八路搶答器仿真圖與單片機程序
紅藍巴薩
2017-12-3 13:37
八路搶答器仿真圖與單片機程序
希望能幫到你,八路搶答器仿真原理圖如下(proteus仿真工程文件可到本帖附件中下載)
(20.21 KB, 下載次數: 69)
2017-12-3 22:14 上傳
(8.56 KB, 下載次數: 73)
2017-12-3 22:13 上傳
#include<reg51.h>
sbit m1=P3^1;
sbit m2=P3^2;
sbit k1=P1^0;
sbit k2=P1^1;
sbit k3=P1^2;
sbit k4=P1^3;
sbit k5=P1^4;
sbit k6=P1^5;
sbit k7=P1^6;
sbit k8=P1^7;
sbit k=P3^0;
sbit beep=P3^7;
uchar code tab[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x77};
uchar shiwei,gewei,xuanshou,count,i,second;
uchar score1,score2,score3,score4,score5,score6,score7,score8;
uint t,m,n,a,a1,a2,a3,a4,a5,a6,a7,a8;
void Timer()
TMOD=0X01;
TH0=0XD8;
TL0=0Xf0;
IE=0X82;
TR0=1;
void tim(void) interrupt 1
{TH0=0xd8;
TL0=0xf0;
count++;
if(count==100)
{ count=0;
second--;}
void delay(uint z)
{ uint x,y;
for(x=z;x>0;x--)
for(y=110;y>0;y--); }
void display (uchar shiwei,gewei,xuanshou)
{ P2=0xfe;
P0=shiwei;
delay(5);
P2=0xfd;
P0=gewei;
delay(5);
P2=0xf7;
P0=xuanshou;
delay(5);
void dis(void)
{shiwei=tab[second/10];
gewei=tab[second%10];
xuanshou=tab[i];
display(shiwei,gewei,xuanshou);
void init()
{ P2=0x04;
P0=0x3f;
t=0;
beep=0;
i=0;
second=29;
score1=60;
score2=60;
score3=60;
score4=60;
score5=60;
score6=60;
score7=60;
score8=60;
a1=1;
a2=1;
a3=1;
a4=1;
a5=1;
a6=1;
a7=1;
a8=1;
{ init();
if(k==0)
{ Timer();
delay(10);
while(!k);
{ dis();
m=0;
n=0;}
if(second==10){beep=1;delay(500);beep=0;}
if(second==0){TR0=0;n=1;
if(k==0)
{beep=1;delay(500);beep=0;second=29;TR0=1;m=1;}
if(n==0)
{ if(k1==0) {delay(5);if(k1==0);while(!k1);t=1;}
else if(k2==0){delay(5);if(k2==0);while(!k2);t=2;}
else if(k3==0){delay(5);if(k3==0);while(!k2);t=3;}
else if(k4==0){delay(5);if(k4==0);while(!k2);t=4;}
else if(k5==0){delay(5);if(k5==0);while(!k2);t=5;}
else if(k6==0){delay(5);if(k6==0);while(!k2);t=6;}
else if(k7==0){delay(5);if(k7==0);while(!k2);t=7;}
else if(k8==0){delay(5);if(k8==0);while(!k2);t=8;}
else if(k==0)
{delay(5);if(k==0);while(!k);t=0;i=0;second=29;beep=1;delay(500);beep=0;TR0=1;}
while(t)
{ if(m==0)
{ switch(t)
{ case 1:
{ TR0=0;i=1;second=0;beep=1;delay(500);beep=0;
a1=0;a2=1;a3=1;a4=1;a5=1;a6=1;a7=1;a8=1;m=1;break;
case 2:
{ TR0=0;i=2;second=0;beep=1;delay(500);beep=0;
a2=0;a1=1;a3=1;a4=1;a5=1;a6=1;a7=1;a8=1;m=1;break;
case 3:
{ TR0=0;i=3;second=0;beep=1;delay(500);beep=0;
a3=0;a1=1;a2=1;a4=1;a5=1;a6=1;a7=1;a8=1;m=1;break;
case 4:
{ TR0=0;i=4;second=0;beep=1;delay(500);beep=0;
a4=0;a1=1;a2=1;a3=1;a5=1;a6=1;a7=1;a8=1;m=1;break;
case 5:
{ TR0=0;i=5;second=0;beep=1;delay(500);beep=0;
a5=0;a1=1;a2=1;a3=1;a4=1;a6=1;a7=1;a8=1;m=1;break;
case 6:
{ TR0=0;i=6;second=0;beep=1;delay(500);beep=0;
a6=0;a1=1;a2=1;a3=1;a4=1;a5=1;a7=1;a8=1;m=1;break;
case 7:
{ TR0=0;i=7;second=0;beep=1;delay(500);beep=0;
a7=0;a1=1;a2=1;a3=1;a4=1;a5=1;a6=1;a8=1;m=1;break;
case 8:
{ TR0=0;i=8;second=0;beep=1;delay(500);beep=0;
a8=0;a1=1;a2=1;a3=1;a4=1;a5=1;a6=1;a7=1;m=1;break;
if(a1==0)
{second=score1;
dis();
if(m1==0)
{delay(5);if(m1==0);while(!m1);beep=1;delay(100);beep=0;score1+=1;if(score1==99)score1=60;}
else if(m2==0)
{delay(5);if(m2==0);while(!m2);beep=1;delay(100);beep=0;score1-=1;if(score1==0)score1=60;
dis();
else if(a2==0)
{ second=score2;
dis();
if(m1==0)
{delay(5);if(m1==0);while(!m1);beep=1;delay(100);beep=0;score2+=1;if(score2==99)score2=60;}
else if(m2==0)
{delay(5);if(m2==0);while(!m2);beep=1;delay(100);beep=0;score2-=1;if(score2==0)score2=60;}
dis();
else if(a3==0)
{second=score3;
dis();
if(m1==0)
{delay(5);if(m1==0);while(!m1);beep=1;delay(100);beep=0;score3+=1;if(score3==99)score3=60;}
else if(m2==0)
{delay(5);if(m2==0);while(!m2);beep=1;delay(100);beep=0;score3-=1;if(score3==0)score3=60;}
dis();
else if(a4==0)
{ second=score4;
dis();
if(m1==0)
{delay(5);if(m1==0);while(!m1);beep=1;delay(100);beep=0;score4+=1;if(score4==99)score4=60;}
else if(m2==0)
{delay(5);if(m2==0);while(!m2);beep=1;delay(100);beep=0;score4-=1;if(score4==0)score4=60;}
dis();
else if(a5==0)
{second=score5;
dis();
if(m1==0)
{delay(5);if(m1==0);while(!m1);beep=1;delay(100);beep=0;score5+=1;if(score5==99)score5=60;}
else if(m2==0)
{delay(5);if(m2==0);while(!m2);beep=1;delay(100);beep=0;score5-=1;if(score5==0)score5=60;}
second=score5;
dis();
else if(a6==0)
{second=score6;
dis();
if(m1==0)
{delay(5);if(m1==0);while(!m1);beep=1;delay(100);beep=0;score6+=1;if(score6==99)score6=60;}
else if(m2==0)
second=score6;
dis();
…………限于本文篇幅 余下代碼請從51黑下載附件…………
八路搶答器.rar
(28.83 KB, 下載次數: 22)
2017-12-3 13:37 上傳
