標(biāo)題: 基于51單片機(jī)的密碼鎖設(shè)計(jì)程序 [打印本頁(yè)]
作者: DJG    時(shí)間: 2017-12-20 14:07
#include<reg52.h>
uchar old1,old2,old3,old4,old5,old6; //原始密碼000000
uchar new1,new2,new3,new4,new5,new6;  //每次MCU采集到的密碼輸入
uchar a=16,b=16,c=16,d=16,e=16,f=16; //送入數(shù)碼管顯示的變量
uchar wei,key,temp;
bit allow,genggai,ok,wanbi,retry,close;         //各個(gè)狀態(tài)位
sbit dula=P2^6;
sbit wela=P2^7;
sbit beep=P2^3;
unsigned char code table[]=
{0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,
0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71,0x00,0x40};
void delay(unsigned char i)
        uchar j,k;
  for(j=i;j>0;j--)
    for(k=125;k>0;k--);
void display(uchar a,uchar b,uchar c,uchar d,uchar e,uchar f)
   dula=0;
   P0=table[a];
   dula=1;
   dula=0;
   wela=0;
   P0=0xfe;
   wela=1;
   wela=0;
   delay(5);
   P0=table[b];
   dula=1;
   dula=0;
   P0=0xfd;
   wela=1;
   wela=0;
   delay(5);
   P0=table[c];
   dula=1;
   dula=0;
   P0=0xfb;
   wela=1;
   wela=0;
   delay(5);
   P0=table[d];
   dula=1;
   dula=0;
   P0=0xf7;
   wela=1;
   wela=0;
   delay(5);
   P0=table[e];
   dula=1;
   dula=0;
   P0=0xef;
   wela=1;
   wela=0;
   delay(5);
   P0=table[f];
   dula=1;
   dula=0;
   P0=0xdf;
   wela=1;
   wela=0;
   delay(5);
void keyscan()
    P3=0xfe;
    temp=P3;
    temp=temp&0xf0;
    if(temp!=0xf0)
      delay(10);
      if(temp!=0xf0)
        temp=P3;
        switch(temp)
          case 0xee:
               key=0;
                           wei++;
               break;
          case 0xde:
               key=1;
                           wei++;
               break;
          case 0xbe:
               key=2;
                           wei++;
               break;
          case 0x7e:
               key=3;
                           wei++;
               break;
         while(temp!=0xf0)
           temp=P3;
           temp=temp&0xf0;
           beep=0;
         beep=1;
    P3=0xfd;
    temp=P3;
    temp=temp&0xf0;
    if(temp!=0xf0)
      delay(10);
      if(temp!=0xf0)
        temp=P3;
        switch(temp)
          case 0xed:
               key=4;
                           wei++;
               break;
          case 0xdd:
               key=5;
                           wei++;
               break;
          case 0xbd:
               key=6;
                           wei++;
               break;
          case 0x7d:
               key=7;
                           wei++;
               break;
         while(temp!=0xf0)
           temp=P3;
           temp=temp&0xf0;
           beep=0;
         beep=1;
    P3=0xfb;
    temp=P3;
    temp=temp&0xf0;
    if(temp!=0xf0)
      delay(10);
      if(temp!=0xf0)
        temp=P3;
        switch(temp)
          case 0xeb:
               key=8;
                           wei++;
               break;
          case 0xdb:
               key=9;
                           wei++;
               break;
          case 0xbb:
               genggai=1;
                           wei=0;
               break;
          case 0x7b:
                             if(allow)
               ok=1;
               break;
        while(temp!=0xf0)
           temp=P3;
           temp=temp&0xf0;
           beep=0;
         beep=1;
          P3=0xf7;
    temp=P3;
    temp=temp&0xf0;
    if(temp!=0xf0)
      delay(10);
      if(temp!=0xf0)
        temp=P3;
        switch(temp)
          case 0xe7:
                             retry=1;
               break;
          case 0xd7:
                             close=1;
               break;
        while(temp!=0xf0)
           temp=P3;
           temp=temp&0xf0;
           beep=0;
         beep=1;
void shumima()                //對(duì)按鍵采集來的數(shù)據(jù)進(jìn)行分配
        if(!wanbi)
        switch(wei)
                case 1:new1=key;
                            if(!allow)        a=17;
                           else a=key;        break;
                case 2:new2=key;
                                if(a==17) b=17;
                                else b=key;        break;
                case 3:new3=key;
                                if(a==17) c=17;
                                else c=key;        break;
                case 4:new4=key;
                                if(a==17) d=17;
                                else d=key;        break;
                case 5:new5=key;
                                if(a==17) e=17;
                                else e=key;        break;
                case 6:new6=key;
                                if(a==17) f=17;
                                else f=key;
                                wanbi=1;        break;
void yanzheng()          //驗(yàn)證密碼是否正確
        if(wanbi)         //只有當(dāng)六位密碼均輸入完畢后方進(jìn)行驗(yàn)證
        if((new1==old1)&(new2==old2)&(new3==old3)&(new4==old4)&(new5==old5)&(new6==old6))
                allow=1;        //當(dāng)輸入的密碼正確,會(huì)得到allowe置一
                keyscan();
                shumima();
                yanzheng();
                if(allow)         //驗(yàn)證完后,若allow為1,則開鎖
                        P1=0x00;
                        if(!genggai)
                                wanbi=0;
                if(genggai)          //當(dāng)S16更改密碼鍵被按下,genggai會(huì)被置一
                        if(allow)         //若已經(jīng)把鎖打開,才有更改密碼的權(quán)限
                                while(!wanbi)        //當(dāng)新的六位密碼沒有設(shè)定完,則一直在這里循環(huán)
                                         keyscan();
                                        shumima();
                                        if(retry|close)         //而當(dāng)探測(cè)到重試鍵S18或者關(guān)閉密碼鎖鍵S19被按下時(shí),則跳出
                                        {        wanbi=1;
                                                break;
                                        display(a,b,c,d,e,f);
                if(ok)          //更改密碼時(shí),當(dāng)所有六位新密碼均被按下時(shí),可以按下此鍵,結(jié)束密碼更改
                {                  //其他時(shí)間按下此鍵無效
                        ok=0; wei=0;
                        genggai=0;
                        old1=new1;old2=new2;old3=new3; //此時(shí),舊的密碼將被代替
                        old4=new4;old5=new5;old6=new6;
                        a=16;b=16;c=16;d=16;e=16;f=16;
                if(retry)        //當(dāng)重試按鍵S18被按下,retry會(huì)被置位
                retry=0; wei=0;wanbi=0;
                new1=0;new2=0;new3=0;new4=0;new5=0;new6=0;
                if(close)  //當(dāng)關(guān)閉密碼鎖按鍵被按下,close會(huì)被置位
                        close=0;genggai=0;//所有變量均被清零。
                        wei=0;        wanbi=0;
                        allow=0;
                        P1=0xff;
                display(a,b,c,d,e,f); //實(shí)時(shí)顯示
