標(biāo)題: 求兩個(gè)電機(jī),四個(gè)紅外循跡小車程序 [打印本頁(yè)]
作者: WUMING6    時(shí)間: 2017-12-28 10:55
作者: Liuhongtao    時(shí)間: 2019-11-7 19:21
我也想要這個(gè),最好還有51單片機(jī)的連線圖
作者: 趙世海    時(shí)間: 2021-7-3 19:19
#include<reg52.h>
uchar temp,signal,tt1,t0,t1,t2,t3,t4,t5,t6;
void delay_1ms(uint d)
        uint i;
        while(d--)
                for(i=0;i<75;i++);
void motor_run()                   //電機(jī)起動(dòng)
          P1=0x35;
        delay_1ms(200);
        P1=0x53;
        delay_1ms(10);
/*        ENA=1;
        OUT1=0;
        OUT2=1;
        delay_1ms(800);
        OUT2=0;
        delay_1ms(200);
        ENB=1;
        OUT4=0;
        OUT3=1;
        delay_1ms(800);
        OUT3=0;
        delay_1ms(200);
void motor_left()                         //左進(jìn)
        P1=0x30;
        delay_1ms(200);
        P1=0x00;
        delay_1ms(20);
void motor_right()                   //右進(jìn)
        P1=0x05;
        delay_1ms(200);
        P1=0x00;
        delay_1ms(20);
void motor_big_right()                         //粗右進(jìn)
        P1=0x55;
        delay_1ms(200);
        P1=0x00;
        delay_1ms(20);
void motor_big_left()
        P1=0x33;
        delay_1ms(200);
        P1=0x00;
        delay_1ms(20);
void motor_stop()                                        //電機(jī)停止
         P1=0x00;
void motor_back()
        P1=0x53;
        t0=0;
        t1=0;
        t2=0;
        t3=0;
        t4=0;
        t5=0;
        t6=0;
        tt1=0;
        EA=1;
        ET1=1;
        TR1=1;
        TMOD=0x01;
        TH1=-(1000/256);
        TL1=-(1000%256);
                 temp=P2;
                signal=temp&0xff;                   //得到紅外反向信號(hào)
                switch(signal)
                        case 0xff:           //無偏差
                                motor_run();
                                t0++;
                                if(t0==10)
                                        t0=0;
                                        motor_left();
                                        motor_right();
                                t1=t2=t3=t4=t5=t6=0;
                                break;
                        case 0xfd:           //1輪右偏
                                motor_big_left();
                                t1++;
                                if(t1==4)
                                        t1=0;
                                        motor_left();
                                t0=t2=t3=t4=t5=t6=0;
                                break;
                        case 0xef:            //4輪左偏
                                motor_big_right();
                                t2++;
                                if(t2==4)
                                        t2=0;
                                        motor_right();
                                t0=t1=t3=t4=t5=t6=0;
                                break;
                        case 0xfb:     //2輪右偏出軌
                        case 0xf9:           //1、2輪右偏
                                 motor_big_left();
                                t3++;
                                if(t3==4)
                                        t3=0;
                                        motor_left();
                                t0=t1=t2=t4=t5=t6=0;
//                                delay_1ms(10);
                                break;
                        case 0xdf:           //5左偏出軌
                        case 0xcf:      //4、5輪左偏
                                 motor_big_right();
                                t4++;
                                if(t4==4)
                                        t4=0;
                                        motor_right();
                                t0=t1=t2=t3=t5=t6=0;
//                                delay_1ms(10);
                                break;
                        case 0xfe:           //0最右偏出軌
                        case 0xfa:
                                 motor_big_left();
                                t5++;
                                if(t5==1)
                                        t5=0;
                                        motor_left();
                                        motor_left();
                                t0=t1=t2=t3=t4=t6=0;
//                                delay_1ms(10);
                                break;
                        case 0xbf:     //6最左偏出軌
                         case 0x9f:
                                motor_big_right();
                                t6++;
                                if(t6==1)
                                        t6=0;
                                        motor_right();
                                        motor_right();
                                t0=t1=t2=t3=t4=t5=0;
//                                delay_1ms(10);
                                break;
                        case 0xeb:         //前兩傳感器壓在黑線上
                        case 0xdb:         //后兩傳感器壓在黑線上
                        case 0xbe:         //中間兩傳感器壓在黑線上
                        case 0xac:                 //前四傳感器壓在黑線上
                        case 0x9a:                //后四傳感器壓在黑線上
                                motor_back();
                                delay_1ms(200);
                                motor_stop();
//                                delay_1ms(1000);
                        default:
//                                motor_back();
//                                delay_1ms(50);
//                                motor_left();
//                                motor_right();
                                break;
/*void time1() interrupt 3
        TH1=-(1000/256);
        TL1=-(1000%256);
        tt1++;
        if(tt1==300)
                motor_back();
        //        delay_1ms(1);
                tt1=0;
