucharunsigned char
#defineuint unsigned int;
sbit k1=P3^5;
sbit k2=P3^4;
sbit csb=P3^1; //TRIG
sbitcsbint=P3^2; //ECHO
sbit bg=P1^6; //液晶屏背光控制
sbit fmq=P1^3; //蜂鳴器
sbit bjdg=P1^0; //報警燈光
sbit RS =P2^5; //定義液晶屏定義端口
sbit RW = P2^6; //定義液晶屏定義端口
sbit EN = P2^7; //定義液晶屏定義端口
sbit DQ=P3^0; //ds18b20 端口
#define RS_CLRRS=0
#define RS_SET RS=1
#define RW_CLRRW=0
#define RW_SETRW=1
#define EN_CLREN=0
#define EN_SETEN=1
unsigned charaa[]={' ',' ','D','i','s','t','a','n','c','e',':'}; //Distance
unsigned charbb[11]={' ',' ',' ',' ','.',' ',' ',' ',' ',' ',};
unsigned charcc[]={'A','.','A','A','m'};
unsigned chardd[] ={'S','H','U','I','-','W','E','I','-','J','I','A','N','-','C','E'};
//unsigned charee[] ={' ',' ',' ',' ','J','I','A','N','-','C','E',' ',' ',' ',' ',' '};
unsigned charff[] ={' ',' ',' ',' ',' ',' ',' ',' ',' ',' ',' ',' ',' ',' ',' ',' '};
unsigned charzf,a1,a2,a3,xs,e,n,m,z;
int jq=0;
unsigned intdz,k,s,j,bgz,k;
int temp;
floattemperature,csbc,wdz;
bit wh;
/*--------------------------------------函數聲明-----------------------------------------*/
unsigned intReadTemperature(void);
bitInit_DS18B20(void);
unsigned charReadOneChar(void);
voidWriteOneChar(unsigned char dat);
voidLCD_Write_String(unsigned char x,unsigned char y,unsigned char *s);
voidLCD_Write_Char(unsigned char x,unsigned char y,unsigned char Data);
void init();
voidwrite_com(unsigned char com);
voidwrite_data(unsigned char date);
voidDelay400Ms(void);
voidDelayUs2x(unsigned char t);
voidDelayMs(unsigned char t);
while(--t);
while(t--) //大致延時1mS
DelayUs2x(245);
DelayUs2x(245);
/*--------------------------------------18b20初始化----------------------------------------*/
bit dat=0;
DQ = 1; //DQ復位
DelayUs2x(5); //稍做延時
DQ =0; //單片機將DQ拉低
DelayUs2x(200); //精確延時 大于480us 小于960us
DelayUs2x(200);
DQ =1; //拉高總線
DelayUs2x(50); //15~60us 后 接收60-240us的存在脈沖
dat=DQ; //如果x=0則初始化成功, x=1則初始化失敗
DelayUs2x(25); //稍作延時返回
returndat;
/*-------------------------------------讀取一個字節--------------------------------------*/
unsigned char i=0;
unsigned char dat = 0;
for (i=8;i>0;i--)
DQ= 0; // 給脈沖信號
dat>>=1;
DQ= 1; // 給脈沖信號
if(DQ)
dat|=0x80;
DelayUs2x(25);
return(dat);
/*----------------------------------寫入一個字節---------------------------------------*/
unsignedchar i=0;
for(i=8; i>0; i--)
DQ= 0;
DQ= dat&0x01;
DelayUs2x(25);
DQ= 1;
dat>>=1;
DelayUs2x(25);
/*---------------------------------讀取溫度-----------------------------------*/
unsigned char a=0;
int b=0;
int t=0;
float tt=0;
while(Init_DS18B20()); //檢測初始化是否成功
WriteOneChar(0xCC); // 跳過讀序號列號的操作
WriteOneChar(0x44); // 啟動溫度轉換
DelayMs(10);
Init_DS18B20();
WriteOneChar(0xCC); //跳過讀序號列號的操作
WriteOneChar(0xBE); //讀取溫度寄存器等(共可讀9個) 前兩個是溫度
a=ReadOneChar(); //低位
b=ReadOneChar(); //高位
t=b;
t<<=8;
t=t|a;
tt=t*0.0625;
t=tt*10+0.5;
return(t);
main()
TH0=0;
TL0=0;
TMOD=0X19; //T1,T0為16位定時器
EA=0;
bg=0;
n=0;
m=0;
z=0;
init();
LCD_Write_String(0,0,dd);
DelayMs(100);
DelayMs(100);
DelayMs(100);
DelayMs(100);
LCD_Write_String(0,0,ff);
Init_DS18B20(); //初始化DS18B20溫度傳感器
dz=80;
bb[6]=0xdf;
bb[7]=0x43;
e=4;
cc[0]=dz/100+'0';
cc[2]=dz/10%10+'0';
cc[3]=dz%10+'0';
LCD_Write_String(0,0,aa);
LCD_Write_String(11,1,cc);
temp=ReadTemperature(); //測量溫度
fmq=1;
DelayMs(100);
if(temp<0) //溫度正負值判斷處理
temp=-(temp-1);
zf=1;
bb[0]='-';
zf=0;
bb[0]=' ';
csb=1; //啟動一次HC-SR04超聲波測距模塊
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
csb=0;
ET0=1; //啟動計數器T0,用以計時
TR0=1;
EA=1;
j=60; //延時
while(j--)
csbint=1;
j=0
111.docx
2018-3-30 14:02 上傳
20.72 KB, 下載次數: 8, 下載積分: 黑幣 -5
作者: lclnn 時間: 2018-5-6 20:17
你好 這個仿真文件你有嗎
