STM32F103C8T6單片機(jī)pwm精準(zhǔn)驅(qū)動(dòng)控制舵機(jī)程序
[打印本頁(yè)]
YUSUJIFENG
時(shí)間:
2018-3-11 17:16
基于STM32F103C8T6單片機(jī)做的控制舵機(jī)的程序,用PWM精準(zhǔn)驅(qū)動(dòng)
程序如下:
/***************STM32F103C8T6**********************
* 文件名 :main.c
* 描述 : 舵機(jī)測(cè)試
* 實(shí)驗(yàn)平臺(tái):STM32F103C8T6
* 備注 :使用定時(shí)器來(lái)產(chǎn)生pwm波,控制舵機(jī)動(dòng)作
* 接口 :TIM1, CH1-PB13, CH2-PB14, CH3-PB15
****************STM32F103C8T6**********************/
#include "pwm_output.h"
/* 配置TIM1復(fù)用輸出PWM時(shí)用到的I/O */
static void TIM1_GPIO_Config(void)
RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1, ENABLE);//定時(shí)器1時(shí)鐘使能
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);//GPIOB時(shí)鐘使能
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13 | GPIO_Pin_14 | GPIO_Pin_15;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;//復(fù)用推挽輸出
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_Init(GPIOB, &GPIO_InitStructure);
/*配置TIM1輸出的PWM信號(hào)的模式,如周期、極性、占空比 */
static void TIM1_Mode_Config(void)
TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
TIM_OCInitTypeDef TIM_OCInitStructure;
/* PWM信號(hào)電平跳變值 */
u16 CCR1_Val = 0;
u16 CCR2_Val = 0;
//u16 CCR3_Val = 50000;
/* Time base configuration */
TIM_TimeBaseStructure.TIM_Period = 20000 - 1;//定時(shí)器周期,20ms
TIM_TimeBaseStructure.TIM_Prescaler = 72 - 1;//時(shí)鐘預(yù)分頻
TIM_TimeBaseStructure.TIM_ClockDivision = 0;
TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;//計(jì)數(shù)方式:向上計(jì)數(shù)
TIM_TimeBaseInit(TIM1, &TIM_TimeBaseStructure);
/* PWM1 Mode configuration: Channel1 */
TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM2;//選擇定時(shí)器模式:tim脈寬調(diào)制2
TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;//比較輸出使能
TIM_OCInitStructure.TIM_OutputNState = TIM_OutputNState_Enable;
TIM_OCInitStructure.TIM_Pulse = CCR1_Val;
TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_Low;//極性
TIM_OCInitStructure.TIM_OCNPolarity = TIM_OCNPolarity_High;//開反向通道
TIM_OCInitStructure.TIM_OCIdleState = TIM_OCIdleState_Set;
TIM_OCInitStructure.TIM_OCNIdleState = TIM_OCIdleState_Reset;
TIM_OC1Init(TIM1, &TIM_OCInitStructure);
TIM_OC1PreloadConfig(TIM1, TIM_OCPreload_Enable);
/* PWM1 Mode configuration: Channel2 */
TIM_OCInitStructure.TIM_Pulse = CCR2_Val;
TIM_OC2Init(TIM1, &TIM_OCInitStructure);
TIM_OC2PreloadConfig(TIM1, TIM_OCPreload_Enable);
/* PWM1 Mode configuration: Channel3 */
TIM_OCInitStructure.TIM_Pulse = CCR3_Val;
TIM_OCInitStructure.TIM_OCNPolarity = TIM_OCNPolarity_Low;//開反向通道
TIM_OC3Init(TIM1, &TIM_OCInitStructure);
TIM_OC3PreloadConfig(TIM1, TIM_OCPreload_Enable); */
TIM_ARRPreloadConfig(TIM1, ENABLE);
/* TIM1 enable counter */
TIM_Cmd(TIM1, ENABLE);
TIM_CtrlPWMOutputs(TIM1, ENABLE);
/*配置和初始化TIM1 */
void TIM1_PWM_Init(void)
TIM1_GPIO_Config();
TIM1_Mode_Config();
//粗略延時(shí) 不精確!
void Delay_us(unsigned int i)
unsigned char t = 0;
for(;i>0;i--)
for(t=0;t<10;t++)
void Delay_ms(unsigned int i)
for(;i>0;i--)
Delay_us(1000);
//舵機(jī)擺動(dòng)
void Servo_out (void)
TIM1->CCR1 = 2000;//pwm波高電平持續(xù)時(shí)間,2ms
Delay_ms(2000);
TIM1->CCR1 = 1500;
Delay_ms(1000);
TIM1->CCR1 = 2500;
Delay_ms(1000);
wuxishun
時(shí)間:
2018-3-12 19:29
好資料
dillinllp
時(shí)間:
2018-3-31 11:56
好資料,可以參考下。。。。
imhd
時(shí)間:
2018-4-11 16:20
正好香做一個(gè)藍(lán)牙控制電機(jī),參考下,感謝
xiaozhong1314
時(shí)間:
2019-7-12 15:33
想問一下舵機(jī)信號(hào)線接哪個(gè)IO口
xiaozhong1314
時(shí)間:
2019-7-14 09:22
樓主在嗎??請(qǐng)問哪個(gè)IO口怎么改啊
一夢(mèng)紅塵
時(shí)間:
2019-7-14 12:00
拿走用了,
15278556431
時(shí)間:
2019-7-17 09:53
樓主求個(gè)壓縮包
