包含畫點(diǎn)、畫直線、畫矩形、畫圓函數(shù)等,非常實(shí)用。
#include <w78e052.h>
#include <intrins.h>
#include "ASCII.h"
#include"math.h"
#define NOP _nop_()
typedef unsigned char u8;
typedef unsigned int u16;
typedef unsigned char u32;
sbit OE = P0^2;
sbit A1 = P0^3;
sbit B1 = P0^4;
sbit SHCP=P0^5; //11腳SHCP 移位時(shí)鐘
sbit STCP=P0^6; //12腳STCP 鎖存時(shí)鐘
sbit DATA=P0^7; //數(shù)據(jù)輸入
sbit BEEP=P1^1;
unsigned char ip,tp,min,sec;
u16 time;
unsigned char PLAYBUF[64];
u8 code yi_dong[31] = {0,1,2,3,4,5,6,7,8,9,10,11,12,13,12,11,10,9,8,7,6,5,4,3,2,1,0};
u8 code tab[10] = {"0123456789"};
const uchar code table[160]=
0x10,0x00,0x08,0x0E,0x7F,0x70,0x22,0x40,0x14,0x40,0xFF,0x7E,0x08,0x48,0x08,0x48,
0xFF,0x48,0x08,0x48,0x2C,0x48,0x2A,0x88,0x4A,0x88,0x89,0x08,0x2A,0x08,0x10,0x08,
0x00,0x00,0x00,0x40,0x78,0x40,0x0B,0xF8,0x10,0x48,0x17,0xFE,0x20,0x48,0x7B,0xF8,
0x08,0x40,0x4B,0xFC,0x48,0x40,0x28,0x40,0x17,0xFC,0x28,0x40,0x46,0x40,0x81,0xFE,
; 源文件 / 文字 : 工
; 寬×高(像素): 15×
0x00,0x00,0x00,0x00,0x3F,0xFC,0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,
0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0xFF,0xFE,0x00,0x00,
; 源文件 / 文字 : 作
; 寬×高(像素): 15×16
0x08,0x80,0x0C,0x80,0x09,0x00,0x13,0xFE,0x12,0x80,0x34,0x88,0x50,0xFC,0x90,0x80,
0x10,0x80,0x10,0x84,0x10,0xFE,0x10,0x80,0x10,0x80,0x10,0x80,0x10,0x80,0x10,0x80,
; 源文件 / 文字 : 室
; 寬×高(像素): 15×16
0x00,0x00,0x02,0x00,0x01,0x00,0x3F,0xFE,0x20,0x04,0x40,0x08,0x3F,0xFC,0x04,0x00,
0x08,0x20,0x1F,0xF0,0x01,0x10,0x01,0x00,0x3F,0xF8,0x01,0x00,0x01,0x00,0xFF,0xFE
//數(shù)據(jù)串行輸入
void serial_input(uchar dat)
uint m;
for(m=0;m<8;m++)
if(dat & 0x80)
DATA=0;
DATA=1;
SHCP=0;
SHCP=1;
NOP;
NOP;
SHCP=0;
NOP;
NOP;
dat=dat<<1;
void delay()
unsigned int i = 50000;
while(i--);
//并出
void serial_output()
STCP=0;
STCP=1;
//行顯控制
void HC138_scan(uchar temp)
OE=1;
A1=0x01 & temp;
B1=0x01 &(temp>>1);
//整屏顯示
void display()
uint i,j,k;
unsigned char buf;
serial_output();
for(k=0;k<4;k++) //顯示的四行
for(j=0;j<2;j++) //顯示3、4列
for(i=0;i<2;i++) // 顯示1、2列
buf = PLAYBUF[24+(k<<1)+i+(j<<5)];
serial_input(buf);
buf = PLAYBUF[16+(k<<1)+i+(j<<5)];
serial_input(buf);
buf = PLAYBUF[8+(k<<1)+i+(j<<5)];
serial_input(buf);
buf = PLAYBUF[(k<<1)+i+(j<<5)];
serial_input(buf);
serial_output();
HC138_scan(k);
void point(unsigned char x,unsigned char y,bit c)
unsigned char i;
if(x>=32) return;
if(y>=16) return;
i=0x80;
i>>=x-((x>>3)<<3);
if(c)
PLAYBUF[(y<<1)+((x>>4)<<5)+((x>>3)&0x01)] |= i;
PLAYBUF[(y<<1)+((x>>4)<<5)+((x>>3)&0x01)] &= ~i;
//畫線
void line(u8 x1, u8 y1, u8 x2, u8 y2, bit color)
u8 x, y, t;
if((x1 == x2) && (y1 == y2))
point(x1, y1, color);
else if(fabs(y2 - y1) > fabs(x2 - x1))
if(y1 > y2)
t = y1;
y1 = y2;
y2 = t;
t = x1;
x1 = x2;
x2 = t;
for(y = y1; y <= y2; y ++)
x = (y - y1) * (x2 - x1) / (y2 - y1) + x1;
point(x, y, color);
if(x1 > x2)
t = y1;
y1 = y2;
y2 = t;
t = x1;
x1 = x2;
x2 = t;
for(x = x1; x <= x2; x ++)
y = (x - x1) * (y2 - y1) / (x2 - x1) + y1;
point(x, y, color);
void rectangle(u8 x1,u8 y1,u8 x2,u8 y2, bit color)
line(x1,y1,x2,y1, color);
line(x1,y1,x1,y2, color);
line(x1,y2,x2,y2, color);
line(x2,y1,x2,y2, color);
void filled_rectangle(u8 x1,u8 y1,u8 x2,u8 y2, bit color)
u8 i;
for(i=y1;i<=y2;i++)
line(x1,i,x2,i, color);
//在指定位置畫一個(gè)指定大小的圓
//(x,y):中心點(diǎn)
//r :半徑
void circle(u8 x0,u8 y0,u8 r, bit color)
int a,b;
int di;
a=0;
b=r;
di=3-2*r; //判斷下個(gè)點(diǎn)位置的標(biāo)志
while(a<=b)
point(x0-b,y0-a, color); //3
point(x0+b,y0-a, color); //0
point(x0-a,y0+b, color); //1
point(x0-b,y0-a, color); //7
point(x0-a,y0-b, color); //2
point(x0+b,y0+a, color); //4
point(x0+a,y0-b, color); //5
point(x0+a,y0+b, color); //6
point(x0-b,y0+a, color);
a++;
/***使用Bresenham算法畫圓**/
if(di<0)di +=4*a+6;
di+=10+4*(a-b);
b--;
void load_playbuff(unsigned char *p)
unsigned char i;
for(i=0;i<64;i++)
PLAYBUF = *p++;
void clear_playbuff(unsigned char n)
unsigned char i;
for(i=0;i<64;i++)
PLAYBUF = n;
unsigned char op;
void put_char(u8 x,u8 y,u8 c,bit color)
unsigned char tmp_char=0,i,j;
for (i=0;i<16;i++)
tmp_char=AsciiLib[((c-0x20)*16)+i];
for (j=0;j<8;j++)
if ( (tmp_char >> 7-j) & 0x01 == 0x01)
point(x+j,y+i,color); // 字符顏色
point(x+j,y+i,!color); // 背景顏色
void put_chinese(u8 x,u8 y,u8 *c,bit color)
u8 i=0;
u8 j=0;
u8 tmp_char=0;
u8 tmp_char2=0;
for (i=0;i<16;i++)
tmp_char=c[i*2];
tmp_char2=c[i*2+1];
for (j=0;j<8;j++)
if ( (tmp_char2 >> 7-j) & 0x01 == 0x01)
point(x+j+8,y+i,color); // 字符顏色
point(x+j+8,y+i,!color); // 背景顏色
void display_move(unsigned int c)
unsigned char i;
for(i=0;i<16;i++)
PLAYBUF[i*2] = (PLAYBUF[i*2]<<1)+(PLAYBUF[i*2+1]>>7);
PLAYBUF[i*2+1] = (PLAYBUF[i*2+1]<<1)+(PLAYBUF[i*2+32]>>7);
PLAYBUF[i*2+32] = (PLAYBUF[i*2+32]<<1)+(PLAYBUF[i*2+1+32]>>7);
PLAYBUF[i*2+32+1] = (PLAYBUF[i*2+32+1]<<1)+((c>>i)&0x01);
unsigned int i=1000;
BEEP=0;
P0=0x00;
TMOD = 0x1;
TH0=0xfc;
TL0=0x18;//12Mhz
ET0 = 1;
TR0 = 1;
EA = 1;
min=0;
sec=0;
time=0;
rectangle(0,0,31,15,1);
circle(15,8,4,1);
while(i--)
display();
//load_playbuff(&table[2*32]);
put_char(0,0,tab[min/10%10],1);
put_char(8,0,tab[min%10],1);
point(15,6,1);
point(15,9,1);
point(16,6,1);
point(16,9,1);
put_char(16,0,tab[sec/10%10],1);
put_char(24,0,tab[sec%10],1);
display();
if(time>=1000)
time=0;
sec++;
if(sec>=60)
sec=0;
min++;
if(min>=60)
min=0;
point(15,5,1);
point(15,10,1);
point(16,5,1);
point(16,10,1);
point(15,6,1);
point(15,9,1);
point(16,6,1);
point(16,9,1);
/*******************************定時(shí)器中斷**************************/
void OSInterrupt(void) interrupt 1
TMOD=0x1;
TH0=0xfc;
TL0=0x18;//12Mhz,1ms_delay
time++;
/*******************************結(jié)束********************************/
