單片機(jī)8*8矩陣燈程序
pcf
時(shí)間:
2017-12-3 14:01
單片機(jī)8*8矩陣燈程序
剛才上傳的是lcd1602,這個(gè)才是矩陣等8x8.
是一個(gè)矩陣等,采用的輸入時(shí)直觀矩陣。就是8x8矩陣。矩陣中有非零與零兩種狀態(tài)。
單片機(jī)源程序如下:
#include<reg52.h>
#include<intrins.h>
typedef unsigned char uchar;
typedef unsigned int uint;
uchar bdata Lie_Wei;
sbit p00 = Lie_Wei^0;
sbit p01 = Lie_Wei^1;
sbit p02 = Lie_Wei^2;
sbit p03 = Lie_Wei^3;
sbit p04 = Lie_Wei^4;
sbit p05 = Lie_Wei^5;
sbit p06 = Lie_Wei^6;
sbit p07 = Lie_Wei^7;
uchar Ju_Zhen[8][18]= { "1 0 0 1 1 0 0 1 L",
"0 0 0 1 1 0 0 0 L",
"0 0 0 0 0 0 0 0 L",
"1 0 0 0 0 0 0 1 L",
"1 1 0 0 0 0 1 1 L",
"1 1 1 0 0 1 1 1 L",
"1 1 1 1 1 1 1 1 L"
"1 1 1 1 1 1 1 1 L",
sbit p34 = P3^4;
sbit p35 = P3^5;
sbit p36 = P3^6;
void Yan_Shi(char i)
char x=0;
for(;i>0;i--)
for(x=10;x>0;x--);
void Hang_Led(uchar Hang)
char i;
p35 = 0;
for(i = 10*i; i<=8 ;i++)
if(i == Hang)
p34 = 1;
else p34 = 0;
p36 = 1;
_nop_();_nop_();_nop_();
p36 = 0;
void Lie_LED(uint GaoSiWei,uint DiSiWei)
p07 = (bit)(GaoSiWei%10000/1000);
p06 = (bit)(GaoSiWei%1000/100);
p05 = (bit)(GaoSiWei%100/10);
p04 = (bit)(GaoSiWei%10);
p03 = (bit)(DiSiWei%10000/1000);
p02 = (bit)(DiSiWei%1000/100);
p01 = (bit)(DiSiWei%100/10);
p00 = (bit)(DiSiWei%10);
void LED_8x8(char Hang,uint GaoSiWei,uint DiSiWei,uchar Shi_HZ)
Hang_Led(Hang);
Lie_LED(GaoSiWei,DiSiWei);
P0=0xff;
p35=1;
p35=0;
P0 = Lie_Wei;
Yan_Shi(Shi_HZ);
void Ju_ZiFu(uchar Zhi_Zhen[8][18])
uchar i;
for(i=0;i<8;i++)
if(Zhi_Zhen[i][16]=='L')
Hang_Led(i+1);
p07 = (bit)(Zhi_Zhen[i][0]-'0');
p06 = (bit)(Zhi_Zhen[i][2]-'0');
p05 = (bit)(Zhi_Zhen[i][4]-'0');
p04 = (bit)(Zhi_Zhen[i][6]-'0');
p03 = (bit)(Zhi_Zhen[i][8]-'0');
p02 = (bit)(Zhi_Zhen[i][10]-'0');
p01 = (bit)(Zhi_Zhen[i][12]-'0');
p00 = (bit)(Zhi_Zhen[i][14]-'0');
P0=0xff;
p35=1;
p35=0;
P0 = Lie_Wei;
Yan_Shi(1);
P0 = 0xff;
p35 = 0;
p36 = 0;
Yan_Shi(10);
{ uchar CiShu;
for(CiShu=180;CiShu>0;CiShu--)
Ju_ZiFu(Ju_Zhen);
…………限于本文篇幅 余下代碼請(qǐng)從51黑下載附件…………
矩陣燈.rar
(26.7 KB, 下載次數(shù): 14)
2017-12-3 14:00 上傳
點(diǎn)擊文件名下載附件
