標題: 單片機熱電偶溫度表數碼管顯示量程0-999度源程序 [打印本頁]
作者: cccc888    時間: 2018-1-19 11:06
說明:程序是根據串口時序圖做的,在時鐘高電平期間讀取,不是在時鐘下降沿讀取。手冊上舉例說明強調時鐘下降沿讀取,目前網上程序有這二種。
單片機源程序:
  1. #include "reg51.h"
  2. #include "intrins.h" //_nop_();延時函數用
  3. #define  uchar unsigned char        //用uchar代替unsigned char,1字節0-255
  4. #define  uint  unsigned int        //用uint代替nsigned int,2字節0-26653
  5. sfr P3M0=0XB2;
  6. sfr P3M1=0XB1;
  7. sbit SO = P1 ^ 0;        //P1.0口與SO相連
  8. sbit SCK = P1 ^ 1;        //P1.1口與SCK相連
  9. sbit CS = P1 ^ 2;        //P1.2口與CS相連
  10. uint j;
  11. uint wendu;
  12. uint Read_AD();        //AD轉換數據數據讀取,并返回值
  13. void Display_temp();        //溫度顯示
  14. uchar qian = 0, bai = 0, shi = 0, ge = 0, xiao = 0;        //初始化LED
  15. uint temp;
  16. uchar code tab_1[10] = { 0xC0, 0xF9, 0xA4, 0xB0, 0x99, 0x92, 0x82, 0xF8, 0x80, 0x90 };        //共陽LED段碼表
  17. uchar code tab_2[10] = { 0x40, 0x79, 0x24, 0x30, 0x19, 0x12, 0x02, 0x78, 0x00, 0x10 };
  18. //含小數點共陽段碼 "0"   "1"  "2"  "3"  "4"  "5"  "6"  "7"  "8"  "9"
  19. uchar code tab_3[4] = { 0x01, 0x02, 0x04, 0x08 };        //位碼
  20. uint Read_AD()// AD轉換數據讀取子函數,并返回值
  21. {
  22.         uchar i;
  23.         unsigned int Temp_2;
  24.         Temp_2 = 0;
  25.         CS = 0;
  26.         _nop_();
  27.         for (i = 0; i < 16; i++)        //16位數據讀取
  28.         {
  29.                 Temp_2 <<= 1;//向左移一位
  30.                 SCK = 1;//上升沿脈沖
  31.                 _nop_();
  32.                 _nop_();
  33.                 _nop_();
  34.                 if (SO == 1) Temp_2 = Temp_2 | 0x01;
  35.                 SCK = 0;
  36.         }
  37.         CS = 1;
  38.         SCK = 0;
  39.         Temp_2 = Temp_2 & 0x7FF8;        //取3-14位,變換為溫度值
  40.         Temp_2 = Temp_2 >>3;
  41.         return (Temp_2);
  42. }
  43. void zhuanhuan()
  44. { uint tempB;
  45.         tempB = (wendu&3)*25;
  46.         wendu=wendu>>2;
  47.         wendu = wendu;
  48.
  49.           if (wendu >= 999)        //最高讀取溫度設定為999攝氏度
  50.                         wendu=999;
  51.                 bai = wendu / 100;        //取百位數字
  52.                 wendu = wendu % 100;
  53.                 shi = wendu / 10;        //取十位數字
  54.                 wendu = wendu % 10;
  55.                 ge = wendu %10;        //取個位數字
  56.                 xiao = tempB / 10;
  57.
  58. }
  59. void Display_temp()        //溫度顯示子函數
  60. {
  61.                 P3 = 0x00;
  62.                 P0 = tab_1[bai];
  63.                 P3 = tab_3[0];//顯示百位數字
  64.                 for (j = 300; j > 0; j--) ;        //延時
  65.
  66.                 P3 = 0x00;
  67.                 P0 = tab_1[shi];
  68.                 P3 = tab_3[1];//顯示十位數字
  69.                 for (j = 300; j > 0; j--) ;
  70.
  71.                 P3 = 0x00;
  72.                 P0 = tab_2[ge];
  73.                 P3 = tab_3[2];        //顯示個位數字
  74.                 for (j = 300; j > 0; j--) ;
  75.
  76.                 P3 = 0x00;
  77.                 P0 = tab_1[xiao];
  78.                 P3 = tab_3[3];//顯示小數位
  79.                 for (j = 300; j > 0; j--) ;
  80.
  81. }
  82. void main()        //主程序
  83. { unsigned char i;
  84.         P3M0=0X00;
  85.         P3M1=0X0F;
  86.         CS = 1;
  87.         SCK = 0;
  88.         for (j = 300; j > 0; j--) ;
  89.         while (1)
  90.         {
  91.                 wendu = Read_AD();        // 熱電偶數據讀取,返回溫度
  92.                 zhuanhuan();
  93.                 for(i=20;i>0;i--)
  94.                         Display_temp();        //溫度顯示
  95.         }
  96. }
作者: faridzled    時間: 2018-1-19 20:34
thanks for sharing
作者: snchj    時間: 2018-1-19 23:13
謝謝分享
作者: chjx0132    時間: 2018-3-21 15:29
這能能不能用?
