低成本 SN8P2624 I/O 直接驅(qū)動 LCD 液晶屏幕:
完整的源程序如下:
SN2624 單片機(jī)IO口直接驅(qū)動LCD 試驗(yàn)程序
/* Compile ...2007-12-21 5:30
E:\07_SN\2604_24\IOLCD\IOLCD.ASM
Link ...
EPROM Check Sum is CF63.
Security Check Sum is 6493.
Chip SN8P2624 has maximum program ROM size : 2044
The program has used size : 381 [0x17D]
The program remain free size : 1663 for use
利用單片機(jī)IO口驅(qū)動3位LCD已經(jīng)成功!
CHIP SN8P2624
//{{SONIX_CODE_OPTION
.Code_Option Noise_Filter Enable
.Code_Option Reset_Pin P02
.Code_Option Watch_Dog Disable ; Disable Watchdog
.Code_Option High_Clk 12M_X'tal ; Crystal/Resonator: 10Mhz~16Mhz
.Code_Option Fcpu #2 ; Fcpu = Fosc/4
.Code_Option Security Enable
//}}SONIX_CODE_OPTION
.NOLIST
INCLUDE e:\07_sn\xsdzmacro.H
INCLUDE e:\07_sn\snmacrox3.h
; INCLUDE E:\07_SN\2604_24\IOLCD\IOLCD_0.ASM
.LIST
.DATA
HIH DS 1
HIL DS 1
LOH DS 1;/滯后,回差
LOL DS 1;/滯后,回差
TZ0D DS 1
DP DS 1
XISCH DS 1;/AD 系數(shù)
XISCL DS 1
XISH DS 1;/AD 系數(shù)
XISL DS 1
SZ03S DS 1
SZ05S DS 1
KEYJS DS 1
KEY10S DS 1;按鍵退出時(shí)間
XSQW DS 1
XSBW DS 1 ;顯示數(shù)碼管寄存器
XSSW DS 1
XSGW DS 1
TQW DS 1
TBW DS 1
TSW DS 1
TGW DS 1
JJJS DS 1
JS0D DS 1;測量零點(diǎn)計(jì)數(shù)
TESS DS 1
TESH DS 1
TESL DS 1
ADJS DS 1
ADH DS 1
ADL DS 1
GNDH DS 1
GNDL DS 1
VINL DS 1
VINH DS 1
VINS DS 1
VREL DS 1
VREH DS 1
VRES DS 1
XSH DS 1
XSL DS 1
DVL DS 1 ;低溫顯示寄存器
DVH DS 1
TEMP0 DS 1
TEMP DS 1
XSJS DS 1
CLJS DS 1
TTH DS 1
TTL DS 1
JS00 DS 1
SEG0H DS 1;寫入LCD數(shù)據(jù)
SEG1H DS 1
SEG2H DS 1
SEG0 DS 1;寫入LCD數(shù)據(jù)
SEG1 DS 1
SEG2 DS 1
LCDJS DS 1
ARD24 DS 1;讀寫地址
RE24 DS 1;讀出數(shù)據(jù)
WR24 DS 1;寫入數(shù)據(jù)
SFL DS 1
SFL0 DS 1
SFL1 DS 1
SFL2 DS 1
FSS05S EQU SFL.0
FK03S EQU SFL.1
F_DIS EQU SFL.2
FK05S EQU SFL.3
F_ENOUT EQU SFL.4
FADCL EQU SFL.5
F_01 EQU SFL.6
FADZH EQU SFL.7
FADAB EQU SFL0.0
FK2S EQU SFL0.1
FM00 EQU SFL0.2
FVIN EQU SFL0.3
FVINX2 EQU SFL0.4
Fdataxt EQU SFL0.5;/數(shù)據(jù)相同
F_READ EQU SFL0.6 ;AD讀數(shù)通知
F_CLKS EQU SFL0.7;測量開始標(biāo)志
FHHH EQU SFL1.0
FWR24C EQU SFL1.1
F24CZ EQU SFL1.2
FSETXS EQU SFL1.3;/設(shè)置系數(shù)
FPSD EQU SFL1.4;設(shè)定鍵標(biāo)志
F_TZ0D EQU SFL1.5
FLLL EQU SFL1.6
;引腳定義
;HC4051控制
PHA EQU FP16
PHB EQU FP17
;10P.充放電電,設(shè)置為開漏輸出
P_CFD EQU FP10
;數(shù)碼管驅(qū)動
P_QW EQU FP54
P_BW EQU FP51
P_SW EQU FP50
P_GW EQU FP52
;電存儲器
P_24SDA EQU FP14;數(shù)據(jù)--------可能與印刷板反了
P_24SDAM EQU FP14M
P_24SCL EQU FP15; 時(shí)鐘
P_24SCLM EQU FP15M
;按鍵
PSD EQU FP02;/28P
PADD EQU FP11;/11P
PDEC EQU FP12;/12P
;控制輸出
POUT0 EQU FP13;/13P
POUT1 EQU FP53;/9P
.CODE
ORG 0 ;代碼起始處
JMP RESET ;復(fù)位向量;地址4至7為保留
ORG 8
JMP ISR ;中斷向量
ORG 10H
LED_TABLE:
B0MOV Y,#TABLELED$M
B0MOV Z,#TABLELED$L
B_ADDZ:
ADD Z,A
BTS0 FC ; 檢查進(jìn)位標(biāo)志C
INCMS Y
NOP
MOVC
RET
TABLELED:;b,a,f,c,g,e,h,d----d 后有一個(gè)圖標(biāo)位----0=點(diǎn)亮
DW 000010101B ;0 /b,a,f,g,c,e,h,d----d 后有一個(gè)圖標(biāo)位
DW 011011111B ;1
DW 001100101B ;2
DW 001001101B ;3
DW 010001111B ;4
DW 100001101B ;5
DW 100000101B ;6
DW 001011111B ;7
DW 000000101B ;8 ;b,a,f,c,g,e,h,d----d 后有一個(gè)圖標(biāo)位
DW 000001101B ;9
DW 111111111B ;滅 10
DW 010000111B ;H 11
DW 110110101B ;L 12
DW 111101111B ;- 13
;SN8P2624:[;OTP ROM : 2K*16 bits.;RAM : 64*8 bits.]
;SN8P2604:[;OTP ROM : 4K*16 bits.;RAM : 128*8 bits.]
RESET:;重置
MOV A,#07FH ;初始化堆棧指針和
B0MOV STKP,A ;禁止全局中斷
CLR PFLAG ;PFLAG = X,X,X,X,X,C,DC,Z
MOV A,#00H ;初始化系統(tǒng)模式
B0MOV OSCM,A
@RST_WDT ; 清看門狗計(jì)數(shù)器
CLRRAM:;清除 RAM
CLR Y
B0MOV Z,#3FH ;2624=64
; B0MOV Z,#080H ;2604=128,這里出現(xiàn)錯(cuò)誤會造成上電有直接進(jìn)入狀態(tài)的情況
CLRRAM0:
CLR @YZ
DECMS Z
JMP CLRRAM0
CLR @YZ
; 系統(tǒng)初始化程序,; 初始化I/O, 定時(shí)器,中斷等
SYSINIT:
MOV A,#00H
MOV P0M,A
MOV P5,A
MOV A,#0FFH ; 使能P0、P1、P2、P5 口的上拉電阻,
MOV P2M,A;全部輸出
MOV P2,A
MOV P1,A
MOV A,#00H
MOV P1M,A
MOV P5M,A;全部輸出
BSET FP50M
MOV A,#0FFH
; B0MOV P1UR,A ;作為COM端口不能上拉!
B0MOV P2UR,A
B0MOV P5UR,A
B0MOV P0UR,A ;
;初始化TC1
B0BCLR FTC1IEN ; 禁止TC1 中斷
B0BCLR FTC1ENB ; 停止TC1 計(jì)數(shù)
MOV A,#70H ;最快速度
; MOV A,#60H ;最快速度,太快不穩(wěn)
; MOV A,#50H ;最快速度,太快不穩(wěn)
B0MOV TC1M,A ; TC1 定時(shí)模式Fcpu/2
MOV A,#00 ;TC1 初始值
;+5V:20R,12M晶體/4=62.4KHZ,產(chǎn)生 -5.04V電壓
B0MOV TC1C,A ; 定時(shí)中斷為10ms
B0MOV TC1R,A
B0BCLR FTC1IRQ ; 清中斷標(biāo)志
B0BSET FALOAD1;使能 TC1自動重裝功能
; B0BSET FTC1ENB ; 開始TC1 計(jì)數(shù)
; B0BSET FTC1OUT;使能 TC1 輸出到 P5.3和禁止P5.3 I/O 功能
;初始化T0
B0BCLR FT0IEN ;關(guān)TC1中斷
B0BCLR FT0ENB ;關(guān)TC1計(jì)數(shù)模式
B0BCLR FT0IRQ ;清TC1中斷申請
MOV A,#00H ;編譯選項(xiàng)16/4=4.0MHZ
; MOV A,#20H ;編譯選項(xiàng)12/4=3.0MHZ
MOV T0M,A;盡量使用最長的中斷間隔
MOV_ T0C,#00;/131
B0BSET FT0IEN ;使能TC1中斷
B0BSET FT0ENB ;開TC1計(jì)時(shí)器
BSET F_DIS
BSET FGIE ;總中斷使能
B_LOOP:;1,2,;顯示1,2,的SEG0對應(yīng)筆段,0=點(diǎn)亮,a4 是千位的筆段.....
/* MOV_ SEG0,#11001011B;**b3,a3,f3,b4,a4,F4
MOV_ SEG1,#11100011B;**c3,g3,e3,c4,g4,e4
MOV_ SEG2,#11101111B;***,d3,*,*,d4,*
;需要3個(gè)表格,它們對應(yīng)某COM端口有效時(shí)的筆段代碼
;如果筆段超過8個(gè),還需要使用2個(gè)寄存器來轉(zhuǎn)移
;COM端口:由+5V經(jīng)過一幾百K電阻,再由GND經(jīng)過一幾百K電阻,構(gòu)成2.5V電平
;這個(gè)電平就是關(guān)閉筆段的電平.就是說,只要把端口設(shè)置為輸入模式,就會關(guān)閉所有筆段.
;筆段電平僅僅有0V和5V的選擇.
;顯示4,7,5,的SEG0對應(yīng)筆段,0=點(diǎn)亮
;2007-12-20 18:44 成功顯示 475 3位數(shù)字
/* MOV_ SEG0,#00001010B;P50-b2, a2,f2,b3,a3,f3,b4,a4,f4
BSET SEG0H.0
MOV_ SEG1,#01011001B;P50-C2, g2,e2,c3,g3,e3,c4,g4,e4
BCLR SEG1H.0
MOV_ SEG2,#01111111B;P50-LO, d2,dp2,*,d3,*,*,d4,*
BSET SEG2H.0
;471
MOV_ SEG0,#11001010B;P50-b2, a2,f2,b3,a3,f3,b4,a4,f4
BCLR SEG0H.0
MOV_ SEG1,#11011001B;P50-C2, g2,e2,c3,g3,e3,c4,g4,e4
BCLR SEG1H.0
MOV_ SEG2,#11111111B;P50-LO, d2,dp2,*,d3,*,*,d4,*
BSET SEG2H.0
;411
MOV_ SEG0,#11011010B;P50-b2, a2,f2,b3,a3,f3,b4,a4,f4
BCLR SEG0H.0
BCLR SEG1H.0
BSET SEG2H.0
JMP B_LOOP
BTS1 FK03S
JMP B_LOOP
BCLR FK03S
BCLR FGIE ;總中斷使能
MOV_ XSBW,#1
MOV_ XSSW,#9
MOV_ XSGW,#1;1X2X3X4X,0,5,6_OK,7X,8,9_OK,
CLR SEG0
CLR SEG1
CLR SEG2
CLR SEG0H
CLR SEG1H
CLR SEG2H
MOV A,XSGW
CALL LED_TABLE
CALL B_MOV8W
MOV A,XSSW
CALL LED_TABLE
CALL B_MOV8WA
MOV A,XSBW
CALL LED_TABLE
CALL B_MOV8WA
BSET FGIE ;總中斷使能
JMP B_LOOP
(未完待續(xù))
