STM32 wifi無線遙控器設計 在網頁端控制單片機LED的亮滅
masnail
2018-3-7 11:20
無線遙控器設計的課程作業
簡化的設計,在網頁端控制開發板LED的亮滅。
使用udp傳輸協議,可以較好的穿透內網,
實現端端之間的直接通信。
(44.59 KB, 下載次數: 50)
2018-3-7 22:18 上傳
(8.95 KB, 下載次數: 47)
2018-3-7 22:19 上傳
STM32MARVELL88芯片主控
#define DEBUG
#include "drivers.h"
#include "app.h"
#include "api.h"
#include "cfg80211.h"
#include "defs.h"
#include "type.h"
#include "types.h"
#include "moal_sdio.h"
#include "lwip/pbuf.h"
#include "lwip/sys.h"
#include "wpa.h"
#include "moal_main.h"
#include "moal_uap.h"
#include "moal_uap_priv.h"
#include "mlan_ioctl.h"
#include "oled.h"
*分為station和ap兩個設備,其接口函數是不一樣的
*所以在不同的模式下我們選擇相對應的設備進行操作
*wifi_dev指向當前設備
struct net_device *sta_wifi_dev = NULL;
struct net_device *ap_wifi_dev = NULL;
struct net_device *direct_wifi_dev = NULL;
struct net_device *wifi_dev = NULL;
struct net_device *get_wifi_dev()
return wifi_dev;
int is_hw_ok()
return wifi_dev?1:0;
* @brief 設置wifi模式,只是切換模式,不對ap參數進行配置
* @param type : MODE_AP, MODE_STATION, MODE_ADHOC
* @retval ok: 0, err: -1
int wifi_set_mode(int type)
int ret = -1;
int set_type;
moal_private *priv;
struct net_device *saved_dev = wifi_dev;
priv = (moal_private *)wifi_dev->ml_priv;
//暫不支持ap+sta同時存在,切換模式前先關閉wifi
if(priv->bss_role == MLAN_BSS_ROLE_UAP)
wifi_stop_ap();
wifi_disconnect();
if(0)
#ifdef UAP_SUPPORT
else if(type == MODE_AP){
set_type = NL80211_IFTYPE_AP;
wifi_dev = ap_wifi_dev;
OLED_ShowString(16,2," MODE:AP ");
OLED_ShowString(0,0,"IP:");
OLED_ShowString(24,0,"192.168.1.8");
p_dbg("IP:192.168.1.8");
#endif
#ifdef STA_SUPPORT
else if(type == MODE_STATION){
wifi_dev = sta_wifi_dev;
set_type = NL80211_IFTYPE_STATION;
OLED_ShowString(16,2,"MODE:STATION");
else if(type == MODE_ADHOC){
set_type = NL80211_IFTYPE_ADHOC;
OLED_ShowString(16,2," MODE:ADHOC ");
#endif
#ifdef WIFI_DIRECT_SUPPORT
else if(type == MODE_P2P_GO){
wifi_dev = direct_wifi_dev;
set_type = NL80211_IFTYPE_P2P_GO;
else if(type == MODE_P2P_GC){
set_type = NL80211_IFTYPE_P2P_CLIENT;
#endif
else{
p_err("type %d not support", type);
return -1;
if(wifi_dev == NULL){
wifi_dev = saved_dev;
p_err("%s not support", __FUNCTION__);
return -1;
if(wifi_dev->cfg80211_ops->change_virtual_intf){
//ap和sta指向相同的change_virtual_intf
ret = wifi_dev->cfg80211_ops->change_virtual_intf(priv->wdev->wiphy, wifi_dev, (enum nl80211_iftype)set_type, 0, 0);
if(ret != 0)
}else
return ret;
* @brief 設置硬件的多播、廣播、混雜模式
* @param flags : IFF_PROMISC 接收所有的包
IFF_ALLMULTI 接收所有的多播包(暫時采用接收所有多播報的簡單方式,
不處理多播地址表)
int wifi_set_multicast(uint32_t flags)
if(!wifi_dev)
return -1;
wifi_dev->flags |= flags;
if(wifi_dev->netdev_ops && wifi_dev->netdev_ops->ndo_set_multicast_list)
wifi_dev->netdev_ops->ndo_set_multicast_list(wifi_dev);
return 0;
* @brief 設置為混雜模式
* @param
int wifi_set_promisc()
return wifi_set_multicast(IFF_PROMISC);
* @brief 設置wifi頻道,for ap
* @param channel : 1 - 14
int wifi_set_channel(int channel)
int ret = -1;
struct ieee80211_channel ch;
moal_private *priv;
//sta和ap的cfg80211_ops接口是不一樣的,必須檢查其成員是否有效,下同
if(wifi_dev->cfg80211_ops->set_channel){
memset(&ch, 0, sizeof(struct ieee80211_channel));
ch.hw_value = channel;
ch.band = IEEE80211_BAND_2GHZ;
ch.center_freq = ieee80211_channel_to_frequency(ch.hw_value, ch.band);
ret = wifi_dev->cfg80211_ops->set_channel(priv->wdev->wiphy, wifi_dev, &ch, NL80211_CHAN_NO_HT);
}else
return ret;
* @brief 設置wifi模式為AP參數
* @param name : 網絡名稱
* @param key:密碼
* @param key_type:加密模式,可選參數KEY_NONE, KEY_WEP,KEY_WPA,KEY_WPA2
* @param channel:頻道
* @param max_client:最大允許客戶端數量,1 - MAX_STA_COUNT(SDK預設為10)
int wifi_ap_cfg(char *name, char *key, int key_type, int channel, int max_client)
int ret = -1;
char str_tmp[64];
/* example
char *cmd = "ASCII_CMD=AP_CFG,"\
"SSID=QWERT,"\
"SEC=wep128,"\
"KEY=12345,"\
"CHANNEL=8,"\
"MAX_SCB=4,"\
"END";
//配置ap參數我們沒有使用cfg80211_ops提供的, 而是使用更簡單的netdev_ops接口
//netdev_ops接口比較豐富,這里做一個參考
if(wifi_dev->netdev_ops && wifi_dev->netdev_ops->ndo_do_ioctl)
struct iwreq *wrq = (struct iwreq *)mem_calloc(256, 1);
if(!wrq)
return ret;
wrq->u.data.pointer = wrq + 1;
strcpy(wrq->u.data.pointer, "ASCII_CMD=AP_CFG,");
snprintf(str_tmp, 64, "SSID=%s,", name);
strcat(wrq->u.data.pointer, str_tmp);
if (key_type == KEY_NONE)
strcpy(str_tmp, "SEC=open,");
else if (key_type == KEY_WEP)
strcpy(str_tmp, "SEC=wep128,");
else if (key_type == KEY_WPA)
strcpy(str_tmp, "SEC=wpa-psk,");
else if (key_type == KEY_WPA2)
strcpy(str_tmp, "SEC=wpa2-psk,");
snprintf(str_tmp, 64, "KEY=%s,", key);
snprintf(str_tmp, 64, "CHANNEL=%d,", channel);
snprintf(str_tmp, 64, "MAX_SCB=%d,", max_client);
strcat(wrq->u.data.pointer, "END");
wrq->u.data.length = strlen(wrq->u.data.pointer);
ret = wifi_dev->netdev_ops->ndo_do_ioctl(wifi_dev, (void*)wrq, WOAL_UAP_FROYO_AP_SET_CFG);
if(ret == 0)
ret = wifi_dev->netdev_ops->ndo_do_ioctl(wifi_dev, 0, WOAL_UAP_FROYO_AP_BSS_START);
mem_free(wrq);
}else
return ret;
int wifi_stop_ap()
int ret = -1;
ret = wifi_dev->netdev_ops->ndo_do_ioctl(wifi_dev, 0, WOAL_UAP_FROYO_AP_BSS_STOP);
return ret;
* @brief
int wifi_join_adhoc(char *ssid, char *key, int ch)
int ret = -1;
moal_private *priv;
struct cfg80211_ibss_params params;
struct ieee80211_channel channel;
int key_len = strlen(key);
memset(¶ms, 0, sizeof(struct cfg80211_ibss_params));
memset(&channel, 0 ,sizeof(struct ieee80211_channel));
params.channel = &channel;
params.beacon_interval = 100;
params.ssid = (u8*)ssid;
params.ssid_len = strlen(ssid);
params.channel_fixed = TRUE;
params.channel->band = IEEE80211_BAND_2GHZ;
params.channel->hw_value = ch;
params.channel->center_freq = ieee80211_channel_to_frequency(params.channel->hw_value,
params.channel->band);
if(key_len)
params.key = key;
params.key_len = key_len;
params.privacy = TRUE; //使能wep加密
if(wifi_dev->cfg80211_ops && wifi_dev->cfg80211_ops->join_ibss)
ret = wifi_dev->cfg80211_ops->join_ibss(priv->wdev->wiphy, wifi_dev, ¶ms);
}else
return ret;
int wifi_leave_adhoc()
int ret = -1;
moal_private *priv;
if(wifi_dev->cfg80211_ops && wifi_dev->cfg80211_ops->leave_ibss)
ret = wifi_dev->cfg80211_ops->leave_ibss(priv->wdev->wiphy, wifi_dev);
}else
return ret;
#ifdef UAP_SUPPORT
int wifi_get_sta_list(mlan_ds_sta_list *p_list)
int ret = -1;
struct iwreq *wrq = (struct iwreq *)mem_calloc(sizeof(struct iwreq), 1);
if(wrq)
wrq->u.data.pointer = p_list;
ret = wifi_dev->netdev_ops->ndo_do_ioctl(wifi_dev, (void*)wrq, UAP_GET_STA_LIST);
mem_free(wrq);
}else
return ret;
#endif
struct cfg80211_scan_request *new_scan_req(moal_private *priv, char *ssid, u8_t ssid_len)
struct wiphy *wiphy = priv->wdev->wiphy;
struct cfg80211_scan_request *creq = NULL;
int i, n_channels = 0;
enum ieee80211_band band;
for (band = (enum ieee80211_band)0; band < IEEE80211_NUM_BANDS; band++) {
if (wiphy->bands[band])
n_channels += wiphy->bands[band]->n_channels;
p_dbg("_new_connect_scan_req,channels:%d,creq_size:%d\n",n_channels,sizeof(*creq) + sizeof(struct cfg80211_ssid) +
n_channels * sizeof(void *));
creq = (struct cfg80211_scan_request *)mem_calloc(sizeof(*creq) + sizeof(struct cfg80211_ssid) +
n_channels * sizeof(void *),1);
if (!creq)
return NULL;
/* SSIDs come after channels */
creq->wiphy = wiphy;
creq->ssids = (void *)&creq->channels[n_channels];
creq->n_channels = n_channels;
if(ssid_len)
creq->n_ssids = 1;
/* Scan all available channels */
i = 0;
int j;
if (!wiphy->bands[band])
continue;
for (j = 0; j < wiphy->bands[band]->n_channels; j++) {
/* ignore disabled channels */
if (wiphy->bands[band]->channels[j].flags &
IEEE80211_CHAN_DISABLED)
continue;
creq->channels[i] = &wiphy->bands[band]->channels[j];
i++;
if (i) {
/* Set real number of channels specified in creq->channels[] */
creq->n_channels = i;
/* Scan for the SSID we're going to connect to */
memcpy(creq->ssids[0].ssid, ssid, ssid_len);
creq->ssids[0].ssid_len = ssid_len;
} else {
/* No channels found... */
mem_free(creq);
creq = NULL;
return creq;
* @brief 掃描附近的AP,usr_scan_result_callback是我們自定義的一個回調接口
* 每掃描到一個ap就會在wlan_ret_802_11_scan->handle_user_scan_result調用一次,其參數scan_result_data包含一些基本
* 的ap信息,一般已經夠用,如果要更詳細的ap的信息請直接在handle_user_scan_result里面取
* @param
extern void (*usr_scan_result_callback)(struct scan_result_data *res_data);
int wifi_scan(void (*scan_result_callback)(struct scan_result_data *res_data),
char *essid)
moal_private *priv;
struct cfg80211_scan_request *scan_request;
if(!wifi_dev)
return -1;
p_err("AP模式下不支持scan,請先切換到STA模式");
return 0;
usr_scan_result_callback = scan_result_callback;
scan_request = new_scan_req(priv, essid, strlen(essid));
wifi_dev->cfg80211_ops->scan(priv->wdev->wiphy, wifi_dev, scan_request);
//scan是異步實現的,這里調用完會馬上退出
//掃描完成后驅動會自動調用cfg80211_scan_done函數
return 0;
* @brief wifi 是否已經連接
int is_wifi_connected()
int ret = 0;
moal_private *priv;
if(priv->media_connected)
ret = 1;
return ret;
* @brief wifi連接,驅動自動處理加密模式和頻道,用戶只需提供路由器名稱和密碼
* @param
* essid: 即AP名稱
* key: 明文密碼
int wifi_connect( char *essid, char *key)
int result_ret = 0;
moal_private *priv;
int essid_len = strlen(essid);
struct cfg80211_connect_params *smee = 0;
p_dbg("enter %s\n", __FUNCTION__);
OLED_ShowString(0,4,"SSID:");
OLED_ShowString(0,6,"KEY:");
OLED_ShowString(48,4,(u8 *)essid);
OLED_ShowString(48,6,(u8 *)key);
if(essid_len > 32 || key_len > 32)
result_ret = -1;
goto ret;
smee = (struct cfg80211_connect_params *)mem_malloc(sizeof(struct cfg80211_connect_params));
if(smee == 0)
result_ret = -1;
goto ret;
memset(smee,0,sizeof(struct cfg80211_connect_params));
smee->bssid = 0;
memcpy(smee->ssid,essid,essid_len);
smee->ssid[essid_len] = 0;
smee->ssid_len = essid_len;
memcpy(smee->key,key,key_len);
smee->key[key_len] = 0;
smee->key_len = key_len;
smee->auth_type = NL80211_AUTHTYPE_AUTOMATIC;
smee->crypto.wpa_versions = NL80211_WPA_VERSION_2;
smee->crypto.cipher_group = MLAN_ENCRYPTION_MODE_CCMP;
smee->crypto.n_ciphers_pairwise = 1;
smee->crypto.ciphers_pairwise[0] = MLAN_ENCRYPTION_MODE_CCMP;
*smee結構只填充了部分成員,其他成員將在連接的時候自動填充(根據目標ap的信息)
result_ret = wifi_dev->cfg80211_ops->wifi_connect(priv->wdev->wiphy, wifi_dev,smee);
ret:
if(smee)
mem_free(smee);
if(result_ret)
p_err("user_link_app err:%d\n",result_ret);
p_dbg("exit %s\n", __FUNCTION__);
return result_ret;
* @brief 斷開連接
int wifi_disconnect()
int ret = -1;
moal_private *priv;
if(wifi_dev->cfg80211_ops && wifi_dev->cfg80211_ops->disconnect)
ret = wifi_dev->cfg80211_ops->disconnect(priv->wdev->wiphy, wifi_dev, 0);
}else
return ret;
* @brief 讀取mac地址,mac地址從8782芯片讀取
* @param mac_addr : mac地址 6BYTE
int wifi_get_mac(unsigned char *mac_addr)
memcpy(mac_addr, wifi_dev->dev_addr, ETH_ALEN);
return 0;
* @brief 獲取WIFI連接的統計信息(信號強度...)
* @param pStats : 指向station_info的指針
* @param mac : 指向需要獲取的station的地址
int wifi_get_stats(uint8_t *mac,struct station_info *sinfo)
int ret = -1;
moal_private *priv;
if(wifi_dev->cfg80211_ops && wifi_dev->cfg80211_ops->get_station)
ret = wifi_dev->cfg80211_ops->get_station(priv->wdev->wiphy, wifi_dev, mac,sinfo);
}else
return ret;
* @brief 配置省電模式,在保持連接的情況下可達到很可觀省電效果
* 省電模式下的耗電量由數據收發量決定
* 此外用戶可以配置更加細節的電源管理參數,比如DTIM間隔
* 一般情況下使用此函數已經夠用
* @param power_save_level : 取值 0,1,2;
* 0代表關閉省電模式(CAM)
* 1采用DTIM省電方式
* 2采用INACTIVITY省電方式
int wifi_power_cfg(uint8_t power_save_level)
int ret = -1;
moal_private *priv;
if(wrq)
if(sleep)
deep_sleep_para param;
memset(¶m, 0, sizeof(deep_sleep_para));
wrq->u.data.pointer = ¶m;
param.subcmd = UAP_DEEP_SLEEP;
param.action = MLAN_ACT_SET;
param.deep_sleep = TRUE;
param.idle_time = 1000;
ret = wifi_dev->netdev_ops->ndo_do_ioctl(wifi_dev, (void*)wrq, UAP_IOCTL_CMD);
}else
mlan_ds_ps_mgmt ps_mgmt;
memset(&ps_mgmt, 0, sizeof(mlan_ds_ps_mgmt));
wrq->u.data.pointer = &ps_mgmt;
ps_mgmt.flags = PS_FLAG_PS_MODE;
if(power_save_level == 0)
ps_mgmt.ps_mode = PS_MODE_DISABLE;
else if(power_save_level == 1)
ps_mgmt.ps_mode = PS_MODE_PERIODIC_DTIM;
else if(power_save_level == 2)
ps_mgmt.ps_mode = PS_MODE_INACTIVITY;
ret = wifi_dev->netdev_ops->ndo_do_ioctl(wifi_dev, (void*)wrq, UAP_POWER_MODE);
mem_free(wrq);
if(priv->bss_role == MLAN_BSS_ROLE_STA)
if(wifi_dev->cfg80211_ops && wifi_dev->cfg80211_ops->set_power_mgmt)
bool enable;
enable = FALSE;
enable = TRUE;
ret = wifi_dev->cfg80211_ops->set_power_mgmt(priv->wdev->wiphy, wifi_dev,enable, 0);
return ret;
* @brief 這里不再提供WIFI事件的回調
* ap模式下請參考wlan_ops_uap_process_event函數
* sta模式下請參考wlan_ops_sta_process_event函數
int event_callback(int type)
return 0;
extern uint8_t g_mac_addr[6];
* @brief 通過CPU_ID計算出一個隨機數用于填充MAC地址的低3字節
int create_mac(unsigned char *mac)
char psk[33], id[12];
…………限于本文篇幅 余下代碼請從51黑下載附件…………
無線遙控器設計.zip
(9.01 MB, 下載次數: 47)
2018-3-7 11:20 上傳
