標題: 可以用在51單片機 1602A液晶屏的時鐘程序 [打印本頁]
作者: Bjfhygh    時間: 2017-12-12 16:50
#include<reg52.h>
uchar a,count,S1num,xqnum;
char yue,ri,shi,fen,miao;
int nian;
sbit lcdrs=P2^5;
sbit lcdrw=P2^4;
sbit lcden=P2^3;
sbit S1=P3^0;                                //定義鍵——進入設置
sbit S2=P3^1;                                //定義鍵——增大
sbit S3=P3^2;                                //定義鍵——減小
sbit S4=P3^3;                                //定義鍵——退出設置
uchar code table0[]="2014-08-13 WED";
uchar code table1[]="00:00:00";
uchar code xingqi[][3]={"MON","TUE","WED","THU","FRI","SAT","SUN"};
void delay(uint z)
        uint x,y;
        for(x=z;x>0;x--)
                for(y=110;y>0;y--);
1602液晶顯示器模塊
sbit lcdrs=P2^5;
sbit lcdrw=P2^4;
sbit lcden=P2^3;
void write_com(uchar com)                                        //液晶寫指令
        lcdrw=0;
        lcdrs=0;
        P0=com;
        delay(5);
        lcden=1;
        delay(5);
        lcden=0;
void write_data(uchar dat)                                        //液晶寫數據
        lcdrw=0;
        lcdrs=1;
        P0=dat;
        delay(5);
        lcden=1;
        delay(5);
        lcden=0;
年月日寫入1602函數
void write_sfm(uchar add,uchar dat)                           //寫時分秒函數
        uchar shi,ge;
        shi=dat/10;
        ge=dat%10;
        write_com(0x80+0x40+add);
        write_data(0x30+shi);
        write_data(0x30+ge);
void write_yr(uchar add,uchar dat)                           //寫月日函數
        uchar shi,ge;
        shi=dat/10;
        ge=dat%10;
        write_com(0x80+add);
void write_nian(uchar add,uint dat)                           //寫年函數
        uint qian,bai,shi,ge;
        qian=dat/1000;
        bai=dat%1000/100;
        shi=dat%100/10;
        ge=dat%10;
        write_data(0x30+qian);
        write_data(0x30+bai);
初始化
void init_lcd()                                                          //液晶初始化
        lcden=0;
        nian=2014;
        yue=8;
        ri=13;
        shi=0;        //初始shi、fen、miao
        fen=0;
        miao=0;
        write_com(0x38);                                           //設置16x2顯示,5x7點陣,8位數據口
        write_com(0x0c);                                           //設置開顯示,不顯示光標
        write_com(0x06);                                           //寫一個字符后地址指針加1
        write_com(0x01);                                           //顯示清0,數據指針清0
void init()        //初始化函數
        init_lcd();        //液晶初始化
        write_com(0x80);                                                  //設置顯示初始坐標
        for(a=0;a<14;a++)                                                   //顯示年月日初始值
                write_data(table0[a]);
                delay(5);
        write_com(0x80+0x40);                                           //設置顯示初始坐標
        for(a=0;a<8;a++)                                                        //顯示時分秒初始值
                write_data(table1[a]);
                delay(5);
        write_nian(0,nian);
        write_sfm(6,miao);                                                         //分別將shi、fen、miao送去液晶顯示
        write_sfm(3,fen);
        write_sfm(0,shi);
        count=0;
        xqnum=0;
        S1num=0;        //初始化全局變量count
        TMOD=0x01;        //設置定時器0工作模式1
        TH0=(65535-50000)/256;                                                  //定時器裝初始值
        TL0=(65535-50000)%256;
        EA=1;        //開總中斷
        ET0=1;        //開定時器0中斷
        TR0=1;        //啟動定時器0
獨立鍵盤
獨立鍵盤已接地
void keyscan()
        if(S1==0)
                delay(5);                                        //確認定義鍵被按下
                if(S1==0)
                        S1num++;                                //定義鍵S1按下次數記錄
                        while(!S1);                                //釋放按鍵確認
                        if(S1num==1)                        //S1按下一次時
                                TR0=0;                                //關閉定時器
                                write_com(0xc0+7);        //光標定位到秒位置
                                write_com(0x0f);        //光標閃爍
                        if(S1num==2)                         //S1按下兩次時
                                write_com(0xc0+4);         //光標定位到分位置
                        if(S1num==3)                          //S1按下三次時
                                write_com(0xc0+1);          //光標定位到時位置
                        if(S1num==4)                          //S1按下四次時
                                write_com(0x80+13);          //光標定位到星期位置
                        if(S1num==5)                          //S1按下五次時
                                write_com(0x80+9);          //光標定位到日位置
                        if(S1num==6)                          //S1按下六次時
                                write_com(0x80+6);          //光標定位到月位置
                        if(S1num==7)                          //S1按下七次時
                                write_com(0x80+3);          //光標定位到年位置
                        if(S1num==8)                          //S1按下八次時
                                S1num=0;                          //S1記錄按鍵次數清零
                                TR0=1;                                  //開啟定時器
                                write_com(0x0c);          //取消光標閃爍
        if(S1num!=0)                                           //只有定義鍵按下后S2、S3、S4才有效
                if(S2==0)
                        delay(5);                                        //防抖
                        if(S2==0)                                   //確認按鍵被按下
                                while(!S2);                                //釋放按鍵確認
                                        miao++;                                //調整秒加1
                                        if(miao==60)                //滿60清零
                                                miao=0;
                                        write_sfm(6,miao);                   //每調節一次送液晶顯示一次
                                        write_com(0x80+0x40+6);           //顯示位置重新回到調節處
                                        fen++;                                        //調整分加1
                                        if(fen==60)
                                                fen=0;
                                        write_sfm(3,fen);
                                        write_com(0x80+0x40+3);
                                        shi++;                                          //調整時加1
                                        if(shi==24)
                                                shi=0;
                                        write_sfm(0,shi);
                                if(S1num==4)                                                   //星期加調整
                                        xqnum++;
                                        if(xqnum==7)
                                                xqnum=0;
                                        write_com(0x80+0x0b);
                                        for(a=0;a<3;a++)
                                                write_data(xingqi[xqnum][a]);
                                                delay(5);
                                if(S1num==5)        //日加調整
                                        ri++;
                                        if(yue==2)
                                                if(nian%400==0)
                                                        if(ri==30)
        ri=1;
                                                if(nian%400!=0)
                                                        if(ri==29)
        ri=1;
                                        else if(yue<=7)
                                                if(yue%2==0&yue!=2)
                                                        if(ri==31)
        ri=1;
                                                else if(yue%2!=0&yue!=2)
                                                        if(ri==32)
        ri=1;
                                        else if(yue>=8)
                                                if(yue%2==0)
                                                        if(ri==32)
        ri=1;
                                                else if(yue%2!=0)
                                                        if(ri==31)
        ri=1;
                                        write_yr(8,ri);
                                if(S1num==6)                                                        //月加調整
                                        yue++;
                                        if(yue==13)
                                                yue=1;
                                        write_yr(5,yue);
                                if(S1num==7)                                                 //年加調整
                                        nian++;
                                        if(nian==2019)
                                                nian=2014;
                                        write_nian(0,nian);
                if(S3==0)
                        delay(5);
                        if(S3==0)                                                 //確認按鍵被按下
                                while(!S3);
                                if(S1num==1)
                                        miao--;                                          //調整秒減1
                                        if(miao==-1)                          //減到00后再減重新設置為59
                                                miao=59;
                                        write_sfm(6,miao);
                                if(S1num==2)
                                        fen--;                                           //調整分減1
                                        if(fen==-1)
                                                fen=59;
                                        write_sfm(3,fen);
                                if(S1num==3)
                                        shi--;                                                //調整時減1
                                        if(shi==-1)
                                                shi=23;
                                        write_sfm(0,shi);
                                if(S1num==4)
                                        xqnum--;                                        //調整星期減一
                                        if(xqnum==-1)
                                                xqnum=6;
                                        for(a=0;a<3;a++)
                                                delay(5);
                                if(S1num==5)                                   //調整日
                                        ri--;
                                        if(yue==2)
                                                if(nian%400==0)
                                                        if(ri==0)
        ri=29;
                                                if(nian%400!=0)
                                                        if(ri==0)
        ri=28;
                                        else if(yue<=7)
                                                if(yue%2==0&yue!=2)
                                                        if(ri==0)
        ri=30;
                                                        if(ri==0)
        ri=31;
                                        else if(yue>=8)
                                                if(yue%2==0)
                                                        if(ri==0)
        ri=31;
                                                else if(yue%2!=0)
                                                        if(ri==0)
        ri=30;
                                        write_yr(8,ri);
                                if(S1num==6)                                           //調整月
                                        yue--;
                                        if(yue==0)
                                                yue=12;
                                        write_yr(5,yue);
                                if(S1num==7)                                          //調整年
                                        nian--;
                                        if(nian==2013)
                                                nian=2018;
                                        write_nian(0,nian);
                if(S4==0)        //退出設置、開啟中斷
                        delay(5);
                        if(S4==0)
                                S1num=0;
                                TR0=1;
                                write_com(0x0c);
定時器0
void timer0() interrupt 1                                         //定時器0中斷服務程序
        TH0=(65535-50000)/256;                                         //重裝定時器初始值
        count++;        //中斷次數累加
        if(count==20)                                                         //20次50毫秒即一秒
                count=0;
                miao++;
                if(miao==60)                                                  //秒加到60時分進位
                        miao=0;
                        fen++;
                        if(fen==60)                                                  //分加到60時時進位
                                fen=0;
                                shi++;
                                if(shi==24)                                                //時加到24時清0
                                        shi=0;
                                        xqnum++;
                                        ri++;
                                        if(yue==2)                                        //如果是二月
                                                if(nian%400==0)                         //閏年判斷
                                                        if(ri==30)
        ri=1;
        yue++;
        write_yr(5,yue);
                                                if(nian%400!=0)                           //平年判斷
                                                        if(ri==29)
        ri=1;
        yue++;
        write_yr(5,yue);
                                        else if(yue<=7&yue!=2)           //一月到七月
                                                if(yue%2==0)                //偶數月(除二月)
                                                        if(ri==31)
        ri=1;
        yue++;
                                                else if(yue%2!=0)                         //奇數月
                                                        if(ri==32)
        ri=1;
        yue++;
                                                write_yr(5,yue);
                                        else if(yue>=8)                                         //八月到12月
                                                        if(ri==32)
        ri=1;
        yue++;
        if(yue==13)                                   //如果判斷月份為12月,則加一后重新定義月份為1
        yue=1;
        nian++;
        write_nian(0,nian);
        write_yr(5,yue);
                                                        if(ri==31)
        ri=1;
        yue++;
        write_yr(5,yue);
                                        write_yr(8,ri);
                                        if(xqnum==7)                                        //星期寫入
                                                xqnum=0;
                                        for(a=0;a<3;a++)
                                                delay(5);
                                write_sfm(0,shi);                                //重新寫入數據
                        write_sfm(3,fen);                                        //重新寫入數據
                write_sfm(6,miao);                                                //重新寫入數據
主函數
        init();
                keyscan();        //不停的檢測按鍵是否被按下
作者: 我是江水    時間: 2019-11-14 13:46
不可以下載?
